Question about Spinmaster Spin Master Air Hogs Vectron Wave
My vectron wave does not lift off the ground even after fully charged. Could any dirt caught up in the propeller give this problem??
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 28 Answers
Did you drop it and its now it takes more enengy to get lift sosee it freely spins or things wore so much not built to last bearing gone or should have been there your describing a toy i guess i never seen one motor may have seen water some or some problem but fresh batterys andget it as instructions state for that itemhave good day can you order new parts sounds interesting is it expensive can you get parts for it who makes it order and replace enuff parts you did it and rebuilt it and get to seehow it applies to a other things that need fixed and to be made better like should have had bearing there instead stuck in plastic so learn these things and thats what happens the trade offs and you have one
Posted on Feb 20, 2012
Testimonial: "thx"
  • tcochranrd2industrypa Mar 06, 2012
    download pdfs on your subject go to its website learn more to be set up to read pdfs you download a program to do this from a place like cnet for good deal parts list and get it fixed does it matter what it is
Self propell not working right
Leave aside all the puffery about 3-1 and such, you described a front wheel drive (pull) walk-behind (FWD), but are asking why the rear wheels won't propel. When you push down the hand grip the front wheels should spin free. Whan you lower from wheels by releasing pressure on hand grips, turning wheels lowered to ground should propel the mower along with its unpowered rear wheels now turning be ground contact. Reminder, never, ever lift rear drive wheels of any mower off the ground while walking behind with engine running:
  1. You could be struck by blade propelled object.
  2. You could pull mower and spinning blade backward onto your feet.
  3. You could lose balance and be pulled forward in a fall.
Contemporary FWD mowers are recognized by a black chain housing on deck top leading from engine to left front of deck. RWD propelling chains are situated underneath deck so cannot be seen from above.
Jun 25, 2014 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Razor mx350
Have you tried removing plastic chain guard and making sure chain is not off track i had this problem and that is all it was.
Apr 24, 2014 | Razor MX350 DIRT ROCKET - BLUE
Spinning
It's not fully charged. Try putting in brand new batteries and fully charge before trying again
Jan 05, 2014 | Brookstone Remote Control Helicopter -...
Will not fly lift . Seem to run well but will not lift off the ground
The batteries on the Helicopter need to be fully charged to take off.
And important: to recharge the helicopter fully it needs really good base unit batteries.
I find all this a waste so - I used a wall power supply to supply suitable power to the charging bases of these helicopters give more consistant results than using batteries.. Just make sure you are using a 9V DC wall transformer (6 1.5v batteries = 9v) and that the polarity is correct.
manual is here
http://www.brookstone.com/webassets/pdf/651307p_manual.pdf
Dec 18, 2013 | Brookstone uControl Cloud Force RC...
2005 Honda NF 100 Wave not charging
Hi, Wilson before testing any electrical component in the Charging System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead-acid batteries.
1. To check the regulator unplug it from the stator. Take a test light and clip it to the negative terminal of the battery and then touch first one pin and then the other on the plug that goes to the regulator. If you get even the slightest amount of light from the test light the regulator is toast.
To do this with a meter: black lead to battery ground, red lead to each pin on the plug, start with the voltage scale higher than 12vdc and move voltage scale down in steps for each pin. Any voltage is a bad regulator.
2. On the other part of the disconnected regulator plug. Set the multimeter for Ohms x1 scale and measure for resistance across the pins of the stator. You should read something around 0.1 to 0.2 ohms for a 32 amp system.
3. Then check for continuity between each pin on the plug and frame/engine ground. The meter needle should not move (infinite resistance)(digitals will show infinite resistance) if the meter needle does move (indicating continuity)(digitals will show some resistance), recheck very carefully. If the meter still shows continuity to ground the stator is shorted (bad).
4. Set the meter to read A/C volts higher than 30 volts (the scale setting for voltage should always be higher than the highest voltage you expect or you may fry the meter). Start the bike, and measure from one pin to the other on the plug (DO NOT cross the multimeter probes! - touch them to each other). You should read roughly 16-20 vac per 1,000 rpm.
5. If the battery was good under load test, if the stator is NOT shorted to ground, and the stator is putting out A/C voltage, then the regulator is bad (most likely even if passed step 2)
For more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
https://www.scribd.com/doc/270754675/Stator-Mod-Floating-Ground-Honda-Wave100-XRM110
Honda Wave 100 Running Problems
http://www.banyalex.com/honda-wave-100-service-manual.pdf
https://www.partsfish.com/page/oem-parts-for-honda
Honda Wave 110i User Manual
Jan 16, 2013 | 2005 Honda NF 100 Wave
Vectron wave toy doesn't charge
2Hz is probably the ripple current from the charger.
Apr 14, 2017 | Spinmaster Spin Master Air Hogs Vectron...
My lawn mower starts and cuts fine, but it will no longer self propel even though the wheels actually turn when I lift the rear wheels off the ground.
Have you checked the belt? There is a belt that runs from the shaft to the transmission that gets worn and streched out. It will spin the tires, but not under a load. I'm sure thats the problem! The cover is usually located under the deck.
Sep 09, 2011 | Troy Bilt 5.5hp Self Propelled Mower
What to do when your vectron wave is blinking red and green at the same time while charging.
When you attach the charger the wrong way round it will flash red and green. Turn it around and it will just flash red. Then when charged it will go orange.
Dec 12, 2010 | Master Heaters Air Hogs Orange Vectron...
Yiboo UJ4708 will not lift even after being fully charged. It will just hover an inch off the ground. It doesn't sound right to me either when its running.
i had the same problem.. one of the gears isn't fully engaged.. if you look at the internal mechanism, you'll see two small gears on opposite sides, each engages a larger gear... during impact, these gears can slide and become not fully engaged. That is the strange sound you are hearing. this also prevents the propellers from spinning up fast enough to get fully off the ground. I used a small jewelers screwdriver to reach in and push the problem gear back into place.
Sep 28, 2010 | RC Remote Control Helicopter Ready To Fly
Spinmaster Spin Master Air Hogs Vectron Wave Logo
430 people viewed this question
Top Spinmaster Toys Experts
ray gallant
Are you a Spinmaster Toy Expert? Answer questions, earn points and help others
