Question about Samsung TXN2771HF 27" TV
TV won't come on
I turned the tv on and it made a hissing sound. There was an acidic burning smell with no picture and the unit will not come on at all at this time. The tv is only 3 yrs. old, has not been moved and is in dry area. Any ideas?
  • 1 more comment
  • Anonymous Jan 21, 2008
    When i pressed the power on my tv it made the click that it normally makes when it turns on but i got no picture and i smelled something burning, what could be wrong?
  • Anonymous Jun 27, 2008
    tv won;t come on. power switch blanks and thats all. tv is only little a year old. do you think it is the sensor power switch. thank you carol
  • Anonymous Jul 12, 2008
    I just encounter the same problem with the KV-32FS320 TV however, unlike the problem of Carol the TV is just a two months old and the remove is original. Would it be possible that the problem is with the manufacturing of the TV itself?
Depends if you know about electronics and have SOME knowledge on how to fix them the user may well be able to source parts to fix them. Read WARNING below..
As suggested the fault could be FBT "Horizontal Output Transistor" (Check to see if shorted.) burnt out resistor or electolytic capacitor.
IF the FBT (Flyback transformer.) needs to be replaced you will want to know how to SAFELY discharge CRT HIGH VOLTAGE (WARNING CRT acts like a huge capacitor and may store around 25000Volts AND CAN KILL a person .) if unsure get qualified person to do repair.
By the way the term "No user servicable parts inside." is to keep
most people safe from high voltages etc inside.
If you know where to go you can get all (Well mostly all) the parts you require.
Things to assist people to help:
Does your TV have self diagnostics?
Ie. does standby led flash in a particular sequence.
This will give a tech a 98% of correctly advising your fault.
If you open the case (Have good lighting.) you should be able to see a burnt out resistor with no problem as it will most likely be brown to black with unreadable color codes or value on it.
Write down the resistor PCB id eg R615 etc. (Same applies to Horizontal Output Transistor etc.)
This will also assist a tech to provide correct information, and reduce the possible causes of fault..
ALWAYS remember if in doubt get a qualified person to do job.
Posted on Jun 14, 2008
Last time i posted the problem of my konka tv.i red somebody's sugession for solution for the problem,and i tried the tech,i found where the problem on the tv's ckt board one of the ckt part which regulates the temp. is loosen when i touched it with my screw driver while turning the tv on, the tv starts to display.
check the whole circuit,u will find some problem,
Posted on Dec 21, 2007
    Novelist:
    Champion:
  • 275 Answers
Really cannot help you. Could be many things. Power Regulator short Circuit, Horizontal Output Transistor and FBT ... Best get a professional to take a look. These sets are all solid state, and there are no user servicable parts inside.
Posted on Aug 25, 2006
Have a 65inch Mitsubishi DLP. acouple years old, just heard a loud pop,smelled like it was burning,it turns on but just sound????
hi,
Check the lamp of you tv. The lam is burned. that's why you heared a pop up sound and burning smell. Just check it and replace it. you will get the picture back.
ok
Apr 16, 2011 | Mitsubishi WD65737 65" DLP TV
Board in lower back of TV has burned out. I have pics.
If you have a burt board you are better off to replace whole board Call Encompass Parts 1-800-638-3328
Jan 08, 2010 | Televison & Video
When I turn on the tv, it makes a sparkly sound and shuts off.
You probably have a high voltage failure causing the TV to sense the overload and shut off. There is about 30,000 volt required to light your picture tube focus the picture. If there is a failure anywhere in this circuit you will get the hissing noise and occasionally an ozone smell. I recommend you contact a TV serviceman to diagnose and repair this problem.
Oct 08, 2009 | RCA D52W23 52" HDTV CRT TV
RCA d52w20b picture shaking and "hissing" sound.
The grey components are Box capacitors chances are the 0047 2KV box capacitor in front of that heat sink is whats shorted out, very common problem for your model.
Aug 08, 2009 | Televison & Video
No picture, perfect sound, burning smell
I assume this is an LCD tv that you have? I would think a fault has developed on your inverter board with one of the components having burnt out & shutting off the drive to the backlights hence the smell & lines on the picture. It would be advisible to take it to a repair centre to have it repaired to check the burning issue as a matter of safety
Aug 04, 2009 | Televison & Video
I just replace convergence board on my akai tv and
There is a burnt capacitor somewhere in the unit. Look for any burnt or swelled up capacitors. You can also usually locate a bad cap if there is burn marks on the system board. Also test power supply with voltmmeter to make sure it is a constant volt reading.
Jul 11, 2009 | Akai PDP-42TD1 42 in. EDTV-Ready Plasma...
No picture
Burning smell can be caused by a blown component, a short, or dust burning inside circuits.
In all cases do not turn TV on untill the TV had been tested and the problem is fixed as you risk to cause further damage to the unit.
Regards.
May 17, 2009 | Mitsubishi VS-5046 50" Rear Projection...
Wont turn on smell burning
Can you remove the rear panel and check if the hissing is coming from the flyback? Which is a large transformer with a large red wire coming from the top of it? If so can post a link where you can get a replacement their not exspensive and their easy to replace. If its not coming from the flyback post a picture of where the hissing is coming from and I will identify the parts for you, But I feel its the flyback due to the hissing. respond to this same post so I have your correct model number when you reply.
Jun 25, 2008 | Zenith R57W46 57" Rear Projection...
No picture or sound
If you had a burning smell, well the board is toast. These sets are made to replace the entire board at one time. Before installing the replacement module, the picture tube should be checked. A defective picture tube ( such as a G1 short) may cause a failure in the power supply section.
Sep 07, 2006 | Zenith C32V36 32" TV
Sanyo TV DS32224
Is the hissing or static sound comming from the speakers or from the back of the set itself?? Need more info please.
Mar 23, 2006 | Sanyo DS27910 27" TV
Samsung TXN2771HF 27" TV Logo
298 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
