Question about RCA HD52W59 HDTV Projection Television
I am replacing the flyback transformer
I have bought a new flyback transformer, and installed it. But I can not get the wires out of the old flyback transformer to hook up to the new one, how do I do it, step by step.
  • sunshine3139 Mar 19, 2009
    How do you get the old one off?
The wires don't come off the flyback. You have to take the front cover off where the speakers are. Trace them and unplug them.
Posted on Nov 08, 2008
  • 10,594 Answers
You should post here pictures of old transformer and point out what wire you want to remove, then I can give you an idea what to do as flyback transformer is not in front of me.
Posted on Oct 27, 2008
  • matthew manning Jul 21, 2011
    i have the same one an im getting a new flyback an it dont come with wire so what should i do???
Flyback transformer
A flyback transformer is one of the more expensive components in a projection TV. If there is no clear reason, such as a known power surge, you could well replace the flyback transformer again soon because the root problem was elsewhere.
An OEM transformer is not necessary but you might have trouble convincing an authorized factory service technician to use anything but the original manufacturer's parts.
As with many of today's electronic devices, if it is more than a year or two old, you will find the new products cheaper and with more features. The next generation of projection TVs will use lasers and scanning will be done with optically controlled micro-mirrors - no flyback transformer required.
Oct 07, 2009 | Toshiba Televison & Video
Inherited RCA scenium HDTV that wont get picture or sound
100% sure it high voltage transformer it dead.
The big block of plastic with a red wire with a cap go to ur CRT(ur tv tube).It call the Flyback transformer it dead.That where the noise came from.
Sep 02, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Replacing the flyback
If your model is a HD52W59 the wires are part of the new transformer and have to be changed at the tripler and screen control block
Jan 21, 2009 | RCA HD52W59 HDTV Projection Television
Focus leads for Flyback transformer
Just use cutters to cut off small rubber part leave wire sticking out put in FBT.
Jan 18, 2009 | RCA D61W20 61" Rear Projection Television
RCA CTC203 chassis-Flyback and hot replacement
Use the one that comes with the new transformer. The old one can be removed by squeezing the sides of sucktion cup.
Dec 15, 2008 | RCA F32668 32" TV
I bought a new flyback transformer for a RCA D52W19 TV, but it came with no HV wire. How do you connect to it? Or maybe I was had?
This transformer does not come with the HV lead, you will need to use the one that is there on the old FBT. Unplug the TV for about 30 minutes to allow it to drain any voltage that might still be in the capacitors.
Remember SAFETY comes first.
Good Luck.
Jul 24, 2008 | Televison & Video
RCA D52W19 Flyback Transformer Replacment guide
The picture tube can hold a charge.with a jumper connect one end to the ground wire around the picture tub. attach the other end to a screw driver and push it under the red cap on the picture tub. that will discharge it.. Remove the transformer from the board by disordering all connections. Insert the new fly and solder. from the old transformer follow the two leads on the side to the screen board at the picture tube. one at a time connect the new transformer leads to the socket and board. part number for the FBT 259296 $50.39 from www.the parts store
Mar 21, 2008 | Televison & Video
Flyback Transformer replacement instructions?
remove solder from all pins and squeeze clips to remove...
Oct 12, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pincushion problem
My thoughts would be, was it a Sony OEM transformer or a generic type? If the latter, that is probably a likely suspect. Another thing would be misplaced wires or switches that could have been accidently moved while replacing the transformer. I have had some of these sets that had no high voltage, and all it turned out to be was a broken solder connection on one of the pins going to the flyback transformer. Usually, if the flyback is bad, the Horizontal output transistor would be also defective. It's also possible that in the process of removing the old flyback (fun job wasn't it?) you may have cracked one or more of the circuit traces in that area of the PC board.
Jan 01, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
RCA HD52W59 HDTV Projection Television Logo
1,059 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
