The copy is not clear on one side
The copy is not clear on the right side of the paper, it is faded. On the other part of the paper it is very clear. The machine is Gestetner 1302f Aficio. Thank you very much.
  • Natalia Villancio Feb 22, 2012
    Is the developing unit the place where you put the toner? If yes, then it is in good shape. Thanks. I haven't solve the problem yet.
    Problem Solver:
  • 14 Answers
Check Developing unit if all developing gears in good shape and the amount of developer presence could be lack of developer due to developer spilling.
Posted on Feb 20, 2012
  • 19 Answers
SOURCE: black lines on the paper
If its not fuser roller or cleaning blade problem, it could be a broken gear inside the Drum Unit.
Posted on Dec 24, 2008
  • 86 Answers
SOURCE: Gestetner 3218 Aficio 180 Fuctional Problem SC 543
Enter SP mode - Clear button (yellow key), 1 0 7 and hold and press stop button (orange key).
Enter SP5-810 (SC code reset) and select “1”.
Then hold down the “Photo mode” key and the enter key(hash) at the same time for at least 3 seconds (it is not necessary to turn the main switch off andon). If the machine beeps 5 times, the reset was successful. If it only beeps twice, the reset failed, and you need to repair the machine.
Possible causes are the fusing thermistor in the fuser unit, or the power supply unit defective.
Good luck and please rate me, thanks.
Posted on Jan 17, 2009
Cogz
  • 1326 Answers
SOURCE: RICOH Aficio 150 Paper Jam Reset
There is not a reset for jams in service mode. Did you open and close all the doors and make sure they are closed all the way. Most likely you still have a small piece of paper left some where in the paper path or you may have a broken sensor flag.
Posted on Jan 25, 2009
SOURCE: Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Posted on Feb 16, 2009
socalern
  • 48 Answers
SOURCE: gestetner 1302f error code sc541
SC541 relates to a heat up error.
Posted on Jan 16, 2010
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Ink smudge on right side of paper
Chances are high that the process of clearing the jam has resulted in ink being released from the cleaning/resting pad area based over on the right hand side (where the printhead sits when not in use).
This waste ink has probable come into contact with the rollers and other parts over on the right edge of the paper.
You'll probably see this ink slowly fade out and disappear over time. If it doesn't however there's something effectively feeding things so check the resting pad for a loose tube, overflow, puddles, etc...
If there's anything like that, report back (preferably with images).
Jul 21, 2013 | Epson Office Equipment & Supplies
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Trying to copy a letter size document. Print on right side of document starts fading at about 2" from right side of paper edge
Check the scanner glass for dirt, or debris from previous scans. Smoke on mirrors, dust all contribute. Dont use canned air.
Nov 18, 2010 | Lexmark P6250 All-In-One InkJet Photo...
It will copy but the it will light and faded. Hard to read.
Too much moisture in the paper will cause blotchy, light and faded print. Run the copy through a second time on the reverse side. If the second side is good you have a paper moisture problem. (Usually happens in non-airconditioned spaces during humid periods if the paper has been stored in the open.) Hope this helps.
Sep 08, 2010 | Sharp AL 1631 Copier
Hi my printer jammed at the beginning feed, and eventhough I cleared the paper, now each time I try to print the same jam happens. Anything I can try other than bringing it to a service center ?
Carefully inspect the paper path and find what stops the paper from moving. Sometimes there is a piece of paper, paperclip or staple stuck in the paper up turn. Usually the paper is wrinkled on that place after removal.
Try manual feed (yes, there is manual feed tray behind that narrow long door in front between the paper tray and the toner access door)
Clean the pickup roller. If it's worn out, try to remove it (there are plastic latches that hold it on place) and turn the rubber part in a way that non worn area covers the protruding part.
Aug 01, 2010 | HP LaserJet 1320n Printer
Canon ir3320 problem is a 2 side copy command after 1 side print ok 2nd side pcopy is a lite
If one side looks great and the second side is faded try loading fresh paper in the copier. Sounds like there is moisture in your paper. It dries out after going thru the fuser section on the first pass so on the second side the paper is dry and the copy will look alot better.
May 11, 2010 | Canon imageRUNNER C3200 Copier
Samsung 1640 printing problem
A number of things! First did you ever clean out the paper path? Run out and buy paper path cleaner and run it 10 times. Try printing again and see if it corrects the problem. If it still acts like that, then you would need to change out the toner (if supected of defects or if empty) or change out the led inside the printer which you would need a repair manual to disngage and replace it.
Mar 05, 2010 | Samsung CLP 315 Laser Printer
Poor, faded print quality on left and right sides of paper
Have you check the teflon at the heater? have you clean the reflector of laser? Try that.
May 30, 2009 | HP LaserJet 8550 Printer
HELLO PRINTING FADES RIGHT HAND SIDE OF DOC ANY ADVICE ,THANKS IN
Hello I have sorted the growling sound out with a shot of WD40 lube ,but have not sorted out wht the cyan does not print clearly any advice would be helpfull
Nov 14, 2008 | Epson AcuLaser C900 Printer
57 people viewed this question
jasbo
jasbo
