Question about Tools & Hardware - Others
WIRING SCHEMATICS VICTOR 1640 LATHE
NEED INFO ON LIMIT SWITCHES
4 Suggested Answers
  • 518 Answers
SOURCE: victor lathe 1860 dcl
may be heavy load is drawing exess currant
Posted on Jul 07, 2010
emissionwiz
  • 76846 Answers
SOURCE: i need to purchase a wiring schematics for a mori seli tl3-b cnc lathe
I'm sorry but I believe you have this posted in the wrong product category? Please re-post the question in the proper category if this is the case, otherwise you have my apologies. This is the car and truck problem category
Posted on Jul 09, 2012
Need the schematic diagram for a Db drive A8 1750.1d
Victor, unable to locate schematic, links below are a manual with trouble shooting and db's web site to get customer support.
press the helpful button and follow me on fixya for more tips and info
http://dbdrive.net/wp-content/uploads/2013/09/A8-Amplifier-Manual-1_21_13.pdf
http://dbdrive.net/
Feb 14, 2016 | DB Drive Car Audio & Video
Protect lathe when reversing.
I don't have much knowledge on lathe. Check this thread I found on google. Hope that helps.
Jun 01, 2013 | Jet JML-1014VSI: 10" x 14" Variable Speed...
Rotor disc does not traverse
if it is an electrical problem,
check limit switch
Nov 06, 2012 | Ammco Combination Disc/Drum Brake Lathe
I need to purchase a wiring schematics for a mori seli tl3-b cnc lathe
Jul 09, 2012 | Cars & Trucks
I have a Drill press 16 Speed, Model BT1001A and the On/Off Switch and light switch has all been removed. How do they go back on the switch and the sequence? How do I get access online to the schematic...
This is a difficult question. There are Euro, American and Chinese motors used, the most common is the chinese one phase motor at 110 volts. This is again complicated by the fact the chinese changed the hookups between 1999 and present models. In 1999 the Grizzly type clones from China had a six screw terminal block with the supply wires being: BLUE, BROWN, BROWN, BLACK, GREEN/YELLOW. with U1=BLUE, V1=BRN, Z1=nil, Z2=BRN, U2=BLK, V2=nil and you could reverse the direction of rotation by reversing the two brown wires on V1 and Z2. The new chineese wiring has made some changes to this and can be viewed on the details of any eBay site selling new Grizzly metal lathes of the 12X36 size of which they make about 9 varieties, keep reviewing each one, there are about two ads that give actual pictures of the new terminal blocks they use which have two flat bar jumpers right in the block and they use different terminals within the six on the motor.
My example is for a 1999 Chineese electric motor for the AT-400 Lathe/Drill/Mill which uses a generic
WANNAN 1 phase electric motor 3/4 HP, 1700 rpm, 11.0 Amps, 110 Volts, Date 99/7
American and Euro wiring tends to have other colors like white, orange, etc. and up to twelve of them so you have to research the exact motor, where it was made, and what date to get the right info. then you have to draw diagrams to match your switch wire hookup to the plate which is on the motor just beside the terminal block. Mine had two reversing switches and two motors plus another switch which selected between power to the mill or power to the lathe. Using the above color codes it worked right the first time only because I researched and then charted out every wire and did continuity testing to ensure functionality without worn-through or loose contacts. Also, unplug the machine and leave unplugged overnight before touching the wires as the capacitors carry a big charge at high voltage and hold it a long time.
Mar 24, 2011 | Clarke Power Products Clarke 16-Speed...
Victor lathe 1860 dcl
Jun 21, 2010 | Victor 16" Swg 40" Cc 1640b Engine Lathe...
Need schematic for carrier furnace/ac. A butcher
There should be a schematic inside where the blower is or in the main elec. panel on unit
Oct 02, 2009 | Heating & Cooling
I need the schematic diagram for an antique radio RCA VICTOR model A25 made in Montreal circa 1941
I wasn't able to find information for the A25 specifically, however, there are a LOT of antique RCA Victor (US and Canadian) schematics here:
http://www.nostalgiaair.org/Resources/
Do you have any more details about the radio? An alternate model number perhaps?
Please rate this answer if helpful.
Apr 19, 2009 | RCA Audio Players & Recorders
Kenmore mod. 59672822200 ice
you should at least have power to ice maker. be sure to check while depressing the light switch assy. some ice amkers are wired through door light switch.after that there should be awire guid. tech sheet under the kickplate to guide you along if needed
Mar 13, 2008 | Refrigerators
Tools & Hardware - Others Logo
69 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
