Question about Dell Precision M90 Notebook
Service manual for dell precision m90
Screen went crazy due to overheating because of one of the fans was not working. Took it apart a sprayed with air duster and put it back together. Now the power button will come on then go right back off. What did I do wrong?
stif_NEC
  • 441 Answers
SOURCE: Dell Precision M90
Try installing other anti-virus like NOD32 or karspersky. You can also try to do a system restore, this may or may not solve the problem though,also using the system restore may get rid of some application you have install prior to the date you will revert it to.
Or you can try this online virus scan
http://housecall.trendmicro.com/
http://www.bitdefender.com/scan8/ie.html
http://www.kaspersky.com/virusscanner
have them scan your system (its free),that way you'll know if your computer really has a virus or not.
Posted on Apr 30, 2008
  • 3940 Answers
SOURCE: hi my dell precision m90 has problem. While I'm
The M90 has 2 fans (1 processor and 1 video card) http://support.dell.com/support/edocs/systems/wsM90/en/sm/fans.htm#wp1000550
while the fans can be passing diags, the system could still be having a cooling issue. Some things you can do are:
  1. Use some canned compressed air to blow out the fan intakes and exhaust ports. The hear exchanges can become clogged with dust and debris causing the cpu or video card to overheat.
  2. The M90 video card is replaceable. If the issue is re-occurring on a regular basis, there is a decent probability the issue is the card. Try booting to the F8 Menu and run system in the VGA mode to reduce the load on the video card. If the system runs without issue in this mode, then the video card is suspect.
  3. From OFF, Hold the Fn key and press the power button to initiate diags and see if you get a diagnostic failure.
  4. Update the bios and video drivers, see if issue resolves.
If issue still occurs after all of the above, then replacement of the video card may be required
Posted on Dec 06, 2009
  • 2567 Answers
SOURCE: I have a Dell M90.
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back. If the fan has failed & is no longer running, it might need to be replaced.
Posted on Sep 20, 2010
SOURCE: My Dell precision m90 stopped working. It won't
The computer runs off the battery, if it will not hold a charge or take a charge, there will be no power to run the computer. Rechargeable batterys will get to a point of no power at all and will not except a charge of anykind.
Posted on Dec 21, 2010
  • 4 Answers
SOURCE: how to clean out dell
http://www.youtube.com/watch?v=0yyEVSkz_0M - similar laptop
http://www.youtube.com/watch?v=4ODaKRx7WPw - the lazy way!
Posted on Jun 23, 2011
Hi My dell Precision T7500 makes huge fan noise constantly. It is the front cage fan and is a new original Dell part.
Edward Farren-Price,
The 2 video cards put off a lot of heat. The fan needs to run to keep the system from overheating. If the fan has alot of dust build up you may want to use some canned air to blow the dust off. You can click the link below to download the online service manual. The manual provides information on the location of parts within your computer.
Dell Precision T7500 Service Manual
http://dell.to/18ClNWJ
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 16, 2015 | Dell Precision WorkStation T5500/ T7500...
Installing internal dell m90 smart card reader
You have to take apart a good portion of the laptop to reach the Smart Card Reader spot. You need to turn off the computer, unplug the AC power and remove the battery first. Make sure that you are grounded to the computer. Then remove your optical drive and the hinge cover. Next you remove the mini-card antennas either from the mini-card or their secure spot, display assembly, the keyboard and the palm rest. Then you can reach the screw for the smart card reader and the place on the motherboard where the smart card reader connects.
The full set of steps and pictures is available from the Dell support site, http://www.dell.com/support/Manuals/us/en/19/product/precision-m90 . See the Workstation Service Manual. The direct link to the English version is ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_precision_mobile/precision-m90_service%20manual_en-us.pdf . There are multiple pages you need to follow.
I hope this helps.
Jul 06, 2013 | Dell Precision Computers & Internet
My Mic in Dell Precision m90 stopped working after i downloaded Skype? Any suggestions on how to get it working again?
Have you checked the sound settings in Skype? Usually skype lets you to set your sound equipment individually rather than using the windows general settings.
Especially if you have onboard mic. Try the call settings sound options in skype and check to see if it is working.
Oct 22, 2012 | Dell Precision M90 Notebook
Hi, I have a Dell Precision M90. It has worked great until now. The problem started when I walked away while it was turned on. It was not on my docking station. When I came back a while later the screen...
these problem called garbaig problem
first of all plug out your pc ram and rub its golden area from a rubber
if the problem is still then replace it with the new one.
if problem not solved yet its mean your ram is ok and problem is in AGP now you have to change your agp. ok
Jul 18, 2011 | Dell Precision M90 Notebook
How to clean out dell precision m90 fan.
Jun 23, 2011 | Dell Precision M90 Notebook
My Dell precision m90 stopped working. It won't turn on. It sounds like it wants to but then stops. It was saying that the battery needed to b replaced 4 like a month. Do I need 2by a new battery? Or...
Oct 29, 2010 | Dell Precision M90 Notebook
I have a Dell M90. It has shut down due to overheating. Now it will no turn on. Do you think this could be a fan issue? I purchased this 7-5-2006
Sep 20, 2010 | Dell Precision M90 Notebook
Dell precision m90 overheats randomly
Either your motherboard has gone bad, or you fan AND cooling grid needs replacement. The grid is simply a series of metal bars, so to speak, which absorb heat to be passed out of your system with the cooling fan. The cooling fan has 2 speeds. If the system is not kicking in the higher speed on the fan, it's more than likely a bad motherboard. Also, make sure you keep your laptop plugged into the wall as much as possible. Going on battery alone does slow down the processor considerably to conserve the battery.
Best wishes.
Feb 23, 2010 | Dell Precision 360 Workstation/Personal...
Hi my dell precision m90 has problem. While I'm doing some work it instantly shot down without any warming. From other answers from your site can be an overheating problem but a run the check for all the...
Dec 05, 2009 | Dell Precision M90 Notebook
Open Questions:
See all Dell Precision M90 Notebook Questions
Dell Precision M90 Notebook Logo
195 people viewed this question
Alun Cox
