Question about Delphi Roady XT XM Radio Receiver
Cannot Get Antenna To Pick-Up Signal
I cannot get my FM Antenna to pickup the satellite radio signal. It only works if I plugin the tape that comes with the Receiver. I put the radio on channel 88.3 FM and also went in menu to ANTENNA SIGNAL. I got 3-4 bars on SATELLITE but no bars on TERRESTRIAL... How can I get it working? Thanks!!!!
If your roadyxt came in a red box then you need to hook up the XM SureConnect to your vehicles antenna. The instructions that come with it are simple and straight forward. Your FM transmitter will not work unless you hook up the sureconnect
Posted on Jan 05, 2007
How do i connect my xm roady sa10035 to my car cd player?
Posted on Feb 02, 2009
I have audiovox Sirius radio from 2004 and still works fine. I am having a problem finding a frequency setting while driving from phila. Pa. To Newark de. Can you help me with a frequency setting that...
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
Jan 06, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
No Signal on XM Radio - Goes in and out of Signal
xm will not hold signal but if I move the antenna wire around inside the vehicle it will suddenly come in clear as day
Sep 02, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
SureConnect problem?
The problem is most likely the ground connection of the antenna to the vehicle chasis.
If the body is metal (and not a composite material) the base of the antenna should be grounded to the vehicle through the mount. Usually, the antenna base has "teeth" on it to make a good ground connection to the body. If this mount is not tight or there is paint or rust preventing a good electrical connection, you'll get weak reception.
Charlie
Aug 20, 2009 | Audiovox Xpress EZ XM Satellite Radio...
Can i get fm signal from a satellite dish we no longer use? This is still attached to the roof. I would like to use that coaxial cable from the dish and connect to my receiver.
No, you won't get significant signal in the FM spectrum from your satellite LNB coax. The dish is tuned to pick up signals of a very different frequency, and aimed to reject any signals not coming from a very specific direction -- up where the satellites are.
For FM, you need to receive signals from ground-based transmitters, in a different frequency range.
That said, you can totally use the coax to bring signals from your rooftop down to your stereo. To do this, you'd need to get up on the roof, disconnect the coax from your satellite dish and attach it to an FM antenna.
Best of luck!
Aug 09, 2009 | JVC Audio Players & Recorders
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Dec 31, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Pioneer inno radio-doesn't work in car
When its in the car dock, the Inno sends an FM signal to the car radio. It does not receive a signal from the car radio. You must have the external antenna correctly installed outside the vehicle for the Inno to work. The built in antenna is disabled when the device is placed in the car dock. Make sure to test it outside, since garages or car ports will block the signal.
Dec 03, 2008 | Pioneer XM2go Inno Satellite Radio...
FM output
I had the same problem. Only thing that I came up with that was consistant is plugging it into the aux jack on my radio so you don't have to depend on FM frequency. But, my unit crapped out this week and I hope it is under warranty.
Aug 23, 2008 | Audiovox Xpress Satellite Radio Receiver...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
XM Roady2 Built in FM Modulator not working
It's not in the menu selections because the Roady 2 does not have an internal FM transmitter. The Roady XT does though.
Feb 01, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Delphi Roady XT XM Radio Receiver Logo
477 people viewed this question
Top Delphi Audio Players & Recorders Experts
xxxxxx xxx
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
