Clare megasave furnace will not start - Heating & Cooling
2 Suggested Answers
  • 1833 Answers
SOURCE: Clare Megasave Propane Furnace. A.C. compressor
You probably have 2 temperature limit switches in thefurnace. One turns on the blower once it is hot enough when the furnace comeson. The second one turns off the gas if the blower fails to come on, or it getstoo hot for some other reason. If the blower fails to start, the gas will keepcoming on until the upper limit switch shuts it off.
Some furnaces use a different relay and coil for a higher speed for fan onlyand A/C is you have it. This means the problem could be the relay too. Most ofthe controls on newer furnaces except the limit switches, are on a board makingdiagnose and repair difficult. In that case you may need to replace the board. Hope this will help you. Good Luck.
Posted on Aug 29, 2011
Took off back to see filters put back together now wont start. spark,nozzle and fan work it just wont start
My Furnace Won't Start. Any Tips Before I Call for Service?
www.airmasterheatingandair.com/my-furnace-wont-start.-any-tips-befor...
Jan 30, 2013 - When your furnace will not start, you might feel a sense of panic and ... GA furnace repair specialists, our team at Air Master Heating and Air has ...
Furnace Won't Turn On? Furnace Troubleshooting
asm-air.com/heating/furnace-wont-turn-on-furnace-troubleshooting/
Jan 7, 2015 - It can be frustrating when your furnace won't turn on, not to mention ...but when you start moving up north it can be downright dangerous when a ... If your furnace is turning on, but blowing cold air, try: Heater Blowing Cold Air.
How To Fix a Furnace that Won't Start - Bonfe's - YouTube
? 1:52
https://www.youtube.com/watch?v=g5alqU4OvqA
Jun 15, 2012 - Uploaded by bonfesplumbingHVAC
Will your furnace not start? Before you call a professional heatingcontractor, check the following step-by-step ...
Furnace wont start. What to do before calling the repa
Jan 16, 2016 | Heating & Cooling
Peugeot 206sw wont start and is makin chain noises from engine and also air filter is jumpin any ideas plz thanx clare.
check the timing belt first sounds ominous this but without my head under the bonnet i have no idea
Jan 30, 2013 | 2005 Peugeot 405
2000 lesabre sometimes stalls at hiway speed. Temp sensor?
Have a Repair Shop Diagnose that code
Don't throw parts at it
Nov 25, 2012 | 2000 Buick LeSabre
Clare Megasave Propane Furnace . How do I remove blower ?
Disconnect the power first. You need to remove the draft blower, push the exhaust pipe from it outward and then move the condensate drain tubing out of the way. Next remove the screws using a 1/4" nut driver or the like. The panel can then be removed exposing the top part. of the blower. Remove any screws that might be present on the track it hangs off of. The blower assembly should then slide out towards you.
Oct 26, 2011 | Coleman Propane Forced Air Heater...
My Simpson eziset 800 washing machine will not start, I press power on then the button start and beeping alarms starts with the 3 water tap lights flashing, Have checked and clared filters and taps
When I had a problem with my simpson washer, with all 3 water temp lights blinking, it was a blockage in the pump, I emptied the washer and disconnected the host to the pump underneath, then cleared out the pump and put the hose back on, problem solved.
Nov 08, 2010 | Siemens Washing Machines
Loss of sound rte1,rte2, tg4, tv3,virgin, nick on box t mmds south west ireland clare
hello the likely problem of this could be the fuses along the audio output section, also check the mosfet transistor that controls the audio out, this can done by opening the back cover of the appliance and using an ohmmeter to read faulty component.... good luck
May 20, 2010 | Audio Players & Recorders
We have a dayton gas furnace model #3E463A. thought the control box was gone. got new one we furnace starts up the power goes on, fan starts no green pulsing light on control no ignition
When your furnace starts...the Ventor motor(exhaust fan) starts up....within a short time (seconds) the Pressure switch closes proving that the Fan is indeed running and the vent is not blocked...if this doesnt happen the furnace will not poweer the ignitor or fire at all....Check the vent pipe outside and look for obstructions or dirt on the screen inside the pipe...the condensate from the fuirnace may not be draining at all...due to plugged condensate drain lines...find this tube coming out of the furnace front...bottom of upper compartment usually , and pull it off the tap....if water starts coming out then your drain is plugged downstream of the furnace.
Oct 25, 2009 | Dayton Gas Furnace Heater
I cant print on cds
clare.... are you putting the actual cd into the printer ?
Robert
Sep 18, 2008 | Epson Printer
Heating & Cooling Logo
85 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
