Question about Aloha Housewares (93645) Ceiling Fan
Installed an Allen & Roth ceiling fan, No Manual, Can't get remote to start fan or light
Having an issue with an Allen & Roth ceiling fan. At first it was slow coming on from the wall switch so we used the remote. That worked for a while now nothing works. And it's not the wall switch.
If you're not scared to do electrical wiring, use a well-insulated pair of needle-nose pliers and jump the switch out and see if the fan comes on if it does change the switch
Dec 14, 2017 | Miscellaneous
Allen + roth santa ana ceiling fan manual
What kind of wiring diagram are you looking for? fanman9952@aol.com
Mar 10, 2016 | Dryers
Allen + Roth ceiling fan with remote Model #: LP8242LCH. The light randomly turns on. Not touching remote. Any ideas how to fix it?
Change the frequency in the receiver & transmitter. Also, stay away from store brand fans.
Nov 22, 2014 | Dryers
Allen & Roth Eastview ceiling fan. How do I reverse to pull up warm air instead of blowing air down?
Look for a slide switch on the side of the housing beneath the motor. If the manufacturer wired it correctly, the up position will pull up warm air and the down position will blow air down.
Jan 09, 2014 | Dryers
Trying to install an Allen & Roth Ceiling Fan Model#LP8062 Help it doesnt seeem like the light open to change a bulb and the blades dont come off Help?
That's just a CHEAP store brand fan. Take it back and go to a real fan store and get a fan with at least a 13 degree blade pitch or at least 5500 CFM's
Nov 03, 2013 | Dryers
I have a Allen and Roth double ceiling fan and now the light will not turn off by the pull string, so we can not have the fans on with the light off-- ANY HELP?? Its only a year old ;(
The light switch may have failed. They tend to do that.
You don't say whether your fan has a remote control, but that could be the source of your light problem as well
Jul 09, 2013 | Dryers
I have a brand new Kichler Ceiling Fan/Light installed in new home. This one for the M-Broom came with Remote UC7206T. The function which controls Fan and Fan speed works fine but I cannot the Light...
Something that may work (based on my experience). Shut off power to the fan (the circuit breaker). Remove the battery from the remote and push all the buttons just in case one is stuck. Reinstall the battery. Turn the CB on. Check operation using the remote.
Dec 29, 2012 | Kichler Lighting 300106OBB Ceiling Fan
I installed model 27303 ceiling fan with light. I had an electrician inspect the wiring to make sure everything was wired correctly, and it was. With the power on the fan/light operates with the remote...
Is it possible that there is another remote, either yours or a neighbor's, close enough to operate it?
I installed a remote operated ceiling fan & it is hard wired, there is no switch. If that happened to me, I'd be stuck never knowing when it will come on.
Can you change the remote code?
Gary
Aug 25, 2011 | Hunter Dryers
Ceiling fan is all wired up and on ceiling but light doesn't come on or fan doesn't spin. I have checked connections and tested for power. Is there a switch or anything on receiver that needs to be...
Jerry, from what you said, I assume you have a remote controlled ceiling fan. If that's the case, check the batteries in the hand held and the receiver, to make sure they are charged. Also, make sure they are installed properly. The Owner's Manual should have a reference to setting or resetting the codes for the remote control (Hand Held & the Receiver). Check those to make sure they are matching. And don't forget, the wall switch must remain ON for the fan to work, even with the remote control. The remote simply overrides the wall switch, when in operation. You may have to use the pull chain to start the fan motor the first time, then the remote can take over from there.
Good luck. I hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 10, 2011 | Heating & Cooling
Aloha Housewares (93645) Ceiling Fan Logo
799 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Mike Carew
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
