Question about Canon PowerShot A540 Digital Camera
Memory Card Error
I have a memory card error all of sudden on my camera. I tried two different cards and nothing. I was told to format the card but that option skips on my menu when I try to access it.
  • gziebell Nov 30, 2008
    I am also getting a "memory card error" message. I've had no problems for three years, but am trying a new 4GB card. It's the same brand (SanDisk) as my old one.
Memory card error. New card did not help. adjusting notch on side of memory card did not help. What's up? I only took about 100 pictures when this happened. Camera is hardly broke in!
Posted on Nov 05, 2008
Memory card locked! My camera suddenly gives this error. I have already checked if actually the card is locked but it isn't. I have also formated the card, and tried with another card: the camera gives...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Oct 24, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Memory card error
If you get a message on your camera such as "Memory Card Error" AND there are no photos that you want still on the card, the first step is to format the card through the camera menu (Note: if you have an xD card, once you re-format your card any photos cannot be recovered.). Read your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
If you do have valuable photos on the card, then DO NOTHING (do NOT format the card, do NOT take any more photos). You need to undertake a photo recovery. For options on Photo Recovery, click here. Once you have recovered your photos and archived them, then reformat the memory card through the camera as outlined above.
Keep us updated (remember to rate this answer).
Dec 22, 2010 | Canon Cameras
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
My Canon A620 has suddenly stopped finding the memory card. It comes up with "No Memory Card" and will not do anything else. I've tried a different card but it is the same problem. Possibly there is a...
There are several possible causes for "memory card locked" or "memory card error", and "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 13, 2010 | Canon Cameras
Memory card error
If the card works on OTHER devices, and you've formatted the cards... the only conclusion you can really have is that it's a problem with the camera. Repair or replace.
Jul 08, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
When i turn the camera on....it saids memory card requires formatting. then continues to say formatting will delete everything on memory card. i press continue and nothing happens. goes back to say memory...
Use a computer with memory card reader, and read the card using a computer.
If the computer says the same and does not read the card, then the pictures inside the card are usually lost.
If computer instead does read the card, then transfer all picture on computer using the memory card reader, and format the card using complete formatting.
If you need to use the camera tonight, then buy a spare memory card.
If the camera returns same error on different card, then you may have a faulty memory card slot, but that is quite uncommon.
Regards
Jun 18, 2009 | Kodak EasyShare C875 Digital Camera
Memory card parameter error is finding in my memory card.
The memory card may have developed an error in card logic format.
Save all data from memory card into computer, then format the card clicking right button of mouse on card (removable disk) on computer and select format option.
If you still get the error some time after formatting the card, then card is faulty, get a refund or replacement.
If I was in your shoes I would ask a replacement immediately, if card is really faulty it won't warn you before losing all your data.
Aug 15, 2008 | Panasonic Lumix DMC-FX8 Digital Camera
Card Error
firstly don't use the card, don't try and take any further pictures.
If you don't have a card reader, buy one, there under $20 and make the job of downloading so much quicker.
If you get an error with the memory card on your computer there are many programs that can help you recover faulty formatted or corrupt memory cards. Do a search on google and try a few as some are better than others and some work better in certain situations than others.
searches to try
memory card recovery
memory card repair
Corrupted Memory Card
I wish you the very best of luck..
If I can be of further help drop me a line
Jun 14, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Samsung S630 Digital Camera, Card Error and Format Error
you have several options:
1. see in the specification details of your camera what memory card is compatible for camera. for S630 it is SDHC/MMC/SD card (Up to 4GB Guaranteed). see if you're using memory card within this capacity and type. If you're using a different memory card type and capacity, try to use memorycard that is compatible with your camera.
2. try to use memory card to other devcie like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
3. try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error meassage, camera needs service.
hope these options solve one of your problems. c",)
Dec 29, 2007 | Samsung Digimax S630 Digital Camera
Canon PowerShot A540 Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
