Question about Samsung RB215LASH
Samsung refrig has blinking display lights
Refrig does not stay cold display lights are blinking
2 Suggested Answers
  • 7 Answers
SOURCE: RS267lash samsung refrig. display panel fridge
Sounds like the fan unit is faouling with ice. The solution is to remove the whole of the contents and then the units inside at the rear. Defrost same and re assemble. Its not that hard if you remove the light difuser first and the two screws. Mark the difuser for top. Then ease out the unit and remove after taking out the electrical connections. They fit only one way. The lower unit has four screws. Two under covers. Easy to unclip. The ice seal may mean that it is not that easy to remove. Defrost both the units with a hairdryer or similar and clear insulation from the fan drain. Re assemble when clear and as dry as you can. The problem will come back so be aware that you have to repeat the procedure when the fan gives signs of fouling. Paul.
Posted on Jul 11, 2010
Kenmore Refrig Model 596.50699000, not getting cold as should. Frost forming on top row of coils only?????
Clean the condenser. Probably below refrig. Reset all settings to mid point and check to see if you have a restricted drain tube.
Jun 17, 2012 | Kenmore Side by Side Refrigerator
Whats a damper
it throttles (Opens & Closes) a small door for the cold air from the freezer into the refrigerator depending at what temp the refrig compartment is set at is how long it stays open or closed
May 02, 2012 | Samsung Refrigerators
The tempature on my refrig. panel continues to blink on the frig.side. I have it at the lowest settinng which is 34F. The Freezer has not moved nor is it blinking. The freezer is still holding its temp. ...
The computer has detected an error in the system and needs to be addressed by a Samsung qualified technician. They have a list of error codes that they can figure out what's wrong with the unit.
Jul 18, 2011 | Samsung RS2630SH Side by Side Refrigerator
Temp in the refrige wont stay cold. frezer is fine. model name is rs2545sh
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Samsung Refrigerators
Jul 11, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
I have a Kenmore refrig./freezer (top freezer, bottom refrig.) that stays in my garage all year long. After this very cold winter, it has stopped working. The light goes on, but no sound of motor, and...
-Possibly no more Freon.
Try this:
-Turn the control switch all the way to 0. Let it stay for 10 minutes or more then turn it up to number 5 to see it kick the motor or not.
If not then possibly the relay is bad.
But if there is power there then the motor is bad.
Good luck and do not store any food in until it had fixed
Mai
Dec 12, 2017 | Kenmore 61282 / 61284 / 61289 Top Freezer...
Refrigerator cold control doesn't work; temperature stays at or below freezing. Freezer control OK.
check the damper door between the refrige and freezer compartments,its behind a plastic cover,if its iced up in the fully open condition it will allow too much cold air into the refrige,if this is the case defrost it with a hair dryer and recheck operation,otherwise the temp control in the refrige is bad
Mar 18, 2010 | Refrigerators
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Control Display keeps changing numbers
we unplugged the refrigerator for a bit over 1 minute and replugged and problem went away.
Jan 11, 2009 | LG LRFD21855 Stainless Steel French Door...
Samsung RB215LASH Logo
51 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
