Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Fridgedaire side by side fan working, compressor hot, refridgerator and freezer not cooling
Fridgedaire side by side fan working, compressor hot, fridge and freezer not cooling, when compressor tested with unit off checked for open windings by ohms found resistnce leg to leg, do we need a new compressor?
  • 1 more comment
  • jeansto Oct 27, 2008
    oops it is a 2001 kenmore - is there any way we can check the relay/compassitor coil? we are getting 115 volts for only 10 seconds and then it goes to zero - thanks for the quick reply & the help my husband does refrigeration for printing press's
  • barbdennis08 Mar 09, 2009
    I need help installing my ice maker & water dispenser?
  • Anonymous Mar 23, 2014
    PTC resistance too high?
  • 943 Answers
.thanks for your question i would try a hard, to start re lay on it after its cooled down. it might just do the trick. the appliance doc
Posted on Oct 30, 2008
    President:
  • Kenmore Master
  • 2,651 Answers
Def sounds like a compressor issue/ sealed system issue, hopefully under 5 years old and you still have coverage
Posted on Oct 27, 2008
  • Ron Coons
    Ron Coons Oct 27, 2008
    you can look your model number up at the sears. com sight and look for the overload/relay assy, try that. sure beats replacing a compressor
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
2002northland 36" refridgerator and freezer not
The compressor should turn on after it cools. It shuts down if it overheats to prevent damage/fire. The compressor itself could be bad but more than likely the fan is dead.
Jan 11, 2011 | Northland 36SSS Side by Side Refrigerator
GE refridgerator won't cool
First of all check and see if the compressor is running and if not is it very hot to the touch. If the compressor is not running but hot then the compressor is either locked up or is cycling on its internal thermal overload. If this is the case then either the condenser fan motor is not running and/or the condenser coil is very dirty. If the condenser coil is dirty you need to blow it out with compressed air(watch out for all the blowing dust). If the compressor has been cycling alot on its internal thermal it will eventually lock up permanently and you will need a new compressor. I hope I was of some assistance to you!
Nov 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator side not cooling
The fresh food section is cooled by the freezer section by forced air supplied by a fan. If you have air flow, check the temp inside the freezer. It should be between 0 and -10. If not look inside your freezer and see if you have ice built up on the back panel. If so you have a defrost problem that is most likely a bad defrost heater, a bad termination thermostat or timer. If ther is no ice then check your fan under the refrig. If you can hear the compressor running it should be turning. If this all checks out then you have a freon system problem like. Low Freon pressure or a restriction.
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Hot high side assembly and at the front door section
Replaced the GE fan motor which seems to have solved the problem.
Dec 28, 2008 | Kenmore Refrigerators
Frig is warming while freezer is staying cold.
No, A compressor will get hot for about three reasons.
Low refridgerant.
Lack of airflow, (maybe due to very dirty coils or bad condensor coil fan on modes with a fan)
Or high amp draw. (which would mean you have a bad compressor)
Its more common to be one of the first two, especially low refridgerant.
Dec 05, 2008 | Refrigerators
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Jun 20, 2008 | Maytag MSD2651 HE Side by Side...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
366 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
