Question about X2Gen MG19MY 19" LCD Monitor
X2GEN 19" Monitor
Goes on 1 sec then image dissapears...
  • 348 Answers
Becauce of overload such a problems are come please disolder path of an eht and look whether smps gives output or not if smps gives output contineusly then replace eht
Posted on Oct 27, 2008
Www rockauto com
hi Robert
do this procedure and your Nissan will be OK
switch ignition ON till airbag light goes OFF briefly ( approx. 7 sec) immediately after light goes out turn ignition OFF for 3 sec,
repeat this 3 times, after you switch ignition OFF 3rd time for 3 sec
switch ignition ON for 1 sec then OFF, again switch ignition on and start the car, the AIR BAG light will goes OFF.
let me know how it goes
good luck
Feb 04, 2014 | Nissan Armada Cars & Trucks
TV Samsung WS-32Z308P (Slim-Fit CRT). Chassi S62A. TV keeps turning on and off in a 15 min cycle.
mine had 6 bad capasitors on which i replaced for 3.99 and been fine since.heres where i got my guide from.hope it helps...
ELECTRONIC EQUIPMENT REPAIR CENTRE
samsung smart tv fix YouTube
Dec 03, 2013 | Samsung WS32Z308P 32" TV
When I plug the monitor it won't stay on. Why?
1. CRT or LCD?
2. Do you have an image of any kind for that 45 sec.?
When it drops out after 45 sec, do you have any strange behavior as you look at the screen (colors, blinking, lines, squiggles, noises, smells)?
3. When failing, does the power drop out (ON light goes OFF)?
How long do you need to wait until you can turn it ON again?
4. What is the status of your screen saver/power saver? 45 sec seems pretty short but it's still possible.
5. What does the manufacturer's website have to say about this problem? What do other users have to say when you search for your model?
I know these are just more questions but your question is too generic to offer specific comments that might be more useful.
Apr 12, 2013 | Computers & Internet
Hello, My phone is a Samsung SGH D 900 and its worked absolutly fine until yesterday. 2 symptoms: Symptom 1: The red phone button on the right is very reluctant to register key presses (though it works...
That has got to be a flex problem with your phone.the flex connects the movable parts of your phone. you will have to see a certified engineer to fix a new flex for your phone.thanks
Sep 23, 2011 | Samsung SGH-D900 Cellular Phone
BLURRED IMAGES
This is usually because it is hard to keep the camera absolutely still when taking the picture. It also happens when the subject is moving.
You could test that these are the problems by taking a picture of a still subject with the camera sitting steadily on a table. If the image is not blurred it means the camera itself is not faulty, and that it is not causing the problem.
The tendency to blurring depends upon how bright the light is. The sensor of digital cameras, or film on 35mm cameras, requires a certain amount of light to be able to record a good image, and the time needed to gather this amount of light is called the 'exposure' (e.g. 1/100 or 1/8 sec.).
If the light is poor the exposure will be longer and the image will be more likely to be blurred if the camera is not still, or if the subject moves.
The ISO setting (ASA for the film of 35mm cameras) determines the sensitivity of the sensor the higher settings, say ISO 800, being more sensitive. The disadvantage is that for each camera the image becomes too blotchy to be any use at a certain high ISO.
At higher ISO the sensor requires a lower exposure, and the Fnumber, which is the degree of light the lens lets in, has a similar influence: e.g. a lower Fnumber, say F2, allows a shorter exposure than F5.6.
With experience and practice, cameras which have a 'stabiliser' (O.I.S) can produce good pictures with exposure down to 1/4 sec but the limit is more likely to be 1/15 sec to 1/8 sec at best.
Untill you know how to use the manual settings it is best to use automatic settings and an ISO of 200 to 400 at most.
Jan 16, 2011 | Cameras
I want to know which lens in better the 70-200mm vr ii or the 70-300mm. please let me know
Both have 70 mm as the widest angle of view, and up to 200 mm as telephoto, while one goes 50% further to 300 mm telephoto range. This means you can zoom in on objects further away than with the 200 mm lens. This is called the focal length of the lens.
The 200 mm offers VR II (second generation of Vibration Reduction) technology, which will allow shooting without a tripod in darker situations than without this technology. This can be a very handy feature if you are in low light situations and don't like to carry a tripod around.
Besides the focal length, a big part of a lens's cost and desirability is how "fast" it is. A lens that has an opening of "f2" is said to be "twice as fast" as one that is "f4". Another way to think of it is that it can allow twice the amount of light into the camera in the same amount of time that an f4 lens can. This means you can shoot in 1/60 sec at f2 as opposed to 1/30 sec at f4 to get the same amount of light in the image. If you don't have a tripod, and you're shooting at 70mm, 1/60 sec is the slowest you can shoot to get a non-blurred image (don't shoot slower than the inverse of the focal length: 70mm = 1/70 sec or 1/60 sec and when zoomed in 200 mm = 1/200 sec - or 1/250 on your camera) The more inexpensive wide angle zooms are often f4.5 - f5.6 and can run several or more hundred dollars. The f2 lenses cost several times more than the f4 - f5 counterparts. This is where the VR technology comes into play. This feature "freezes" the image to allow for an exposure that would be too blurry or otherwise not viewable. You can read a quick article about the differences between VR and VR II for Nikon lenses here. There are others to read, too - so read more than one for more than one opinion.
Another variable, is the coatings. Multi-coated lenses are generally more expensive than single or non coated lenses. Each coating reduces unwanted effects of stray light, etc. that can cause flares on images, etc. You can read more about coatings here.
There are other variables, but those are the main points. You'll have to weigh the differences between the lenses, your intended use for them and cost.
I hope this provided a good starting point for you and good luck!
Nov 18, 2010 | Nikon D90 Digital Camera with 18-105mm...
No picture, no sound, won't turn ON. Lamp light is ON
It sounds like the color wheel is beginning to fail. I would recommend calling a technician to repair this problem. You can call 1-800-samsung to find the closest service center.
Jul 07, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Satellite A25-S279 screen flickers and goes blank after 5-10 secs
are you getting image on your LCD while booting up in the bios and windows loading screen ?
if yes, then perform a windows installation.
Aug 24, 2009 | Computers & Internet
No printing on right side, I replaced the imaging drum but that did not solve the problem.
u hav to check the drum and adjust its position,u also check the position of the tray in the printer.
Aug 20, 2008 | Dell 3100cn Laser Printer
Internal memory
Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card SHQ 2288 x 1712 4 images 5 images 178 images HQ 2288 x 1712 14 images 16 images 523 images SQ1 1600 x 1200 27 images 32 images 1030 images SQ2 640 x 480 144 images 165 images 5324 images Storable movie length and resolution (approximate figures). The number of movies saved is based upon the storage capacity of the xD-Picture Card and length of each movie. Quality Mode Resolution 14MB Internal Memory 16MB xD-Picture Card 512MB xD-Picture Card HQ 320 x 240 30 fps movie 20 sec. max movie 24 sec. max movie 12 min. 54 sec. movie SQ 320 x 240 15 fps movie 41 sec. max movie 48 sec. max movie 25 min. 48 sec. movie
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
X2Gen MG19MY 19" LCD Monitor Logo
73 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
