Question about Hitachi Televison & Video
Vertical hold on a hitachi 53 inch projection tv, does not work on a/v inputs picture is stops rolling on hd inputs. Please help..
    Top Expert:
  • Hitachi Master
  • 74,482 Answers
Hell
The set needs proper attention to its vertical output section, and synchronising seperatror sections. You must have through knoledge in electronics and repairing circuit boards. If you have, replace all the electrolytic capacitors at its vertical output section.
Posted on Feb 20, 2012
SOURCE: Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Posted on Dec 18, 2007
ctf1800
  • 4402 Answers
SOURCE: HITACHI 53" PROJECTION TV 53FDXO1B
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Posted on Feb 06, 2008
SOURCE: Pioneer 501-HD 53 Rear Projection TV- No Picture or Sound
I can get a picture in split screen (half) mode but that's it. Convergence screens, menus, etc. work.
Thanks for your input. I'll keep watching.
Posted on Oct 26, 2008
ladywinn
  • 5138 Answers
SOURCE: SCREEN ROLLS/HITACHI
Replace vertical ic and caps.
Posted on Nov 27, 2008
freetek
  • 5568 Answers
SOURCE: Hitachi 53" rear projection is losing its picture.
If you are not experiencing any shift in colors, it sounds like the power supply is failing since this will affect all three colors.
Posted on Feb 28, 2009
Where is the vertical hold button
This set has no vertical hold control---is picture rolling left right or up down?
Mar 10, 2012 | Hitachi 57F500 57" Rear Projection...
ROLLING PICTURE HATACHI
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Jan 08, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I have a Hitachi 53UDX10B 53 in. Rear Projection HDTV.
Hello iehoryna,
The answer is yes, you will be able to pick up and display HD channels. You will have to use your component video cables between your cable box and your TV. Component video will allow you to view low to medium end HD pictures.
I hope this helps,
Thank you,
Shuttle83
Nov 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
TV wont stay on
Sounds like a short somewhere in there. I see old pre-HD big screen sets going for well under $200 on my local craigslist, so look there for a good replacement, because the repair will cost more.
Or fork over about $500 for a good used HD projection set.
Apr 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Bad picture on a Hitachi 53"
The problem is in the vertical sweep ckt. and is heat related. Would need to be repaired by a tech.
Electrode
Feb 28, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53 fdx 20b pojection tv
If you lost the picture and even the menu does not show up on screen, then I will bet that your high voltage has shut down or the computer has stopped the picture because it has detected a fault in the vertical circuit. In either case this is something that cannot be reset with the buttons or remote and should be handled by a qualified tech.
Oct 24, 2006 | Hitachi 53FDX20B 53" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
