Question about Heartland Metro 3535RWLP3PR Dual Fuel Range
SC on heartland stove and oven won't shut off
3 Suggested Answers
heavymetal77
  • 721 Answers
SOURCE: Hi, I have had the
www.heartlandapp.com/GetFile.ashx?idFile=20 That's a link to the service manual
Do you smell gas? I've seen spider egg sacks on gas grills cause this. Cloggs the ports & not enough gas comes out. But this unit has alot more to it than a grill. The ignitor must be spaced properly to achieve the proper spark. You need about an eighth in. gap to get the right arc. The regulator may not be letting the proper pressure out. too much & no light, too little same deal. Some disassembly maybe needed to clean the ports & tubes out if they are blocked. I googled this model & many have similar issues. Other concerns could be, is it getting enough air under the unit? Amazing they bill you $300 & not fix it or provide a decent solution!
Posted on Apr 30, 2011
Hi, well you have got yourself a nasty little problem. however it may be resolvable. See it sounds as though you may have a "Jet" or "pressure" problem.
A Gas appliance is a fairly simple device, the gas enters, and is usually dropped in pressure, and then via a Valve, is fed to an outlet port, that has a "Jet" in it, (a small insert with a tiny hole through it, bigger hole more gas) So, now the "Igniter" is a Pizeo-electric element, and this produces a spark, to light the gas.
Now we also have "Protection" circuitry that monitors certain parameters, and will shut down the stove if any of those parameters are activated.
Also we have a "Main Controller" that administrates the stoves activities, and work in conjunction with our "protection" circuits.
So as you can see there is little that can go wrong... if we suspect Gas, then it maybe blocked jets, blocked gas pipe, or low pressure. If we suspect igniter, then obviously, that's where the problem is, either it's stopped working, the electrical connection isn't correct/broken.
Now the fact you can "Hear" the "Sparking" indicates that the igniter must be working, no doubt, you can also "See" the blue spark as well. If so this then eliminates the igniter, as they are a Go-No-Go device, and yours it seems is OK.
That leaves us with Gas, perhaps you have a bad regulator? perhaps you have a Blocked jet? perhaps you have a pipe blockage? Perhaps you have bad pressure?
Most often it is simply a clogged jet nozzle, they can be cleaned out with thin wire, Fuse wire is ideal. As can most pipes, it is seldom those though, The regulators and any valves can often be suspect, the diaphragm causes the problems here, and valves can stick etc..
But in saying all that it could also be a main controller "Fault" as this too can give similar symptoms, one really has to work through the troubleshooting steps, and isolate the exact cause, by process of elimination.
Below is a user manual for you. I searched for a service manual, however was unable to find one, this is a "Must Have" if one wants to service anything. Perhaps if you contact an agent or similar you maybe able to procure a manual? If you wish to DIY then you really do need one.
With Gas though, you really must be careful, as you must understand. This is why, in reality, professionally, I must advise you to use a professional serviceman, just to be safe.
Also one must at some point come to the idea of replacement, what with spending $300 already, and still it hasn't been resolved, and now there is a prospect of more monies having to be outlaid, perhaps even the same amount again, to my mind, I would be thinking about putting any further monies towards a NEW unit, with a full warranty?
Further, to this end, a recent Swedish study, has revealed that an repaired item, any repaired item, will "Fault" again within the next 12 - 18 months regardless. This is due, to the fact that "Other" components are "Stressed" by the initial "Fault", and this, or a repeat of the old fault, causes a failure later on. Food for thought?
How do I turn off the "key" icon on screen display Heartland Stove/Oven ?
The key is a lockout symbol. It appears when you set the oven to child lock mode ( Stops kids from opening the door and getting burnt) or when the oven gets over a certain temperature. (Stops you getting burnt) If you from have the instruction manual, it is xa bit difficult. You usually have to npress and hold 1 or more of the buttons in for a few seconds to unlock. I'm not sure which ones on your oven.
Jan 02, 2016 | Heartland Appliances 30 Inch Dual Fuel...
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Stove reads F3 and won't cancel and oven won't shut off?
Hello & Welcome to FixYa
F3 error code indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 15, 2011 | Frigidaire Ovens
The oven door of my heartland stove does not close tightly any more. Is there an easy fix?
i have a 36 in legacy when you replace the door oven strip do not put it on the bottom
Jan 31, 2011 | Heartland 3525SS Dual Fuel (Electric and...
The cooling fan stays engaged after a cleaning cycle. How can it be turned off as it has been running for 2 days now.
The problem is the oven door latch. Open the oven door and you'll see the latch on the left front. When it's to the right, the readout will read "SC" for self cleaning. When pushed back left, the fan stops. Apparently the latch does not return to the off position after SC. Snap it back a few times and it may stay off. If not, you'll have to fix it.
Dec 06, 2009 | Heartland 3525SS Dual Fuel (Electric and...
Heartland Metro 3535RWLP3PR  Dual Fuel  Range Logo
Top Heartland Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Heartland Kitchen Range Expert? Answer questions, earn points and help others
