Question about Garden
What is the fuel mix for a homelite mp 38 - Garden
3 Suggested Answers
  • 4088 Answers
SOURCE: Fuel Ratio
40:1 is about right. Be sure to use modern synthetic oils made for saws and premix thoroughly before adding to the saw.
Posted on May 04, 2010
  • 221 Answers
SOURCE: what is the fuel mix ratio
50 to 1. try to find non ethanol fuel to run in it also.
Posted on May 17, 2010
What is the fuel ratio for a homelite LX30 chainsaw,ive been told 30/1 50/1 25/1 40/1. Which is correct thanks.
Find an oil you like and mix it according to the oil recommendations.
I use Opti-2 in all my 2cycle fuel mix and it's a 100:1.
What the oil manufacturer says to mix the oil/fuel is what you go by, not what the engine manufacturer says.
Opti 2 2 Cycle Oil 34oz EZ Measure Bottle 20112 eBay
Mar 05, 2018 | Homelite Garden
How to mix fuel and oil
Page 14 here
http://www.manualslib.com/manual/453515/Homelite-Ranger-Ut10926.html?page=14#manual
May 27, 2016 | Homelite Garden
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
What is gas m ratio fr 25cc weer
Hello there
Download here friend.
http://manuals.homelite.com/system/files/4262/original/UT40502_UT40903_041_eng.pdf?2011
Page 8 of the Homelite user Manual gives you the EXACT ratio.
FUEL MIXTURE
'This product is powered by a 2-cycle engine and requires
pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded
gasoline and 2-cycle engine lubricant in a clean 1 gallon
container approved for gasoline.
Recommended fuel:
This engine is certified to operate on
unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mixlubricant with gasolineaccording to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US)'
Sep 12, 2014 | Homelite Garden
I just purchase a homelite leafblower ut 09510 175mph, do i need to mix oil and gas for fuel?
Yes, you will need to mix up some fuel with two cycle oil. See your owners manual for the proper mix ratio. Keep this fuel in separate container from your lawn mower gas.
Sep 04, 2011 | Homelite Garden
Need to know the fuel and oil mix on a homelite 330 chainsaw
The fuel, oil mix for homelite chinsaws is 32:1. Hope this helps.
Sep 26, 2010 | Homelite ZR10926 16" Chain Saw
Oil to gas mix
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 10, 2010 | Poulan Pro PP3816AV 38 Cc 16" Anti - Vib...
Fuel mix ratio for poulan counter vibe 3400 chain saw and for a homelite st-145 weed trimmer
Oil Mix Ratio: (last 5-10 years)
If me I would have the Poulan tweaked to run properly on 50:1 and use that in both. It will start easier and take much longer to carbon foul.
Lou
Apr 30, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
What is the fuel oil mixture for a homelite gas trimmer model ut20779
Hi a safe fuel mix is 25:1 but most homelites run a mix of 32:1 either one should be ok
Jul 03, 2009 | Garden
Garden Logo
130 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
