Question about iLO Televison & Video
HDMI problems I have an iLO 32 in. television and directv HDMI, but I cannot receive any signal via HDMI only composite. any solution? (it's a new cable)
  • 1 more comment
  • carlandpat6 Oct 27, 2008
    Yes the box is set to use HDMI. We used to be able to receive the HDMI signal, but it just quit. So we bought a new cable. Directv told us the problem is with the television. and it could well be. because we halso have issues with the s-video being in black and white.
    Yes we have tried all the solutions that we can, but we have no other HD television, nor is there another HDMI port to try. I had already tried resetting the television.
    thank you for your time
    PCE
    Thanks I'll try that tomarrow. Have a great evening.
  • iLO Master
  • 13,433 Answers
Is the box set to use the hdmi? Sounds like a settings problem.
Posted on Oct 27, 2008
  • Ekse Oct 27, 2008
    Could be a setting problem on the tv side or then you are having a electronic problem in the input / signal board of the tv. do you have another hdmi port to try? if not can you try another television with hdmi? try reseting your tv to default settings.
  • Ekse Oct 27, 2008
    You could take the box to a friend with a tv that the box would work with to confirm if the problem is in your tv.
My tv is not 'seeing' any of the hdmi devices plugged into it.
surge protectors do not work very well. They dont really stop mildly high voltages. If you can plug the Directv receiver into another TV and it works, then you have a bad digital board in your TV.
Aug 15, 2015 | Toshiba Televison & Video
ILO 42 plasma P42BSMT-32 am upgrading satellite service to HD is this tv HD compatiable no HTMI port
You can get 720p or 1080i " fake 1080 " through the RGB component inputs, But you will not get 1080p true 1080 res. But, this TV is only 720p anyway. But,it will still make a big difference in the pict. up-grading. And having the new HD box when you get new your new service now,will save you $100 from needing to buy a HD box later if you have a new TV with the HDMI. As DirecTV will give you the HD boxes free with new service. But,charge later if you have up-grade from a standard box. No sure how Dish network does tho. But, not have had too many customers happy with Dish. DirecTV is the way to go. And the signal during the rain is so much more problem free.
Apr 26, 2014 | Televison & Video
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
How do i connect my existing directv box to my new insignia 42" lcd tv?
if have hd box use hdmi or composite video input
if not hd box us video or channe 3 or 4
Nov 09, 2009 | Insignia IS-LCDTV32 32 in. Television
No digital signal
You don't have anything to worry about. I have Directv too.
Just leave everything normal. The Directv box does all the work and puts the programs on the TV. The Directv System is not affected by the DTV Deadline.
Here's info from Directv web site on the subject.
http://www.directv.com/DTVAPP/global/contentPageNR.jsp?assetId=3460059
Jun 12, 2009 | iLO 3200 32 in. LCD Television
I just got a new tv, and have hooked it up to my Directv receiver per their phone helpdesk person's instructions. I can't get the channels to auto-program on the tv - it keeps telling me there's no signal....
How are you connecting the receiver to the television? RCA cables? HDMI? Coax cables?
Auto tune only works if you are connecting via coax and plan to use channel 3/4 to view. If you are using either HDMI/Coax/Component/etc, then you would need to use the input button on your television remote (Not the DirecTV remote, the one that came with your television) to toggle through the various inputs until you find the signal from the DirecTV receiver.
Feb 24, 2009 | Directv RC23 Remote Control
Connection problem with Denon 589 and direct tv
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 08, 2009 | Denon AVR588 Receiver
Ilo 32'' lcd television
call comcast and they will walk you through it at no charge
Nov 02, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
79 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
