Question about KitchenAid 24 in. KUDI02CRBS stainless Steel Built-in Dishwasher
Reset sequence for kitchenaid dishwasher
I need to reset the dishwasher. and if possible find out the problem codes.
How do you reset a KitchenAid dishwasher model: KUDE70FXSS4?
Press High Temp Scrub and Dry Heat option buttons in quick succession one after the other for about 6 sec until all the lights come on. Then press Cancel button. This should reset the dishwasher. Press equivalent buttons on the panel if the actual ones above are not there.
Make sure the dishwasher detergent dispenser lid is shut and the dishwasher door is shut before you start the above reset sequence.
Jan 02, 2013 | KitchenAid Dishwashers
CLEAN LIGHT BLINKS 7 TIMES ON KITCHEAID KUDP DISH WASHER
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Aug 08, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light blinks 7 times, pauses, then blinks 7 etc.?
Kevin
Jul 25, 2011 | KitchenAid 24 in. KUDP01IL - Multiple...
My dishwasher needs to be reset. What is the button sequence for this?
see procedure for clearing flashing clean light. it appears to reset everything.
May 17, 2011 | KitchenAid 24 in. KUDP01FL Built-in...
Dishwasher clean light will not stop flashing preventing further input and dishwashing
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Dec 14, 2010 | KitchenAid KUDR24SE Built-in Dishwasher
Clean light blinks 7 times and will not start it is a STATUS KITCHENAID
Kevin
Dec 10, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Kitchenaid dishwasher mdl: kud101t jbt0
try the reset button sequence.. described in that other post about the clean light blinking.. that will reset the whole machine..
tpug
Jul 07, 2008 | KitchenAid 24 in. KUDI01FL - Multiple...
Clean Light Flashes
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Oct 07, 2006 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDI02CRBS stainless Steel Built-in Dishwasher Logo
189 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
