Question about Sanyo Cameras
Sanyo e1292 lens error 0x02210020 - Sanyo Cameras
  • 11967 Answers
SOURCE: I bought a brand new sanyo e1292 camera and cant
Well, have you tried formatting the card in the camera? This will erase it so download any pictures first using a card reader if necessary.
Posted on Feb 24, 2010
  • 11967 Answers
SOURCE: lens error 0x03110000 in sanyo vpc e1292
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
duane_wong
  • 6826 Answers
SOURCE: My sanyou vpc-e1292 camera says lens error then it
Usually this means that the motor is binding for the lens focusing in and out distance wise. This symptom can be caused by physically blocking the lense from focusing in and out with a finger or hand.
It could be due to a lack of lubrication or binding of the lens focusing gear.
A webpage describing how to contact sanyo service centers follows:
http://us.sanyo.com/Customer-Support-Service-Center-Locator
Posted on Jul 26, 2010
Obertelli
  • 3006 Answers
SOURCE: lens error 0x03110000 on sanyo vpc e1292
Apologies for the extreme delay in answering, I've just been specifically searching for old unanswered questions. I realise that the information is probably far too late for you, but it may help others searching the site for answers to the same problem.
Your camera has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Sanyo service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Please take a moment to rate the free answer I have provided.
Posted on Oct 06, 2010
t00nz
  • 4738 Answers
SOURCE: my sanyo vpc e1292 says lens error 0x03110000
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Oct 24, 2010
Firmware for sanyo e1292
I purchased (used) the exact same camcorder from eBay. It arrived. Same deal as you described - turn "ON" and white screen appears. SO, I went out and got a new battery. Charging it now, so I will let you know the result after charging. This is my LAST go around with this. Normally, I would never buy a camera from eBay, but I've bought so much other stuff I have not had an issue with (including new & used electronics.) Will keep you posted.
Feb 10, 2012 | Sanyo Xacti VPC-HD2000 High Definition...
How do I fix the lens error on my sanyo vpc-e1292
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101=-
Aug 25, 2011 | Cameras
My sanyou vpc-e1292 camera says lens error then it turns off. What is wrong?
Jul 19, 2010 | Cameras
My sanyo vpc e1292 says lens error 0x03110000
Apr 19, 2010 | Sanyo Vpc-s1070w Digital Camera
I bought a brand new sanyo e1292 camera and cant not get arround the error message of formatting the card, try different cards and size and still the same message. ''Card requires formatting''
Feb 24, 2010 | Cameras
Transfering pictures from camera to computer
Use a card reader instead of your camera.
Dec 26, 2009 | Cameras
Lens error 0x03110000 on sanyo vpc e1292
Nov 18, 2009 | Sanyo Vpc-s1070w Digital Camera
My sanyo vpc-e760 digital camera is showing lens error:22 what do i do
well i have a SANYO camera and every time i cut it on it cuts on a little bit and i see it and it sais lens error: 308 what does that mean?
Oct 08, 2008 | Sanyo VPC-E760 Digital Camera
Cameras Logo
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
