Question about DeLonghi DUH400 Heater
Heater light turns on but nothing else is working
The heater quit working yesterday. i unplugged it for 12 hrs. plugged it back in and turned it on. the on light glows but nothing else is working. what could be the problems? the fan is clean.
  • redheadedfai
    redheadedfai Feb 20, 2012
    also, when i turned it on yesterday, i had to tap the front by the controls before it statred running. it ran for about 40 min. before it quit.
The power wire leading to the heating element could be broken or burned out or the wire to the fan [ if equipped with one ] could be broken
Posted on Feb 20, 2012
Rinnai RC98i Error 12 - Flame Failure
IF THIS UNIT HAS SPARK IGNITION THE IGNITORS ARE PROBABLY OUT OF ADJUSTMENT WHICH IS LIKE HAVING TO WIDE OF A GAP ON A SPARK PLUG . IF YOU MAKE GAP OF IGNITOR ELECTRODES APPROXIMATELY 1/8TH OF AN INCH APART IT SHOULD LIGHT AS LONG AS YOU ARE GETTING VOLTAGE FROM IGNITION COIL. CALL A SERVICE TECH
Dec 22, 2013 | Rinnai RC98i Tankless Water Heater 9.8 GPM...
Have General Electric standup freezer; model # FUF2DMARWH. Left door open a tad, over night. Unplugged it in morning for 10 min., then plugged it in and it seemed to be working as the temp. dropped...
turn off freezer and remove freezer panel at bottom in back. if evap.coil full of ice then defrost all ice. if no ice build-up then compressor may need new relay.
Aug 29, 2013 | General Electric Refrigerators
Sidebyside kenmore works great for 12 hr. then seems to go into defrost mode and won't cool unless i unplug for 6 to 8 hrs plug it back in and it works fine for 24 hrs then repeats
Larry I tried to write the solution here but it would not send. Click Here=> Kenmore Appliance Model Number Locator and examples Your solution is at top and center of that web page. Let me know if helpful or if you have more questions, Thank You, Sea Breeze
Nov 16, 2011 | Refrigerators
I have a Linksys E1000 wireless router. It has been working fine. The power cord it is on was unplugged briefly last night. Now when I plug it back in, all the blue lights are flashing and I can't get...
have you tryed turning off computer, router, and modem if you have one. then unplug all connections from router (phone line, ethernet net cable and power cord). Then wait 2 min then plug all back in, and turn on modem, router, then computer. We lost power yesterday for 3 hrs and I needed to actually turn in all off and unplug power cords then turn it all back on to rest and reboot them to get them working properly. Hope it helps.
Sep 25, 2011 | Cisco Linksys E1000 WirelessN Broadband...
My HK AVR 135 wont turn on. The orange light comes on but when i try to turn it on it does nothing. It has done this before and i ust unplugged it and plugged it back in and it turned on for a brief period...
Try unpluging the unit for atleast 2 hrs. The capacitors bleed off energy very slow, thats why it needs to be unpluged for a couple hrs. If that doesnt work it usually means the powersupply is going out.
Mar 30, 2011 | Harman Kardon AVR 135 Receiver
AKAI LCT3201AD
Find and replace the following caps, Ec18, 19, 20 / 1000uf/16v,
Ec9, 10 / 1000uf/35v, Ec14, 25 / 470uf/35v should resolve the problem. You can get the caps at almost any electronics supply.
This is a common problem in this unit.
Good Luck!
Happy Thanksgiving!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 27, 2008 | Akai LCT2715 27 in. LCD Television
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Plugged in, worked, turn on later, did not work
First thing i would do would be to check convergance amp ics
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 01, 2008 | Toshiba 55H70 55" Rear Projection...
DeLonghi DUH400 Heater Logo
322 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
