Question about Garden
How to adjust high and low on a classic poulin pro pp4218av gas chainsaw
SOURCE: homelite chainsaw carb adjustments
I'd replace the fuel pickup and line. It sounds like you are getting air into the fuel system ahead of the carb.
Posted on Oct 14, 2008
dennisgladx
  • 52 Answers
SOURCE: high geared chainsaw
Hi 1tgriffin,
My name is Dennis and I hope that will serve your needs.
IDLE ADJUSTMENTS:
There are three adjustment screws on the carburetor labeled
H (for High speed MIXTURE)
L (for low speed MIXTURE)
T (for idle SPEED SETTING)
They are located just above the primer bulb. If your saw floods so soon in the starting process the idle mixture setting can be set too rich and the speed may be set too slow. Remember the chain will not move when the idle speed is set correctly with a WARM ENGINE!
Adjust the idle speed to just below chain movement WITH A WARM ENGINE this is just below the activation RPM of the centrifugal clutch. Let the engine run at a higher speed than idle until it is warm -- 3 min -- you may have to keep goosing it until then.
Please don't exceed the limits of the plastic limiters when making adjustments.
If you haven't adjusted the mixture screws you may just have to adjust the idle speed and that can start my turning that screw all the way in to the stop and then back out 4-1/2 turns for a good place to start. FAST IDLE -- Adjust the speed until the engine runs with out the chain moving. Adjust clockwise to increase speed. C clockwise to decrease engine speed.
Accelerate the engine and if it stumbles and makes too much smoke it's too rich turn the
LOW SPEED MIXTURE (in) clockwise in 1/16 a turn increments NO MORE at a time because a two cycle needs to run at a setting for a short time to really prove the setting. don’t run it wide open to warm it up but it should be at a fast idle. Nothing you do will be proven correct until the engine is warm.
Good Luck
Glad to be of assistance - please rate the solution because I will learn from your rating. Thank you
Posted on Nov 09, 2008
  • 186 Answers
SOURCE: Stihl ms310 chainsaw will only run on choke
stihl chainsaw runs short time with choke when apply trigger to cut stall and is very hard to restart
Posted on Jul 19, 2009
  • 4088 Answers
SOURCE: How do I adjust the carburetor on a Poulan 38cc
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Be sure to check the fuel filter, air cleaner, and muffler for plugging. Start the engine and allow to warm up--pull the throttle full on and adjust H jet needle CW until the engine starts to speed up, but still 4-stroking. Proper adjustment is reached when the engine 4-strokes at speed, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Set the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
Posted on Jul 09, 2010
  • 4088 Answers
SOURCE: Poulan Pro Chainsaw(PP4218AV) worked for a while now won't start
It's possible that the carburetor diaphragm in the lower chamber has hardened or cracked. Does the primer bulb fill with fuel after several pumps? If not, try moving the line that comes up from the fuel filter to the carburetor over to the primer port that normally connects to the other carburetor connection. Try to pump fuel again--if successful, then there is blockage within the carburetor which should be cleaned with spray carburetor cleaner inside and out. There is a small filter screen inside the main body that can be easily plugged with stale fuel. Hope this helps!
Posted on Jul 11, 2010
Can I get a replacement clutch cover for Poulan Pro model PP4218AVX
Yes, Just use the one from the PP4218AV PN 545012003. I just can not tell if the adjuster assembly comes with the cover or is need to ordered separately.
Jan 24, 2015 | Poulan Pro Pp4218av 18" Gas Chain Saw...
Hard pull start this is anew saw
The Poulin has a very hi compression you need a good harm.
Oct 10, 2014 | Poulan Pro 14" Gas Chainsaw 33CC P3314
How do you adjust the idle on th poulan p3314 gas chainsaw and is there a special tool you need it just wont idle
Most poulan chain saw have three screws idle, high, and low.. if you look air filter cover you will usually see three holes and the high and low will usually have plastic covers on it.. adjust the low 1/4 of a turn and the idle screw in about 1/4 or until the idle picks up... On the plastic cover where the three holes are you will see H which is High L which is Low and I which is Idle... Let me know if you have any problems.. thanks
Jul 16, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
How do you adjust the carborator on a 2.5 stihl chainsaw?
Most Stihl carburetors built after 2000 have limiter caps that prevent much adjusting. the standard for adjustable carburetors is 1 turn out on both high and low then set rpm of idle and high end to specs.
If you need to adjust the engine to get it running there is a problem somewhere else in the systems.
see a dealer like www.arcolawn.com for help.
good luck
Nov 07, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
DONT HAVE PROBLEM JUST NEED TO KNOW MIXTURE OF GAS/OIL FOR POULIN PRO 20 INCH
The correct mix is 40:1. That is 3.2 oz 2 cycle engine oil to 1 gallon regular unleaded gas 87 octane. Use ethanol free gas if you can. Ethanol will damage your fuel lines in time.
Oct 03, 2010 | Poulan Garden
Jul 10, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulin p3314 gas runs out carb
Set the H and L jet screws CW to stops (lightly), then CCW 1-3/4 turns each. This is a basic setting and both need to be turned CW somewhat when the engine runs. Recheck the lower chamber in the carburetor for correct installation of the needle, seat, spring, fulcrum, and diaphragm. Go to: www.drystacked.com for a detailed look at Walbro brand carburetors. Even if you do not have a Walbro carburetor, the principles are much the same. Make sure the fuel tank vent is open.
Mar 27, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I neen repair manual for a Poulan Pro SM4218AV.
Hi Lou; great name.
What are you trying to repair? The correct IPL and some thought works for most things.
Poulan "PP4218AV Type 2" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP4218AV-Gas-Saw-Type-2/75.PP4218AV-Gas-Saw-Type-2.1.59.1.html
If this is not your saw you can find the correct one here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Reply below with some additional detail of what you are looking and we will continue. HTH
Lou
I was born May 1950. Which of us has been Lou longer?
Feb 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Nov 13, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
