Question about Sony KP-57HW40 57" Rear Projection Television
Sony KP-57WS5610 Blue light will not converge the blue is offset from everything else on the screen so its like a blue shadow Any ideas on whats wrong
THe blue light is not converging correctly the screen was fine until i tried plugging in other sources ie xbox now the blue is shifted of the rest of the picture like a blue shadow any ideas whats wrong
  • Sony Master
  • 3,459 Answers
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then yourconvergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
e8sony KP-57WS5610 Blue light will not converge the  - 69189a5.pngclass=
69189a5.pngSOLUTION #1
What you will need to do is convergence. You can get a repair kit fromTvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
Posted on Mar 18, 2012
tvtechnician
  • 105 Answers
SOURCE: Convergence problem
you will need to replace the stk ic's they are mounted to 2 large heat sinks in side the tv. the ic numbers are on the chips themselves. i do believe it is stk392-510 for sony. once you have the number you can buy these anywhere online. just put new ones in and should be good to go. if this doesnt work then there are a few resistors and fuses by the ic's that sometimes fail.
Posted on Oct 12, 2007
skippy101
  • 143 Answers
SOURCE: Sony KP-53HS30 Convergence Issue
did you check all fuses get back to me
Posted on Nov 02, 2007
  • 71 Answers
SOURCE: kp-57ws510 convergence problem
Start by replacing the convergence amplifiers IC's.
Are two STK 392-560 and after that redo the adjustments.
Posted on Dec 30, 2007
ladywinn
  • 5138 Answers
SOURCE: Sony KP-43HT20 convergence problem
Replace STK-392-110s or 150s upgrade with 180s replace both ics.
Posted on Jan 09, 2008
Ecollier2012
  • 3459 Answers
SOURCE: kp-65ws510 convergence problem
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 13, 2009
There is a blue wavy line from the left top to the middle of the top of the screen. The area above the line is yellowish. Below the line the images are clear until the bottom third where everything has a...
Convergence ICs have failed. The Sony type 1 convergence repair kit available from www.tvrepairworld.com is the correct kit for your model. The kit contains the parts and the CD with instructions.
Jul 16, 2010 | Sony KP-46WT500 46" Rear Projection...
I have a sony kp 48s and there seems to be a blue shadow on the picture?? i've tried everything in the settings to fix it but it just seems like a manufacture malfunction?
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 28, 2010 | Sony Televison & Video
Picture has blue shadow/trail? sony KP-53HS10
This sounds like a bad blue CRT (cathode ray tube) The repair on this is a major job. Beyond the tube replacement it would then require some convergence alignment and possibly some setup on the other related service adj. such as geometry. You may want to get an estimate from a reputable local repair company.
Jan 25, 2010 | Sony KP-53HS10 TV
Sony kp53v75 TV with blue convergence off right by half inch
it is a convergence problem u may have 2 replace conv ic's and some resistors
May 11, 2009 | Sony KP-51WS500 51" Rear Projection...
Blue shadows
yes its the problem of convergence
and for reaar idea of what to replace on the main board and how to replace and how the components look and what is called what and what tools you require to do it yourself and how to fix it
please check the above link by clicking it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jul 21, 2008 | Sony KP-53XBR45 53" Rear Projection...
Everything on the screen has a blue shadow
need to change both convergence ICs STK392-560. you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Sony KP-46WT500 46" Rear Projection...
Convergence problem
did you try to do convergence thru the menu system?
Feb 21, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony tv KP-61HS10 lenses wont align
This is common in those sets. One of your convergence IC's has stopped working and needs to be replaced. The convergence IC should be replaced and the convergence circuits realigned by someone with experience in Sony projection sets.
Aug 09, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
168 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
