Laundry too wrinkled
I have a whirlpool cabrio 6600sw2 and regardless of the spin speed or soak combination that we choose our wash comes out of the unit extremely twisted. So much so that even when we take the load out of the washer, shake out each individual piece of clothing before it goes into the dryer, it still comes out of the dryer way too wrinkled. Regardless of the size of the load. We have found that setting the washer on heavy soak and the spin speed on medium tends to produce the least amount of twisted and wrinkled garments. it is almost as if the clothes need more water, but everything looks fine. We have even considered finding out if there was a way to get more water to the washer by taking off the water saver component on the unit. any suggestions?
    President:
  • Washing Mach... Master
  • 2,651 Answers
Grabbed this of an official whirlpool web site: Clothing in the washer can become tangled and twisted or balled up.
Under certain conditions, a combination of the wash load, the cycle selected and the subsequent load movement can cause
the load to become tangled or twisted.
The wash impeller has been redesigned to make the wash load less likely to tangle under the conditions mentioned above.
Replace the wash impeller with part #W10141017.
willing to bet your serial number is before this number here. easy enough part to switch if its no longer under warr
SERIAL CODE RANGE: Prior to CU39
Remove & destroy
pointer L8178694
dated September 2007
Posted on Oct 27, 2008
Whirlpool Cabrio Washer does not spin the water completly out of the clothes
probably not getting into high speed spin mode
they spin slow in the initial stages to allow the clothes to become evenly distributed then after the water is removed they pick up speed
It is possible a problem in the program board not advancing to high speed
Call in a technician for a proper diagnosis and a quote
Jul 07, 2016 | Whirlpool Washing Machines
Whirlpool cabrio washer no longer spins
Most likely control board. On a cabrio main power controls everything. If it agitate and drains and does not spin that's what it will be especially if there are no codes. Only other thing that could prevent spin, is a bad lid lock. But if there are no codes it a board.
Apr 05, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a Cabrio platinum top loader (not glass) & dark clothes come out with white powdery residue no matter how little he detergent I use and clothes come out really wrinkled
Aha! the problem i'll guess your model number is wtw8200ywo-you have a very bad washing machine-i'm sorry-it does what you say darks are covered withresidue and clothes are very wrinkled-if you are not happy with these issues take it back and get another brand of washer-I have a maytag-maytag was bought by whirlpool-I've had problems with this machine only a year and a half old so probably not a good choice either-Research before you buy and let me know who you come out-cheers Denny
Oct 22, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes very wrinkled
Possible that the drum paddle is not in alignment.
check this link: drum paddle
Jul 05, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes come out super wrinkled?
Just purchased a Cabrio washer/dryer.....biggest mistake I have made in a long time. The clothes come out so wrinkled that you cannot get the wrinkles out wihtout ironing EVERYTHING. These machines are going back ASAP!!!!! I don't care if they are rated #2...they are horrible!
Aug 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Whirlpool Cabrio 6600sw2 has lots of problems, it stops and flashes F50 over and over again, it also flashes many of the other codes, it doesn't fill with enough water and it is not washing the clothes...
The F50 error code indicates that the RPS (rotor position sensor) detects no motor rotation. Check to see if the basket spins freely. If not, you could have an item caught between the outer tub and the inner spin basket. A toy or other item underneath the washer could also prevent the basket from spinning and would result in this F50 code.
If the basket spins freely, you could have a wiring failure that would prevent the motor from spinning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question****
Jan 03, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Jan 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
376 people viewed this question
Top Washing Machines Experts
