Question about Jenn-Air Kitchen Ranges
Manual jenn-air slide in range s161
Need owners manual
SOURCE: F1-1 error on Jenn-Air Range
VANMAN69, I have looked in the door under the oven door and can not find the codes. Any more suggestions? I have had a repair man come and replace my control board but I am still getting the F1-1 fault code and when using the oven I get the F3-1 fault code.
Posted on Aug 02, 2007
SOURCE: jenn-air slide in range/convection
Our 7 year old "Jenn-Air Convection Oven", Canadian Model # SVE47600 also has the same problem with the dimming display. We can barely read the temperature on the oven. Does anyone know what is wrong, how to fix it, and how much it may cost. Thank you!
Posted on Jan 02, 2008
SOURCE: jenn air 88370
I have a similar Jenn Air oven approximate date 1982. It has a catalytic liner (colored a kind of dark charcoal  with paler flecks), so it is a continuous clean oven during normal cooking.  However, it also has the Accel Clean setting on the control knob. This increases the oven temperature to maximum and also runs the convection fan to burn off cooking residues. This allows the catalytic lining work at high efficiency, and burn off stubborn residues that are not removed at normal cooking temperature. The oven may emit smoke through the top door vents as the food residues burn off, so watch that you do not set off your smoke detector. I switch on the cooker hood fan and also put a fan in the kitchen window (blowing air out of the kitchen), to avoid setting off my kitchen smoke detector if I use Accel Clean.
Posted on Feb 28, 2009
erpaalai
  • 999 Answers
SOURCE: jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Posted on Jul 03, 2009
SOURCE: I have a jenn-air 30 inch downdraft electric slide
I have 30 inch slide in Jenn air and the black top is blistering and peeling. Jenn air replaced it one but the same thing is happening again. What can I replace this with.
Posted on Sep 22, 2009
Replaced lower element after short
They are generally mounted to the rear of the oven with screws. Not all ovens have them. Please post the complete model number from the range and I will try to help you find the problem.
Thanks/mike
Jan 14, 2008 | Jenn-Air SVE47100 Slide-In Electric...
My Jenn air downdraft gas slide in range is not fully working, the keypad is locked how do i reset it?
Hello, All you have to do is hold the number one button down untill it unlocks. Here is the owners manual http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208113P368-60.pdf
Hope this helps...Please Rate Me..Thank You :)
Jun 09, 2011 | Jenn-Air JGS8750ADS Gas Kitchen Range
I have a jenn-air 30 inch downdraft electric slide in range jes 9800- I have lost the owners manual. How can I get a new one? The power was off for several hours and I need to reset the clock/day. thanks...
Jul 13, 2009 | Jenn-Air JES9800BA Electric Range
Have a slide in Gas Jenn Air model JGS8860BDP, but no manual. Ho
Google your range (i.e. Jenn Air JGS8860BDP). You will be brought to Adobe Reader which will have a copy of the User Guide for your range. Doenload it to your computer, or print it directly.
Nov 11, 2008 | Jenn-Air JES9860 Electric Kitchen Range
How do I get to the grease containers?
The grease container is at the bottom of the range. If you remove the front panel there is a little plastic cup that holds the grease. Hope this helps!!
Oct 10, 2008 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Jenn-Aire locked tight!
Try turning the oven tempurature all the way to the right (past clean). That is what unlocks mine.
Jan 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air stove locked
Check the trouble shooting section of your owner's manual for your various fault codes. It may point you in the right direction as to your next course of action.
Oct 04, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
90 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
