Question about Blaupunkt Car Audio & Video
If a room is 16 ft x 19 ft and the door is 3ft x 7 ft the ceiling is 9 ft high. A gallon of paint will cover 77.8 ft square. If you do not paint the door how many gallons do you need to paint the room
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 28 Answers
Frist whats the plan ok lets try this converstion factors ok units nowsomething we understand and divide or then use the calcuator orif this a trick question someting trying i dont know ok now so like forcommon everday sitution so you make this equation which is your forumlanow you see the tricky part its mix the paint so i am not bugged on that howmix and get the paint color this after the fact so your not worried huh rightneither am i so your buying a color i dont mix need more paint its whiteis color so convert it all in to something and divide it and did your equation carry though and do all the units just to make sure you get theidea you know not to paint the floor so figure for everything and that in pararanatsis is subtracted off ok a door and windows or open space sostart equation string like inside a box in whats left is dived out gallonsall converted for each term now write your formula equation subtract you didnt paint the floor its the way they state the problem s to paint so
Posted on Feb 20, 2012
How to convert 200 cubic ft to square feet
Cubic feet is a measure of volume, while square feet is a measure of area. There is no direct conversion between them.
Imagine two rooms that are 20 feet by 20 feet. One room has a ceiling 8 feet high, the other has a ceiling 10 feet high.
Both rooms are 400 square feet, but the first room is 3200 cubic feet while the second is 4000 cubic feet.
Oct 14, 2016 | Office Equipment & Supplies
I would like to know how many gallons of water there are in a pool depth1ft 7ins length8ft by 3ft 9ins wide
Google is amazingly good at calculations. Just go to Google and put in what you want to know, in this case: 1 ft 7 in x 8ft x 3 ft 9 in gallons
May 02, 2016 | Pool & Spa
My pool is 16feet wide by 32 long 10 feet deep what is the square footage
What you looking to know?
Square feet suggests a flat area, like the floor plan of the pool, which would be 16 x 32 = 512 square feet. Like you'd measure walls for tiles or paper etc.
As you've given 3 dimensions, sounds like your after the cubic capacity/volume of the pool, in which case your looking at cubic feet (same as flat area above, but with the added depth to go from flat 2d, to 3d (2 vs 3 dimensions)), which would be 16 x 32 x 10 = 5,120 cubic feet.
Jun 02, 2015 | Pool & Spa
I need the formula for figuring square feet, say a 12 x 25 foot square---Need to know how much paint would be needed?
12 x 25= 300 sq ft.
Divide that by whatever the paint can says the coverage is.
if paint says 1 gallon covers 200 sq ft then u need 1.5 gallons
Apr 03, 2015 | Miscellaneous
Michael has to paint a house whose size is 2,800 square feet. He used 5 gallons of paint to cover 1,750 square feet. How many more gallons of paint will he need to cover the remaining area?
If Michael used 5 gallons to cover 1750 square feet, we can calculate how much each gallon covers by taking 1750 and dividing it by 5, which is 350 square feet per gallon.
He has 2,800 square feet to paint, while he has now painted 1, 750 square feet. We have to calculate how much more he needs to paint by subtracting 1,750 from 2,800. I get 1050 square feet to still paint.
We divide this amount 1,050 and divide it by 350 square feet per gallon. I get 3, so we need 3 more gallons. If it was 3 point something, we would have to get an extra gallon to complete the job.
Good luck.
Paul
Mar 13, 2015 | Office Equipment & Supplies
How do I calculate the amount of paint needed for walls in a 12 foot by 16 foot room with 8 foot ceilings?
Ceiling paint estimator
Use the following formula to estimate the amount of ceiling paint you need. Double the result if the ceiling requires two coats.
1. Multiply the length of the ceiling times its width to find its area.
14 × 20 = 280 square feet
2. Divide that number by 350 (the estimated square feet covered per gallon) to figure out how many gallons of paint you need.
280 ÷ 350 = .8
For this example, you want to buy 1 gallon of ceiling paint for a single coat.
Wall paint estimator
Use the following formula to estimate the amount of wall paint you need. Double the result if the walls require two coats.
Feb 18, 2015 | Tools & Hardware - Others
1 gallon of any liquid, poured out at 1 mil wet film thickness, will cover approximately how many square feet?
One gallon when applied to a horizontal wall will cover 820 sq. ft. above 87 degrees F. OAT, standard humidity, MSL. thirsty , smooth surface and a way to measure and maintain a 1 mil thickness, in-doors and oil based paint, will skin over as it dries. latex will measure to 1200 sq. ft. @95* F.
Oct 04, 2014 | Tools & Hardware - Others
What is 9600 cubic ft converted to square ft?
Cubic foot is a unit of volume. Square foot is a unit of area. There is no direct conversion between them.
A 9600 cubic foot room with a ten-foot high ceiling is 960 square feet. If the roof is eight feet high, the area is 1200 square feet. If the roof is 12 feet high, the area is 800 square feet.
Jul 02, 2014 | Office Equipment & Supplies
Hi i need to know how to convert 80 sq ft to cubic meters
You don't. Square feet is a measure of area while cubic meters is a measure of volume.
Consider a room 8 ft by 10 ft. The floor area is 80 square ft. What's the volume of the room in cubic feet (let's not worry about converting to meters yet). Well, that depends on the height of the ceiling, doesn't it? If the ceiling is 8 ft high then the volume is 640 cubic feet. If the ceiling is 12 ft high then the volume is 960 cubic feet. Without that third dimension, you can't calculate the volume.
Oct 18, 2013 | Office Equipment & Supplies
I need a diagram of a 1995 ford escort engine
96 escort 1.9L
Engine Components
Item Part Number Description 1 6766 Oil Filler Cap 2 6A548 (8 Req'd) Valve Cover Bolt 3 6582 Valve Cover 4 — Exhaust Manifold Shield-to-Exhaust Manifold Nut (4 Req'd) 5 9A462 Exhaust Manifold Shield 6 — Exhaust Manifold Shield Stud (4 Req'd) 7 9430 Exhaust Manifold 8 9454 Exhaust Manifold Nut 9 9448 Exhaust Manifold Gasket 10 — Exhaust Manifold Stud (Fine Thread), Short (4 Req'd) 11 — Exhaust Manifold Stud, Long (1 Req'd) 12 — Exhaust Manifold Stud (Medium Thread), Short (1 Req'd) 13 6518 Valve Spring Retainer Key 14 6514 Valve Spring Retainer 15 6513 Valve Spring and Damper, Intake 16 6C515 Valve Tappet Guide Plate Retainer 17 6571 Valve Stem Seal 18 6513 Valve Spring, Exhaust 19 12405 Spark Plug 20 6269 Camshaft Thrust Plate 21 — Camshaft Thrust Plate Bolt (2 Req'd) 22 — Cup Plug 23 6B273 Camshaft Oil Flow Control Rod 24 6K292 Camshaft Front Seal 25 6256 Camshaft Sprocket 26 6278 Camshaft Sprocket Washer 27 6K252 Camshaft Sprocket Retaining Bolt 28 6L269 Camshaft Sprocket Key (5 x 18) 29 6250 Camshaft 30 6051 Head Gasket 31 6A008 Cylinder Head to Block Dowel 32 6010 Cylinder Block 33 6507 Intake Valve 34 6505 Exhaust Valve 35 6049 Cylinder Head 36 — Intake Manifold Stud (7 Req'd) 37 17A084 Engine Lifting Eye 38 — Engine Lifting Eye Bolt (2 Req'd) 39 9439 Intake Manifold Gasket 40 — Bolt 41 9723 Accelerator Cable Bracket 42 9424 Intake Manifold 43 — Intake Manifold Nut (7 Req'd) 44 9D476 EGR Valve Gasket 45 — Exhaust Gas Recirculation (EGR) Valve Bolt (2 Req'd) 46 9D475 EGR Valve 47 — Fuel Injection Supply Manifold Bolt
(2 Req'd) 48 9F593 Fuel Injector 49 9D930 Fuel Charging Wiring 50 6786 Oil Level Indicator Tube Bracket 51 — Oil Level Indicator Tube Bracket Bolt 52 6754 Oil Level Indicator Tube 53 6750 Oil Level Dipstick 54 9D280 Fuel Injection Supply Manifold 55 — Vacuum Fitting 56 9E498 Main Emission Vacuum Control Connector 57 — Vacuum Tap 58 — Vacuum Hose 59 9B989 Throttle Position Sensor 60 — Screw and Washer 61 9F782 Throttle Position Sensor Gasket 62 — Throttle Body Bolt (4 Req'd) 63 — Idle Air Control (IAC) Valve Bolt
(2 Req'd) 64 9F715 Idle Air Control Valve 65 9F670 Idle Air Control Gasket 66 9E926 Throttle Body 67 9E936 Throttle Body Gasket 68 — Vacuum Fitting 69 — Camshaft Position Sensor Screw 70 6B288 Camshaft Position Sensor 71 8255 Water Hose Connection Gasket 72 — Water Hose Connection Bolt (3 Req'd) 73 8592 Water Hose Connection 74 8575 Water Thermostat 75 6065 Cylinder Head Bolts 76 6500 Valve Tappet 77 6K512 Valve Tappet Guide Plate 78 6564 Rocker Arm 79 6A528 Rocker Arm Seat 80 6A527 Rocker Arm Bolt (8 Req'd) 81 — Ignition Coil Mounting Bracket Bolt
(3 Req'd) 82 18827 Noise Filter Condenser 83 — Ignition Coil Mounting Bolt (4 Req'd) 84 12259 Spark Plug Wire Set 85 12029 Ignition Coil 86 12043 Ignition Coil Mounting Bracket A — Tighten to 5-12 Nm (4-9 Lb-Ft) B — Tighten to 5-7 Nm (3-5 Lb-Ft) C — Tighten to 21-26 Nm (16-19 Lb-Ft) D — Tighten to 2-10 Nm (1.5-7 Lb-Ft) E — Tighten to 8-13 Nm (6-9 Lb-Ft) F — Tighten to 40-55 Nm (30-41 Lb-Ft) G — Tighten to 16-20 Nm (12-15 Lb-Ft) H — Tighten to 20-30 Nm (15-22 Lb-Ft) I — Tighten to 8-10 Nm (6-8 Lb-Ft) J — Tighten to 8-11 Nm (6-9 Lb-Ft) K — Tighten to 23-30 Nm (17-22 Lb-Ft) L — Tighten to 20-40 Nm (15-30 Lb-Ft) M — Tighten to 4.5-7 Nm (3-5 Lb-Ft) N — Tighten to 18-26 Nm (13-19 Lb-Ft)
Feb 24, 2009 | 1995 Ford Escort
Car Audio & Video Logo
73 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
