Question about HP Officejet Pro L7580 All-In-One InkJet Printer
How do I perform a factory reset of an HP Officejet 6500 E709n
SOURCE: Cannot scan from HP 6500 E709n (No Scan Options)
the shortcut is:
c:\program files\hp\digital imaging\bin\hpiscnapp
Posted on Sep 04, 2009
Testimonial: "Thanks, that totally worked. I still wish i could scan from the printer, though."
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
SOURCE: HP Officejet 6500 No scan Options
I am trying to scan, but when I press the scan button it states "No scan options. Refer to device doc to troubleshoot". However, I can't find my device doc. I am assuming there is an easy fix?
Posted on Dec 19, 2009
Mhinhi
  • 10 Answers
SOURCE: HP Officejet 6500 will not print after sleep mode
Move the printer to a different location and keep it closer to the connected device (e.g. router) and away from large metal objects / other electromagnetic devices for stronger signal strength.
Posted on Mar 01, 2010
SOURCE: how to reset the ink level of my hp officejet 6500
Checking ink levelsUse one of the following methods to check the ink levels. Method one: Check the ink levels from the HP All-in-One The ink level is displayed on the main screen of the control panel display. Locate the two icons that represent the print cartridges. The icon on the left is for the color cartridge and the icon on the right is for the black cartridge.
  • The exclamation mark (! ) symbol indicates a low ink level.
  • The question mark (? ) symbol indicates the product cannot determine the status of the print cartridge. This might be because the cartridge is refilled.
Figure 1: Ink levels on the control panel displayc01362755.gif 1 - Exclamation mark indicates low ink in the color cartridge 2 - Ink level in the black cartridge is OK Method two: Check the ink levels from the computer using the HP ToolboxFollow these steps to check the estimated ink levels using HP Toolbox.
  1. Make sure the product is on and connected to the computer.
  2. Open HP Solution Center .
    • Windows XP: On the Windows taskbar, click Start , click All Programs , point to HP , and then click HP Solution Center .
    • Windows Vista: On the Windows taskbar, click the Windows icon (c01364735.gif ), click All Programs , click HP , and then click HP Solution Center .
    • Windows 2000: On the Windows taskbar, click Start , click Programs , point to HP , and then click HP Solution Center .
  3. Click Settings .
  4. Point to Print Settings , and then click Printer Toolbox . Printer Toolbox opens.
  5. Check the ink levels displayed on the Estimated Ink Levels tab.
Figure 2: Estimated ink levelsc00670267.gif
Posted on Jun 02, 2010
I want reset my hp officejet 6500A
Hi. To reset an HP Officejet 6500 E709a or 6500 Wireless E709n, follow these simple steps:
1. Press the (*) and (#) buttons on the printer control panel at the same time and let go.
2. Use right and left arrows to scroll trhough menu and select "Resets"
3. Select "Semi-Full" reset and printer will shut off in a few seconds.
4. Unplug the printer from wall and wait 30 seconds.
5. Plug in the printer, Turn printer on and selec basic settings.
Your printer is now reset!!!
Apr 18, 2012 | HP Officejet 6500 AllInOne InkJet Printer
I have a HP Officejet printer model 6500 E709n (USB connected) and I have just changed the black print cartridge and now the printer only ptints blank ppages. I check of the printer status reveals that...
What about print head?.. perform print head cleaning process through tool box, check any back print out? no remove black/yellow print head clean nozzles manually, try it if not resolved replace print head..browse the link how to clean the print head..http://www.ehow.com/video_4974250_manually-clean-hp-inkjet-cartridge.html
Oct 27, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500 wireless printer won't print quickbooks checks
go to control panel, printers, right click on my printer icon (HP Officejet 6500 E709n), click properties, click advanced tab and check "print directly to printer"
Nov 26, 2010 | HP Officejet 6500 Wireless All-in-One...
I just bought a new HP Officejet 6500 Wireless All-in-One Printer - E709n. When I try to scan, it tells me I have no scan options. What do I do?
If you're using Vista, I had the same problem. To scan, go to MS Paint and choose "file" and "from scanner or camera" then save the file it scans. That worked well for me, as a go-around for Vista. Hope this helps! Lisa
Nov 10, 2010 | HP Officejet 6500 Wireless All-in-One...
Can we have a different phone number for the fax on the Officejet 6500 E709n ???
You can provide or connect telephone services with different telephone numbers or more as anything you want but for your HP Office Jet 6500 i think not yet program to do that.
Unless on your telephone services have splitter or switch with different line, it's yes!
This printer is only one telephone port.
I hope this might help you a tip to know about your query.
Have fun use with your beautiful HP printer.
Sep 16, 2009 | HP Officejet 6500 Wireless All-in-One...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
137 people viewed this question
Seeker5211
Seeker5211
