Question about Motorola Mobility A1000
Screen broke down
I hav a motorola A1000 the screen has been brokedown can any body help me,where can i replace the screen. can i found any services in auckland.newzealand.
0 characters
1 Points
My a1000 couldn't get network me
The motorola A1000 does have a signal problem, however a signal booster has been released and can be purchased by following this link:,Signal_booster.htm
May 26, 2010 | Motorola Mobility A1000
Unlock code for A1000 motorolla with imei-354911002754646
me too faced same problem with my Motorola Phone ..... My Phone also locked of no reason
i tried to get from my service provider ......... they couldn't help me ......... some friends suggested me to get it from third party..........................
then i surfed in google and other forums and found N-Number of sites ..................
then i went for highly recommended site in all forums ......... let me give you the link Click Here
Good Luck
Apr 08, 2009 | Motorola Mobility A1000
About motorola A1000
Its very simple ! What you have to do is,
Go and use it in some other country where it will work, Leave Egypt as soon as possible.
Nov 14, 2008 | Motorola Mobility A1000
Motorola A1000 will not start
This problem can be because the software is cracked after bootloader or there is not enоugh memory free. try reseting the phone. you can find keyboard combination for hard reset on internet.
Jul 02, 2008 | Motorola Mobility A1000
Motorola A1000 Internet Setup
I have a motorola a1000 too.... this phone keep lacking and im unable 2 accsess to the net... pls i need help
Feb 07, 2008 | Motorola Mobility A1000
My motorola lcd touch screen brokened
The screen of the a1000 model is composed of 2 parts, the lcd display and the touchscreen pannel wich are both secured in the same housing, protected by a metal frame. Even if you only broke the lcd screen (and the touchscreen is still ok) in most cases, a service center will replace the entire screen assembly. It will cost somewhere around $100-200 depending on wich service center you choose. If you try this operation in a service center, the costs will be greater because you will buy a new screen and pay the labour part. It would be greater if you can buy a second hand broken a1000 with a good display and change it yourself. A1000 and the P9xx series are very easy to dissasemble and work with. You may receive further informations and pictures if you reply with this request.
The short answer would be to try to avoid a service intervention to the phone. It will be very expensive. the a1000 model was made in 2003 so the spare parts that can be found today are expensive and hard to find. Try finding a second hand unit, you may strike a good deal with it.
hope this helps,
Jan 18, 2008 | Motorola Mobility A1000
Buy new screen from E-bay under twenty pounds uk.
Nov 28, 2007 | Motorola Mobility A1000
Motorla A1000
Have a look at this web site it has all sorts of advice and hints and tips to re-flash and alter settings on your A1000, i use it alot.
Oct 16, 2007 | Motorola Mobility A1000
Motorola A1000 rebooting
you will need to get the phone flashed that means get all of the phone settings and files installed again then ur phone will have none of the files u stored on the phone but if its on the memory card they will not be wiped out
Nov 16, 2006 | Motorola Mobility A1000
Motorola Mobility A1000 Logo
13 people viewed this question
Top Motorola Mobility PDAs Experts
David Payne
David Payne
Abby Carter
Are you a Motorola Mobility PDA Expert? Answer questions, earn points and help others
