Question about Acer Aspire™ T180 PC Desktop
How to open desktop to add memory
I have an acer AST180-350b desktop which comes with 512MB memory -- i bought (2) 1GB DDR2 memory -- but could not open the desktop even after removing all the screws in the back of the computer -- how do i take away the case so that i can install the memory chips?
  • avmeno Oct 27, 2008
    i tried -- no luck -- seems to me i have to do somethng more -- look forward to suggestions
  • bobsp100 Oct 27, 2008
    I tried to remove the cover on my Acer Aspire T180, without success. There is, what appears to be, a sort of "handle" at the back, but I could not budge the cover. I tried very diligently (and somewhat gently, to avoid damage), but no luck. I tried prying with a screwdriver. I tried pressing and pushing at various points on the cover. The cover acted as if I had not removed all the screws...I found 4 silver-colored and 2 larger black screws, and removed them all. There must be a trick to removal of the cover, but my manual (user's guide) does not mention removal of the cover. I have searched on line for a more detailed manual, with no success. I have removed covers on many computers, some easy, some difficult, but always with success, until now.
  • 152 Answers
If you have removed all the screws, it may be that you just need to slide the cover backwards to release the locking flaps. Try pushing the cover in several directions to see if it disengages something.
Posted on Oct 27, 2008
Upgrade ram
In order to upgrade the ram of your desktop. First you have to check the ram specifications. If wrong specifications the desktop will not work. To check you have to remove the ram from your desktop by removing the screws behind your desktop. Open the lid and you will see the contents of your desktop. Besides of your processor, there is ram installed. Unclip it. Then bring that ram to the computer shops. Purchase a ram higher than the ram installed in your desktop. Afterwards, install the new ram to your desktop. Good luck.
Sep 13, 2010 | Acer Aspire T690 (AST690UP820A) PC...
ACER Aspire AX1200-U1510A: What mother board and socket is in this computer? AM2, AM2+, or AM3
you have given the memory chip number and not the computer model the chips you have are 533 MHZ DDR so I would suggest you click on start go to my computer right click on properties and it will list the chip set. here is a web page you can go to to see the memory you have.
Feb 11, 2010 | Acer Computers & Internet
Does the acer aspire 5315 2077 require a certain type of memory?
Go to and click on the scan my system button to see what configuration of Memory Modules are installed on your laptop.
Here are some other details:
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Chipset: Intel 960GML
Drive Form Factor: 2.5"
Drive Interface: SATA
Maximum Memory: 2048MB
Slots: 2 (2 banks of 1)
Standard Memory: 512MB removable
USB Support: 2.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR2 memory with support for DDR2 PC2-5300 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: Yes.
Jan 14, 2010 | Acer Aspire 5315 Notebook
Whatis the maximum memory the medion rim2520 pc
Standard Memory : 512MB or 1GB Maximum Memory : 2GB ( 2 x 1GB) Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM
Oct 08, 2009 | Computers & Internet
Need to add Ram memory
This is really easy on this model of acer laptop
  • unplug the power adapter and remove the battery from the laptop
1. Remove the two screws fastening the RAM cover.
2. Detach the RAM cover from the main unit.
3. Pop out the memorys and remove the memorys from the memory sockets.
Let me know if you need anything else.
Feb 17, 2009 | Acer Aspire 3680 Laptop
Memory Upgrade
I believe the max you can go with per slot is 1gb.
This is copied from the Acer site:
Up to 4 GB of DDR2 533/667/800 MHz SDRAM
Jan 31, 2009 | Acer Aspire™ T180 PC Desktop
P4M800P7MB RS2H Foxconn motherboard and 2G memory upgrade
the 1gb memory modules need to be low-density ie chips on both sides. the motherboard can only recognise 512mb on each side of the memory module.
Jun 01, 2008 | Computers & Internet
Acer Aspire T-180 Memory Upgrade question
Hello, You might be able to add 2GB more. 1GB per slot. You need to get the model # off your motherboard and verify what the maximum amount of memory it will support. 1GB per slot would be 4GB total but some Operating systems will only support 3GB. So some might be wasted if that is the case. You would need to use the same memory type. So if existing is PC2-4300, use the same. Hope this helps.
Mar 05, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
211 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
