Question about Kenwood Excelon KAC-X541 88W x 4 Car Amplifier Car Audio Amplifier
Need help with cooling fan
I have a Kenwood Excelon KAC-X301T with the powerslide and my amp is getting hot after about 30 minutes driving...It seems as if the cooling fan isnt working...I mean its on, but the amp is just waaay too hot...And the amp goes in and out after awhile...Just trying to figure out whats going on...plz help
  • shelby irwin Apr 06, 2008
    i don't know much about amps so i don't really know how to explain it except that it is cutting off after about 15 minutes and after it cuts off the amp is very hot and it will not come back on until i shut my car off
  • Anonymous Jul 03, 2008
    After driving for fwew min , Amp gives away RED Protection light ,, Overheart maby? , bc it get really hot
    Problem Solver:
  • 19 Answers
Your ohm load is too low causing the amp to work harder which is causing the overheating problem , and that is causing your amp to go into thermal protection mode which is causeing ti to go in and out. what ohm load are you running it at?
Posted on Dec 30, 2007
    Scholar:
  • 72 Answers
Recheck your wiring if this is a new problem. Or if you know someone with a multimeter put it on ohms and check the resistance on the subs. Or if you have multiple subs unhook them all and hook them back up one by one and run it in between to see if the amp runs cooler. Remember you can not go to low on ohms. speakers hooked in parallel brings the ohms down fast. Four ohms and four ohms in parallel equals 2 ohms and so on. check the manual or on the amp somewhere to see how low of ohms you go.
Posted on Aug 25, 2006
SOURCE:
My kenwood excelon KAC-X811D overheats after about 15 minutes and my fan won't turn on, i'm thinking either that or the ground wire being to small could be part of the problem. id really like to know how...
Hi was the fan running fine before overheating problems if so sounds like the fan has gone open amp up take fan out and take to a elec store for replacement
Oct 18, 2009 | Kenwood Excelon KAC-X811D Car Audio...
Kenwood Excelon KAC-X811D blinking e-03
Hello mogly20,
The amp probably won't know if it's you or the homeless guy, so try smashing a glass bottle on it like he did. If that doesn't work, I'd recommend you locate another homeless guy and buy another amp.
Hope this helps.
Aug 08, 2009 | Kenwood Excelon KAC-X521 Car Audio...
Blinking E-03
somthing is fried on your motherboard
Apr 28, 2009 | Kenwood Excelon KAC-X811D Car Audio...
Kenwood Excelon KAC-X812D mono amp
Right next to the rca inputs you will see a reset switch, Reset the amplifier by holding that switch in for about 20 to 30 seconds. This amp has a microprocessor in it that controls the fan. The LCD display that you played with only shows the status of the fan, it does not control the fan. the fan should turn on when the amp starts to get hot. It operates at high or low or stop. If the fan never comes on, even when the amp is very hot, you will need to take it in to be serviced. There is no easy fix to some of the problems. You need the fan to work, so check it out soon and determain if the fan ever comes on. It may take a while to come on, but if it comes on after it starts getting hot, it is working.
Jun 17, 2008 | Kenwood eXcelon KAC-X812D Car Audio...
According to page 7 of the radio's manual, E-02 means the amp has failed and DC is being applied to the speakers. It also says "Turn the POWER switch "OFF" and release the protection."
Feb 09, 2008 | Kenwood Excelon KAC-X521 Car Audio...
Kenwood Excelon KAC-X541 88W x 4 Car Amplifier Car Audio Amplifier Logo
201 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
