Amana AMV5164 Microwave Oven Logo
Posted on Oct 27, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Amana radarange microwave oven 1000 watts not heating.
Seems to be running just fine. Someone gave me the oven so I have no manual, but its just not heating at all.
Anonymous
Level 2:
Scholar:
  • Expert 112 Answers
  • Posted on Oct 27, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
112
Questions
0
Helped
45337
Points
283
The two possible causes are a faulty door switch and a bad magnatron. You can pull the top cover off of the unit and check all of the door switches (there are 2-6 of them all on a common rail, me normally closed)). If the door switches all check out, replace the magnatron, diodes, and capacitor.
Timer clock runs vary fast and will not heat up or cook anything
You have the unit in demo mode, Follow instructions in manual to exit demo.
Does not heat
You gave no model number or other detail. There are MANY possible causes. Fuse, safety switch, power supply, magnetron, control board. Check the fuse first. There is DANGER working on any device like this, and certain skills necessary. That's why they pay us the big bucks, NOT. If you insist on fixing it yourself, do a google search for your model oven, and download the manual. Please follow safety guidelines. Parts and repair help are available at:
http://www.repairclinic.com/
1helpful
Stopped heating
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
Let me know how this works out for you.
Benjamin
Not heating food
likely the magnetron is gone. check your warranty on this part with you book. otherwise it is a costly repair.
1helpful
Amana OTR Convection Microwave runs 59 seconds and shuts off
This sounds like either a thermistor or a damper switch/motor problem.
Amana's technical support line is 866-426-2621. This is the commercial side but they should be able to get you in touch with the domestic side.
I hit the lock button and it quit wrking
Hold down the "START" button for 5 seconds.
4helpful
Help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
2answers
Amama 2.0 Cu ft. Radarange Microwave model# UXA3036BAB
This model does not list Stainless Steel as a feature. Stainless Steel is used in the interior (CAVITY) of a Microwave if it is a Combination Convection/Microwave Oven. The Convection Oven can reach temperatures of 400+ degreesF. This Temperature would MELT the paint off a painted interior.
Stainless Steel can be tested with a Magnet. It will not be attracted or "Stick" to Stainless.
Hope this answers your concerns!
Thanks!
Top Amana Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
