Question about Tablets & eReaders
My VIZIO Tablet 1008 micro USB charging port is looseand charging indicator comes on some times when I move the wires around. ow do I get to charge the Vtab?
Even the SB charging does not work. The problem is in the port which is loose or not working
    New Friend:
Hi, you can buy new ones from here 2 pcs Replacement Micro USB Charging Port Connector for Vizio Tablet... and change it . take a look. enjoy
Posted on Nov 23, 2014
I had the same problem with my vizio tablet. The port came loose after the wife and kids kept playing with it. The tablet would not charge anymore. What I had to do was open the tablet and check if the little pins that connect the Micro USB port were still soldered on the circuit board. Mine were broken off so I had to replace the whole port. I couldnt even find the OEM replacement part so I had to buy a Mico USB (style B) port off ebay and made it work.
Posted on Jul 03, 2012
  • Measuray Franklin
    Measuray Franklin Mar 30, 2013
    Kevin, once you replaced the Vizio charging port witih a different 5 pin, type b did this work and is it continuing to work for you today? Also where did you purchase the micro usb type b port from?
  • Measuray Franklin
    Addendum which type of charging port did you use and how did you modify it to work with Vizio tablet?
SOURCE: Power port on le1600 does not charge batteries.
We contacted Motion about an issue with our docking station because our power & USB ports stopped working, or worked only intermittently. We were instructed to remove the front cover from the docking station to check the connection of the cables. We found that the cable had completely disconnected (it had evidently pulled loose from tilting the dock up and down). Once the cable was reattached, and the cover reassembled, viola! Success!
Posted on Nov 23, 2009
  • 5 Answers
SOURCE: Gateway M1300 tablet pc will not charge in the
Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
online shopping
Posted on Mar 08, 2012
  • 909 Answers
SOURCE: USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
Posted on May 28, 2009
  • 24 Answers
SOURCE: TC1000 Stopped working
Whatever happened? Fixed? still not up? Trashed?
Posted on Apr 05, 2008
SOURCE: Battery won't charge
Find a computer/electronics tech to solder the leads to the jack back on. I had to do that too. You just need to be careful if you, or they take it apart b/c the cable and leads are very delicate. I got it working and thought I missed something only to rip the video card out and need to buy a new motherboard on ebay, which is another idea for ya.
Posted on Sep 30, 2010
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
Why want my tablet charge Where do I return my tablet it will not charge anymore
Most common cause of this is faulty charger, the metal connector at end of wire won't connect properly to device charging port.
Test it by putting plug back in Tablet charger port and very very gently wiggle it around very slowly, see if the charging light comes on or flickers. They usually make a beeping noise when successfully charging or the screen lights up. If you get intermittent charging then it's the charger and time to get a new one. Very common, most are USB connectors or small pin types.
If it's still under warranty then send it back to the place you bought it before you try testing it.
Oct 07, 2016 | Tablets & eReaders
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
The charger wont go in to the port to charge it and the tablet needs to be charged it was working just fine last night dont know if my son did something or not
Robin, the charge ports can be changed at a computer or cell phone repair facility. Check the attached links,instruction and guides, Good luck
How to replace the fixed charging port
How to Fix Tablet Charger Port
Amazon com 2 pcs Replacement Micro USB Charging Port Connector for Vizio...
Apr 24, 2016 | Tablets & eReaders
Is it ok to charge my RCA tablet pc w/a micro mini USB?
if the micro mini usb port fits the tablet ---yes as that is the cable used to charge it with
Dec 21, 2015 | Tablets & eReaders
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
Aug 04, 2014 | Tablets & eReaders
We need a plug
The charging on the tablet depends on the model.
Most including the Kocaso 776 charge via the micro USB port, and this is a standard USB port.
So all you do is purchase a micro USB to standard USB cable and plug it into the standard USB port on the charger or a PC.
Feb 07, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
Kindle isnt charging
Yes it will :)
If you are using a USB port on a PC or Laptop think of trying a different USB port - sometimes they put out low power;
If your laptop or PC is more than 3 years old it probably can not put out enough power on the USB to charge a tablet (any tablet).
Check to see if any of your existing wall adaptors for (say) your phones have the same micro USB connection - use it to charge your Kindle - it's totally fine.
Go to any shop in the high street and buy a Micro USB wall adaptor, they start at about 5gbp. You can get them on Amazon too.
Remember it takes about 6 hours to charge from the wall and 16 hours (yes, 16) to charge from a computer usb.
Good luck
Feb 01, 2014 | Amazon Kindle Fire HD
Tablets & eReaders Logo
3,144 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
