Question about Frigidaire Washing Machines
Frgidaire washer leaks when spinning - Frigidaire Washing Machines
2 Suggested Answers
  • 1531 Answers
SOURCE: washer will spin while in rinse mode, but does not
this could be a main control board problem.how ever i would check the drain pump for any kind of foregin object that may be causing the drain but to stop functioning.last resort bad drain pump
Posted on Sep 17, 2009
I have a fridgidaire gallery dishwasher. It doesn't shut off at the end of the cycle, pump sounds like it's running and the bottom spray arm doesn't spin when in a cleaning mode. It spins freely when the...
Is there water in it ? Frgidaire as all end with the drain pump running about 5 min give or take. If the pump is continuing to run and not stopping at the end of the cycle , could be a timer or control issue. Most all functions are timed for a specific amount of time.
Oct 30, 2013 | Frigidaire Dishwashers
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frgidaire Gallery series front loader washing machine. It just started pausing itself mid cycle. I have to keep checking on it and repress the start button. It doesn't seem to be spinning...
I have the same problem ,, and i called frigidair and they didnt seem to care my unit is only a year old ,, im so furious right now ,, now i was looking on the recall list and the water pumps are on the recall list on selected models i know with mine it will stop then pause and not drain the water out ,, maybe some can help us out :)
Sep 06, 2011 | Frigidaire ATF6000ES Front Load Washer
I need a wiring diagram for a frgidaire washing machine
The wiring diagram in inside the the washers backsplash, just take the backsplash apart and it will be in a small envelope
Dec 21, 2010 | Frigidaire FWS833A Top Load Washer
I have an Affinity Frgidair front loader Model # ATF 7000EGO my washing will not spin i have repalced the pump but it still will not sipn i could hear the water pumping out but when it gets down to about 5...
More than like ly it is the door lock. This can be removed and replaced easily by removing the top of the machine (2 screws on the back), then take out the 2 screws that hold the lock in place from the front of the machine. You willl have to reach in from the top to hold the lock while unscrewing it and then unplug it. Reverse these steps to install the new door switch. The dorr switch can be found for around 40 - 50 bucks. Please make sure the machine is unplugged prior to taking the top off to prevent shock.
Dec 18, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer will spin while in rinse mode, but does not
Sep 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Wash machine won't spin.
If you want you can jump the switch out by taking the wires off the switch and put electrical tape around them together really tight and see if that works if so its your switch thats bad
Aug 24, 2009 | Frigidaire GLTF2940F Front Load Washer
LEAKY NON SPIN WASHER
sounds like you have a couple of problems, but the leaking is something you need to see where it's leaking from. as to the not spinning, it sounds like the transmission is bad
Dec 09, 2008 | Kenmore 23822 Top Load Washer
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Aug 04, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
15 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
