Question about Maxent MX-42HPM20 42 in. Plasma HDTV
TV is blinking like th tube is going out
Once the tv is on it will start binking. Once it warms up it will continue to blink until I turn it off. Should I replace the TV??
  • Maxent Master
  • 1,205 Answers
Morning to you
Have you looked in the troubleshooting pages in the manual?
I suspect that plasma TVs do not have tubes, but there is no reason for tv not show thesame behaviour, but for different reasons.
Look for the scart cables and make sure that they are where they sould be. If this does not work it is the plasma TV doctor who has to take a look.
all the best
Kolbrun
Posted on Feb 20, 2012
Can't find the manufacturer's code for TV
To search for a code for your TV:
  1. Turn on your TV.
  2. On the remote control, press TV once; it blinks once. Then press and hold SET UP until the TV key blinks twice.
  3. Enter 9 9 1. The TV key blinks twice.
  4. Press 1 (the device code digit for your TV). The TV key blinks twice. Aim the remote control at the TV and press POWER once.
  5. Press and release the CH+ key continuously, then stop when the TV turns off.
NOTE: In the searchmode, the remote control sends IR codes from its library to the selected device, starting with the most popular code first.
  1. Press POWER. The TVshould turn on, then press SET UP to lock in the code.
NOTE: If the TV does not turn on during step 6, then slowly press and release CH- to go back through the codes, then press SET UP when the TV turns on.
Apr 15, 2014 | Televison & Video
Code For Charter Remote
Charter has a web site tat list the codes. Bit hard to find the url so you might call support
Feb 09, 2014 | Proscan 32LB30H LCD TV
How do i link my radio shack gamer-pro remote to my dynex
1. Turn on the device (for example, DVD player) and, if needed, load media (for example, DVD).
2. On the remote, press a device key (that is, VCR/DVD, CBL/SAT, or TV). 3. Press and hold P until the red LED blinks twice, then release.4. Enter the first four-digit code for your device.
The LED blinks once as each digit is entered. If the code is correct, the LED blinks twice.
NOTE: If the LED does not blink twice, repeat steps 2 to 4 and try entering the code again.
5. Aim the remote at the device and press Power (or Play, if it does not have a Power key). The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works.6. Repeat steps 1 to 5 for each device you want to control. For future reference, write down each working device code in a safe place.Code search Method
1. Press TV once.
2. Press and hold P until the red LED blinks twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The remote sends IR codes from its library to the selected device, starting with the most popular code first.
5. If the TV responds, go to step 6. If the TV does not respond, press CH+. The remote will try the next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED blinks twice.
7. To search for other device codes, repeat steps 1 to 6, substituting the appropriate key for the device.
Oct 03, 2011 | Dynex DX-L19-10A LCD TV
I have a HDTV 1080 and the power to our neighborhood went out over the night and now the green light on the TV just blinks. I can't get the TV to turn on. I have reset the system reset button on the from...
try this ... if there is a reset button on your 'front' control panel..maybe 2 - 3 positions to the left of your blinking timer light..
try inserting the tip of a mechanical pencil or tip of a straighten paperclip into the 'tiny hole' of th ereset button ...hold pressure on that button until yout blinking light starts blinking RAPIDLY .. this
rapid blinking should continue for several seconds or a minute.
then it should stop .. may even go off ... now ..hopefully.. you will be able to turn your set on
Aug 20, 2010 | Mitsubishi Televison & Video
Need the code for the charter remote for my vizio
For example, to search for a code for your TV:
  1. Turn on your TV.
NOTE: In the searchmode, the remote control sends IR codes fromits library to the selected device, starting with the most popular code first.
Jan 12, 2010 | Vizio VO47L 47 in. LCD TV
JVC TV crisis.....HELP
yes... i actually work at verizon the tv is to old for fios because fios is so advanced we run off ot 720 to 1080 depending on areas. what kind of box is it? is it the hd box or stb>
Feb 13, 2008 | JVC AV-32230 32" TV
Picture Blinking
9 times out of ten restoration is temporary,at best.....
Requires socket adapter for your tube or use universal
adapter...tricky hook-up = read instruction book for CR-70
...........................T.
Dec 18, 2007 | Sony KV-32S20 32" TV
Tv Keeps Blinking
If still under warranty or if you have no electronic repair experience you should take the set back to the shop or to a repair person. Some of the solutions described below can be dangerous, TV's are very hazardous to service. Even when plugged out, TV's can store very high voltages. In some other brands/models the tubes have problems over heating and cracking. This would give you the same symptoms. If this is indeed your problem you will have to replace all 3 tubes, since leaving some to be stronger than others will still result in blinking. Can be very expensive, up to a 1000 $. Good luck
Jun 06, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
Maxent MX-42HPM20 42 in. Plasma HDTV Logo
81 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
