Question about Nikon D90 Body Only Digital Camera
Nikon D90 Won't Shut Off
My new Nikon D90 will not shut off even after turning the power switch to the off position. Any simple fix?
  • M.g. Srinivasan
    M.g. Srinivasan Oct 27, 2008
    Thanks, but that is what I did the first time. When I took the battery out and reinserted it, while the switch stayed in the off position, the camera turned on again! I am looking for a permanent solution, without having to resort to warranty service.
  • Kymy Jan 17, 2009
    I am having the same problem, I remove the battery and it doesn't happen again for a while. This is just ONE of the problems I've been having!
  • 39 Answers
Try to remove the battery and put the battery back in. try to turn on and off.
Posted on Oct 27, 2008
  • geek_jim Oct 27, 2008
    the on/off switch is not working. no other way but to have it sent to warranty service
Setting nikon d90
Turn the mode dial to "M". You control the shutter speed by turning the command dial, and you control the aperture by turning the aperture ring on the lens. The camera's exposure meter is shut off and won't help with the exposure. You can shoot a picture and look at it on the display to judge the exposure.
Feb 02, 2014 | Rokinon Cameras
Memory Card Indicator always blinks
Since a couple of months, my "out of warranty" D90 is having a problem.
Even after shutting down the unit , sometimes (post of the time) the green led is blinking (at random speed) untill the battery is 100% down (after half a day).
Switching memory card , or formatting memory card does not help.
Even without lens , problem occurs.
I tried also a other battery pack , same problem...
Anyone has an possible reason why this happens , or a 100% working solution.
PS: D90, battery packs and charger are 100% genuine NIKON.
Regards, Rik
Dec 22, 2012 | Nikon DSLR D90 Digital Camera
Why can't Nikon D90 or D7000 not start up with LCD screen when turned on?
On the D90, set Custom Setting F1 to "Both". When turning on the camera, turn the switch two notches, past the "On" position to the backlight position before releasing it. This will bring up the information screen.
On the D7000, set Custom Setting F1 to "backlight and information display". Turn the camera on the same way.
It's not quite as convenient as having the information display come up automatically, but you should be able to train yourself to turn the camera on by turning the switch all the way.
Aug 08, 2012 | Cameras
Nikon D90 flashing green light runs down battery even in power off mode.
Possible short to the top cover circuit around and including the on/off switch - spillage, wear of switch.
Apr 06, 2012 | Nikon D90 Digital Camera with 18-105mm...
Nikon d80 won't turn off. Stayed on after viewing slide show on TV. Operates properly with switch in "off" or "on" position. Tried:1. removing battery. it restarts with switch...
It may be as simple as a broken or worn out on/off switch. If the switch shorts out, the camera will always be on or always be off. The problem could also be the switching circuitry. If you need service, you should call Nikon's Service Department at 1-800-NIKON-US (1-800-645-6687)9AM-8PM EST, Monday to Friday.
Sep 20, 2011 | Nikon D80 Digital Camera with 18-200mm...
Error msg CHR flashing how to get it to turn off, inserted new memory card, even in off position continues to flash. D90
Format the memory card. Press and hold the two [FORMAT] buttons until "For" blinks on the top display. Release the two buttons and then press the same two buttons again.
Sep 26, 2010 | Nikon D90 Digital Camera with 18-105mm...
D90 does not switch on
Do you have fresh new batteries for the camera?
If so and it still won't turn on, then try the following website for service for your Nikon D90:
http://www.nikonusa.com/Service-And-Support/Service-And-Repair.page
Jul 24, 2010 | Nikon D90 Digital Camera with 18-105mm...
Blinking green led even D90 is off
I couldn't find a reference to a blinking green led when the d90 is off.
I would refer you to Nikon tech support for this one.
http://imaging.nikon.com/products/imaging/worldwide/index.htm
The above link has 1-800 numbers for Nikon.
Jul 23, 2010 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 that does not want to shoot pictures
The camera may not be sensing that a lens is attached. Try removing the lens completely and then attaching it again securely.
Jan 17, 2010 | Nikon D90 Digital Camera with 18-200mm...
Nikon D90 Memory Card Access Blinking
It's a deadly common problem of D90. Fixation:Simply go to the DSLR repair shop and ask them to change the power circuit board of the camera. Will take $60-70 if the board available. Reason of issue:The power control IC get short and feedback the battery power to the battery causing the draining out and other problem like the top LCD back lamp turned ON after turning on the camera. Careful:To avoid this issue in future, after full charge of the battery, do not put it in the camera right then. Wait for the battery to cool down for 5-10 min and then put it in. With the full charge, the battery hold high ampere for a short time. It could damage the power distributor IC suddenly if you put it in the camera right after a full charge. Best, Leo>>from personal experience<<
Jun 14, 2009 | Nikon D90 Digital Camera with 18-105mm...
Nikon D90 Body Only Digital Camera Logo
315 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
