Question about Exercise & Fitness
The tension on my Weslo 710 elliptical machine is stuck at a high tension and is not adjusting on the console
The tension is not adjusting when I press on the console, I tried changing the batteries but this did not help
2 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: We have a REFLEX Step
I had a similar problem recently with my elliptical - it was permanently stuck in the "hard" position. In my case, it has a wheel that turns when you step, and the tension is adjusted by a pair of magnets inside this wheel assembly. These magnets are positioned near the wheel - closer for more tension or further for less tension.
The console control electronics that send a signal down to this wheel assembly. There is a little motor that pulls on a short cable to position the magnet(s).
The problem was that the cable attached to one of the magnets snapped, leaving that magnet close to the wheel, i.e. high tension. We had to have a technician order and replace the entire wheel assembly as its individual pieces are not made to be serviceable.
It sounds like your case might be similar. Maybe you only have one magnet or two. In any case, I'd look at whether the magnet(s) are moving relative to the wheel when you adjust the tension settings (you should be able to see or hear the magnets move - you might need a buddy to help).
While you may not be able to repair it yourself (you can get yourself pinched badly around these gears and mechanical elements), you will at least know what's going on so you get the right work done if you choose to hire someone.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 01, 2010
Nordictrack commercial 1300 elliptical
My machine will not start, any suggestions what I can do? i tried holding the start button, nothing. I checked the electricity works in the apartment. I tried the button combination and nothing. Any suggestions?
Nov 13, 2013 | Exercise & Fitness
I bought a second hand Proform 14.0 CE elliptical. The incline is stuck at about 20 degrees. The incline ramp moves slightly while trying to calibrate but remains about 20 degrees. The display shows that...
FOLLOW this steps and fix it. God bless you
Clean the heart rate monitoring pads if the console is not displaying your heart rate when you grip the pads. Use a damp cloth and a mild soap to clean the pads. Do not use alcohol or any other abrasive cleaners that may damage the equipment.
    • 2
Calibrate the ramp if the elliptical is not functioning properly. Press and hold the "Target Toning Workouts" button on the console until the calibration mode appears on the display. Press the "Target Toning Workouts" button once. The elliptical will display additional directions. Use the "One Step Power Ramp" increase and decrease buttons to raise and lower the ramp.
    • 3
Adjust the reed switch by removing the access cover, which sits over the wheel of the elliptical at the back of the machine. The access cover can be removed with a flat-head screwdriver. Unplug the machine. The reed switch provides information to the console for display. Rotate the pulley until the pulley magnet, which is under the belt, lines up with the reed switch. The reed switch has a wire running into it. Loosen the screw to the reed switch and adjust the distance closer or farther from the pulley magnet. Tighten the screw. Plug in the machine and rotate the pulley. If the console still is not displaying correctly, repeat adjusting the reed switch distance either closer or father from the pulley magnet.
    • 4
Adjust the drive belt if the pedals slip while in use. Unplug the elliptical. Lift the latch on the underside of the left pedal arm and slip it off. Use a screwdriver to remove the arm sleeve and pry open the disc panel. Loosen the pivot screw located on the left side. The belt tighten screw is below the pivot screw. Tighten the belt tightening screw until the belt is tight. Tighten the pivot screw. Replace the disc and arm to the elliptical
Oct 24, 2013 | Exercise & Fitness
Resistance not adjusting
Reading on HSN website, it is b/c this product is junk. Dozens and dozens of reviews stating the resistance is stuck and wont' change.
http://www.hsn.com/products/proform-smart-strider-spacesaver-elliptical/6647352?query=6647352&isSuggested=True
Jan 20, 2013 | Proform Smart Strider SpaceSaver...
Need a weslo momentum 710 elliptical manual
go www.fitness.manualonline.com or www.iconservice.com or www.retrevo.com
sincerely. God bless you
Apr 18, 2012 | Exercise & Fitness
My weslo momentum 7.0 ex elliptical machine display stopped working. It won't power on even with new batteries.
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of the pedalsto the crank axles.
ernesto cuadramanagua, nicaragua
Mar 07, 2012 | Exercise & Fitness
How do I fix my crosstrainer, magnetic resistance has stopped working
This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
Feb 15, 2012 | Exercise & Fitness
My weslo momentum 7.0 ex elliptical machine stopped giving resistance. I have turned the knob as far as it can go, and it is still easy! What can I do to repair this?
If you don't have the owners manual I suggest going to iconservice.com click on manual input this info Weslo THEN M# WLEL2904 then pages 11 and 12 will the steps to inspect and adjust tension for resesistance.
Jun 08, 2010 | Exercise & Fitness
How to adjust resistance on a manual Weslo cardio/walk treadmill
I found the solution on the Internet. Allen head bolts on each end of the frame can be turned to loosen or tighten the belt.
Jan 05, 2010 | Exercise & Fitness
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Exercise & Fitness Logo
216 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
