Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Lg lrfd25850tt freezer door handle is loose
I need to tighten the freezer door handle its loose.
aborcass
  • 2651 Answers
SOURCE: loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Posted on Feb 25, 2008
SOURCE: Door Handles Loose
thanks....I solved the problem with your help
Posted on Sep 03, 2007
  • 489 Answers
SOURCE: Loose Door Handle
There is no adjustment for the door handles.  The brackets are metal pressed and if they become loose, it is recommended that they be replaced.
Posted on Jun 11, 2008
  • 311 Answers
SOURCE: refrigerator door handle is loose
If allen screws are there then that is what holds handle in place. There are screws that the handle fits over, so remove handle and tighten as needed. Allen screws are very tiny.
Posted on Nov 28, 2008
rickyrt441
  • 4399 Answers
SOURCE: How do I tighten the outside door handles. They
Do you see any screws?
Posted on Mar 05, 2011
How to tighten loose set screws on freezer door handle on ken more fridge with bottom mount freezer, model no. 269-76353019
I think that the handle is attached either to the door edge or the face. In either case the screws are usually hidden behind a small trim panel. This needs to be removed to expose the screws. I don't know what type of screws have been used. They're usually cross heads but occasionally they require an allen key to remove them.
Jul 19, 2015 | Kenmore Refrigerators
Loose door handle thermador refrigerator
I'd appreciate thoughts on how to tighten THERMADOR not another brand refrigerator door handles. Model: KBUDT4860 A02 which is a stainless steel side by side 2 door freezer / refrigerator. Thanks.
tried the other suggestions above and damaged the surface.
Jan 16, 2013 | Thermador Refrigerators
The freezer handle is loose on one side. How can
Check to see if your freezer handle has an inlay in the handle or trim that pops off to get at a screw that holds the handle onto the door. If you don't have this then you may have a handle that literally slides up and off. You then tighten the mounting screws or replace the handle if that is what is making it loose. We no longer can tear apart the doors on refrigerators to get at components inside, because the factory puts these together and shoots liquid insulation into the cavity, and this insulation expands and hardens making it impossible to tear doors apart anymore. This is why most handles now are front repairable. Good Luck. Appliance Specialists
Dec 11, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Freezer door handle loose
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
May 26, 2009 | Amana ABD2233DES Bottom Freezer...
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Nov 14, 2008 | Amana ABB1927DE Bottom Freezer...
Use a 3/32 Allen wrench to tighten the screw on the side of the door handle
Jul 16, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
