Question about Drive Medical Drive Phoenix 4 wheel scooter *Free Batteries/Free Home Delivery!
Where is the circuit board on drive medical phoenix scooter?
Where is the circuit board located?
3 Suggested Answers
  • 177 Answers
SOURCE: Where can I order parts for the drive medical
Hi is the on /off switch a proper key lock, or a round plug. If it is a round plug then the switch is probably a mono plug available from any radio repair shop. I have changed a few of these.
Is the name phantom a proper brand name, or just a name the importer put on it. Have a llok inside the covers and see if you can find another name, or a serial number sticker.
Good luck. Neil.
Posted on May 30, 2010
  • 177 Answers
SOURCE: how to disconnect the back-up sound oon a medical drive falcon 4
Hi. On most scooters, the reverse beeper and the horn beeper noises are emitted from the same speaker.
The simplest way, is to unplug the speaker from the circuit board, although this might also disable the horn. It is easy to reconnect the beeper if you need to.
If you still need to use a horn, you can get cheap plastic ones from the bicycle shops.
Good luck. Neil.
Posted on Jun 12, 2010
Testimonial: "Thanks - hopefully, there are two wires to the speaker!"
How to fix scooter when red light flashes 5 times
hi, i need you tell me what controller type is fitted to that scooter before i can be more precise with fault info ,, the controller is a black, or blue or silver box located under the rear cover of the scooter ,, the wires lead to this unit...
Regards
Rob
www.gewizrepairs.co.uk
Apr 10, 2014 | Drive Medical Phoenix 3 Wheel Compact...
The red light flashes 5 times scooter will not move
I would look at the freewheel lever. Disengage and then engage the freewheel and see if this corrects the problem. If not, you may have a bad freewheel switch.
My Phoenix scooter is two years old and looses the charge in about 5 min. I changed the batterys and got a new charger but it still does this?
hi, there must be a short, first of all is it possible you got another set of bad batteries, are they new ? and how long are you charging them for , and it the charging showing that it , if for some reason the connection is bad depending on the charger can show fully charged when it fact they are not !!! check the charger socket to the batteries...
Regards
GeWiz.
Feb 02, 2013 | Drive Medical Phoenix 3 Wheel Compact...
I need to find a stackable battery box for my scooter, as well as what batteries are needed. Also, what charger should be used with it? I bought used from a private party-no charger and the small battery...
James your scooter use 2 12-12ah batteries located inside the battery case. Just remove the screws holding the case together and remove the old batteries then replace with the new ones making sure that you repace the wiring just as you removed them from the old batteries you might also have a heat sensor attached to one of the batteries make sure you reattach that to the new batteries. Any off board charger made for power chairs or scooters will work but try to find a 4 amp charger with an on/off switch. Always turn the charger off when plugging or unplugging from the scooter Check on e-bay or with a provider for a charger Hope this helps
Nov 18, 2010 | Drive Medical Phoenix 3 Wheel Compact...
DRIVEMEDICAL PHOENIX 3 WHEEL Just bought it and charged it for 10hours. When I put battery into scooter, all the battery lights come on- 2red 1yellow 2green.....so is it charged? are the connections loose?...
Wez Thats a normal indication of a full charge. The battery level indicator will go down as you use the scooter. Always charge the scooter overnite if you use it a good bit during the day. With new batteries it will take 8-10 charging to break them in and operating at 100%. Always store fully charged and if not used alot charge once a week after you have charged the batteries 8-10 times
Hope this helps
Oct 27, 2010 | Drive Medical Phoenix 3 Wheel Compact...
How to disconnect the back-up sound oon a medical drive falcon 4
Good luck. Neil.
Jun 11, 2010 | Drive Medical Drive Falcon 4 Wheel Compact...
Drive Medical Drive Phoenix 4 wheel scooter *Free Batteries/Free Home Delivery! Logo
Top Drive Medical Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Robin Hill
Robin Hill
Are you a Drive Medical Health and Beauty Expert? Answer questions, earn points and help others
