Zenith Z56Z98D8 rear projection......HELP!!!
Hello there. Just found this site and decided to ask for someassistance. I saw your reply to a different person who seemed to have similar problems and thought you may be able to help me. I have a Zenith Z56Z95D8.Recently, the picture went black...still had sound just no picture. Wastold to replace the HV module board(part# 9-1674-03). As soon as I didthis, the tv worked fine for a couple weeks. Now, to start tv I need tohold in the power button for it to turn on. When it comes on there is adistinctive electric "clicking-popping" sound being made and thepicture has a "electrical interference" at the same time as the sound.I can definitely trace the sound to the part where the HV module wireplugs into the bottom of what I would call a splitter block. There are(3) additional wires that go from this "splitter block" to each of theCRT's. The id sticker for this part is # A-17813-01. Is this theculprit part? What is this part called? Where to get a replacementcheap? I replaced the same High Voltage Module(9-1674-03) approx (3) years ago and had no problems until the picture went out again, so I just ordered and installed a new one. Would a bad "splitter" be causing the high voltage board to go bad? I'm no electronics guru but I can replace parts, just no good a electrical troubleshooting. Thanks Alot for any assistance, don't have $$$$ for a new tv.
Steve
brnltjo@embarqmail.com
p.s. what is the difference between a flyback transformer and a high voltage splitter?
  • brnltjo Oct 27, 2008
    Hey again... Thanks for the quick reply!!! Just a couple more questions.... Is a "bleeder assembly" the same as a "HV splitter"? Would the part# for this bleeder assembly be A-17813-01? Is part # A-17196-03 a bleeder assembly a substitute bleeder part or something totally different? How comfortable % wise are you that this is my problem? Unless I'm an idiot, the noise I hear is coming from this particular part. Sorry for the additional questions, it's not that I don't appreciate or trust your expertise, cause god knows it's WAY WAY more than what I have, I just want to be as sure as possible before spending $$$.
    Thanks again, greatly appreciate it!!
    Steve
  • 8,617 Answers
Its called a bleeder assembly www.partsstore.com has a replacement for it 172.00 That could very well cause of the HV modules problems.
Posted on Oct 27, 2008
  • Sonny Berry
    Sonny Berry Oct 27, 2008
    A-17196-03 is the part number for another Bleeder assembly but isnt listed as a replacement for your model, although it may work without any problems as it fits some models with the same chassis as yours. I couldnt swear that the bleeder is causing the problem without diagnosing the set in person, However if your hearing any noises from the bleeder thats not a normal situation so it maybe defective. Yes the bleeder is very simallar to a HV splitter they basically do the same job.
Fuel mix ratio for poulan counter vibe 3400 chain saw; mix ratio
A different site that lists 40:1. http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/4a98e23d38cbda9b88256bf80015de57?OpenDocument
Oil mix is controversial. Some think more is better, todays saws run much faster and carbon up much quicker. Ask the mechanics at a local saw shop. I will wager they say 50:1 regardless of the age of the saw. Me too! The Echo site now says use 50:1 regardless of what is printed in the OM. It is your saw Mike; run what you want.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 02, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
I have a blue haze across the bottom of the tv screen. About 1 1/2 inches tall. what causes this?
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
Aug 01, 2009 | Zenith E44W46LCD 44" Rear Projection...
I have a Zenith d52wlcd and the screen is dark or excessively blue.
Jun 27, 2009 | Zenith D52WLCD 52" Rear Projection...
Blue Bands on sides of Zenith Projection TV D60WLCD
Dec 23, 2008 | Zenith IQB60M92W 60" Rear Projection...
Replacement Filter for LCD TV
hey there yeah you are right your LCD is brunt out, to be honest with you I don't think they sale just the LCD chips you have to buy the OPTICAL BLOCK to fix this problem good luck.
Dec 04, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith D60WLCD Repair
Sep 21, 2008 | Zenith D60WLCD 60" Rear Projection...
Need replacement convergence panel for 40"zenith rear projection hdtv. repairman took part and money, then ran. please help
can you verify the model number of your Zenith and i will try to assist you. reply to this same post.
Jul 24, 2008 | Televison & Video
ZENITH D52WLCD
I just found the solution on another model of Zenith TV. Hold the enter button down on the TV and the MUTE button on the remote. In approx. 5-7 seconds a screen will pop up asking if you want to reset the lamp timer. Hit the bullseye button in the middle of the arrows and it will reset. Worked perfectly.
Apr 15, 2008 | Zenith D52WLCD 52" Rear Projection...
R57w46 zenith
Hello Was wondering if you ever found anything out how to reset the IC Screen Numbers or what the factory numbers all are on the Zenith Rear Projection TV Model # R57W46? I have the same problem ! My 2 year old son, not knowing how he did it cuze only a technecian is suppose to get into this screen, but he did change numbers in the too. I called zenith themselves and no luck ! My screen is bowed , etc.. Any Help ?
Jan 16, 2007 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
