Question about Sport & Outdoor - Others
Year of manufacture of winchester model 61 serial number 1994504
Shoots 22 shorts ,longs ,long rifle ammo
SOURCE: winchester model 100 semi-auto 308 cal. how to disassemble?
IMPORTANT Recall info:
WINCHESTER MODEL 100 FIRING PIN RECALL - A notice dated 7-1990 relates the following
“PRODUCT SAFETY WARNING AND REPLACEMENT NOTICE. Attention owners of Winchester model 100
rifles and carbines please read this notice. In July of 1990 the following product safety
warning was issued by Winchester. It has come to our attention that the firing pin in the
Winchester Model 100 Rifle or Carbine may break due to use and metal fatigue and become
lodged in the breech bolt face. If this occurs, the firearm may fire before the action is
locked causing severe damage to the firearm and possibly injury or death to the shooter
and bystander.
WARNING DO NOT SHOOT YOUR WINCHESTER MODEL 100 RIFLE OR CARBINE. Repair and replacement.
A new firing pin has been designed to replace the firing pin originally made for the
Winchester Model 100 Rifle and Carbine. The new firing pins will be available in April
1991. If you own a Winchester Model 100 Rifle or Carbine, please send your firearm to one
of the authorized Winchester Model 100 Firing Pin Replacement Centers indicated below.
Your Winchester Model 100 firearm will be inspected, the firing pin replaced and tested
and the firearm returned to you. The inspection, replacement/testing and return postage
will be accomplished at no cost to you. If other repair or maintenance work is authorized
by you to be performed on the firearm when the firing pin is replaced, such work shall be
at your cost.”
W. R. Long Gunsmiths
2007 Brook Road North
Cobourg, Ontario K9A4W4
Canada Frank LeFever & Sons
RD 2 Box 31
Lee Center, NY 13363
USA Bolsa Gunsmithing
7404 Bolsa Avenue
Westminister, CA 92683
USA Nu Line Guns
1053 Caulks Hill Road
Harvester, MO 63303
USA
If you have any questions concerning this notice, call Winchester Product Service
1-800-852-5734 or write to Winchester Firing Pin replacement Notice, PO Box 10 Cottage
Hills Illinois 62018 Attention Product Service Dept.
The following is Wisner's rendition & info on the subject.
The difference in the old firing pin and the new one is as follows. The old replaced
style, was totally lathe tuned (round). While the new recall style is similar in lathe
turning on the front and back, but in the front midsection it has two flats milled, one
on each side. This makes the center section stronger. Also replaced is the bolt sleeve
lock pin (firing pin guide) which was made to accommodate this different shaped firing
pin
Part number for the new parts are, firing pin =1391ND, bolt sleeve locking pin =1491ND
The word was at the time this recall was in process was that if the firing pin would
break at the mid section and still remain in the gun as two pieces, the possibility of a
premature discharge before the bolt was locked was possible. This apparently was caused
by the firing pin tip (now not having a retracting spring) to be stuck forward, and
thereby slam-firing upon chambering.
The responsibility for the recall apparently was on Olin, as they were the parent company
at time of manufacture. Olin set up regional recall centers at three established US
gunshops. There was a manufacturing delay in the replacement firing pins, and a backlog
occurred, also some collectors did not like the idea of shipping their guns long
distances. Olin then also authorized other gunshops to make the required alterations.
Upon completion of the recall, the shops were to test fire the firearm and to stamp an
assigned letter on the inside top of the receiver as seen thru the magazine well with the
bolt retracted. The letter “B” represented Bolsa Gunsmithing, “L” was Lefever, and “N”
was for Nu-line Guns. The letter “X” apparently was for all the other independent shops.
However this identification information did not get communicated to some of the smaller
shops at the start of the project. The only way to tell if the gun as been modified, if
the ”letter” is not present, is to take the barrel & action out of the stock, remove the
trigger guard assembly and the try to rotate the firing pin by twisting it. If it does
NOT rotate, then the firing pin recall HAS been performed.
For link back to the parts & price list that we make & have for sale CLICK HERE
Copyright © 2004-2007 Wisner's Inc. All Rights Reserved
Back to Additional information To Winchester model 88 & 100 parts
Originated 01-13-2001 Last Modified 03-19-2007
LeeRoy Wisner
Posted on May 20, 2009
bigcass
  • 35 Answers
SOURCE: looking for the age of a Remmington model 121
Cant give you an Exact but I can give you the Manufacture Years:
Manufactured from 1936-1954
Posted on Oct 18, 2009
cuvilldj
  • 14 Answers
SOURCE: where is the serial number located on a remington
693f0fe.jpg Introduction Year: 1936 Year Discontinued: 1955 Total Production: Approximately: 12,200 Designer/Inventor: C.C. Loomis, A.L. Lowe, K.J. Lowe Action Type: Bolt Action – Clip Magazine Caliber/Gauge: .22 Long Rifle Serial Number Blocks: Starting: 00001
Ending: 12300 Grades Offered: Model 37 Rangemaster
37 Target
37AR
37AF
37AX
37AM
37AV
37AS Variations: None
Posted on Dec 11, 2009
  • 3 Answers
SOURCE: Model 74 22 long rifle jammed and cannot eject the
at the back of the rifle there is this small ''switch'' . pull it back and the casing will be loose. pull it out. i think its visual c++ model 390
Posted on Jul 02, 2010
kicks like a jack ! if u know what i mean. ur right its not cool for the barrel to ride on the wood ! and on this weapon the trigger is hard to squeeze! and loud ..sometimes im a littel gun shy!. it will shoot straight if u hold r steady. remember squeeze the trigger not pull. an a lot of practice!
Posted on Oct 31, 2010
Winchester model 70 xtr 7mm mauser featherweight g1554069 what year mnufactured
What year was my Winchester manufactured Serial Number Reference
www.winchesterguns.com/support/faq/date-your-firearm.html
Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. Below is the download link for a special resource for ...
[PDF]Winchester Repeating Arms -- Date of Manufacture by Year -- Scans of ...
www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-D... Winchester Firearms Manufacturing Dates by Serial Number and Year ... ASSIGNED TO GUNS AT THE END OF THE CALENDAR YEAR. 1866 -. 67 -. 68 -. 69 -. 70 - .... YEARS OF THIS MODEL AND IT WAS THEREFORE DlSCONTIN UED IN ...
What year was my Model 70 manufactured? - Winchester Repeating ...
www.winchesterguns.com/support/.../what-year-was-my-model-70-manufactured.htm... To obtain date of manufacture on a Model 70 made after 1992 please contact the Winchester Customer Service Department at 800-333-3288. In the event of alteration or the serial number being expunged, the BATF needs to be advised.
Date Your Model 70 and 94 - RifleShooter
www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803/ Nov 3, 2010 - Winchester's Model 70 bolt-action rifle is without a doubt, one of the ... rifle was made, the tables below show serial number range by year made ...
Model 70 - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=winxx70.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 70: Covering numbers: 1 - 1537135. Please enter a serial number and click the submit button.
May 21, 2018 | Winchester Optics
What year and make is my winchester rifle 36' long?
length is neither here nor there, and your 'make' is Winchester :>)
Winchester has a great serials search feature.
Google
Winchester <model> <calibre> serial number
model info
Winchester rifle - Wikipedia
https://en.wikipedia.org/wiki/Winchester_rifleWinchester rifle is a comprehensive term describing a series of lever-action repeating rifles manufactured by the Winchester Repeating Arms Company.
winchester rifle serial number look up Google Search
Feb 11, 2017 | The Computers & Internet
Hello anybody know
Yes, I do but please don't post disjointed posts like this one. You can bring your original post up be clicking Want Answer. If you rally want to repost, elaborate on what you said before.
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... date of manufacture and value: Click here to go to our gun values resource links.
[PDF]Winchester Firearms Manufacturing Dates by Serial Number
www.winchesterguns.com/.../winchester.../serial-number.../Winchester-Manufacture-...
  1. Cached
determining date of manufacture and value: Click here to go to our gun values ..... *TOO POST-64 MODEL 94 BEGAN WITH SERIAL NUMBER 2,700,000.
Winchester Model 94 Serial Numbers - Gun Collections Online
guncollectionsonline.com/winchestermodel94.htm
  1. Cached
  2. Similar
Winchester Model 94, winchester model 94 values, Winchester 1894, winchester model 94 prices, model 94 rifle, winchester lever action, 30-30 lever action.
Serial Number info for Winchester Model 94 - The Firing Line Forums
https://thefiringline.com/forums/showthread.php?t=322230
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Serial Number info for Winchester Model 94 The Harley Nolden Memorial ... and find dates and serial numbers on The Winchester Model 94 30 30 ? ... I am thinking of trading the rifle for a 270 or 308 but want to verify its value. Winchester 94 w/no serial 18 posts 2 Oct 2007 Winchester 30-30-model 94 Pre or Post 1964? 25 posts 12 Nov 2004 More results from thefiringline.com
Blue Book of Gun Values - WINCHESTER FACTORY WINCHESTER ...
bluebookofgunvalues.com > Gun Values > WINCHESTER
  1. Cached
  2. Similar
Add $50-$75 over individual prices for consecutively serial numbered rifle and ..... Model 94 rifle in .30-30 Win. cal. with octagon barrel, extensive C. Giovanelli scroll ... Other special issue receivers were used that bear this serial number as the ...
What Is The Year And Value Of My Winchester Model 94 Serial Number ...
www.gunvaluesboard.com/what-is-the-year-and-value-of-my-winchester-model-94-s...
  1. Cached
  2. Similar
May 7, 2010 - I have a winchester model 94 30/30 lever action rifle . The serial number is 1208774. It is in mint condition. I was wondering what this gun is worth. Reply. avatar. Winchester Model 94 Pre 1964 Serial Number 1105022 4 Nov 2012 Where Is The Serial Number Located 31 May 2010 Winchester Model 94 8 May 2010 Winchester Model 94 30 Wcf Pre-64 6 May 2010 More results from www.gunvaluesboard.com
Value Of A Model 94 Winchester Rifle 30-30 Serial Number Is ... ' Gun ...
www.gunvaluesboard.com/value-of-a-model-94-winchester-rifle-30-30-serial-numbe...
  1. Cached
  2. Similar
hey wiz sorry to interrupt and i know it is rude but i have a very poor money situation and need to sell this similar winchester model 94 30-30 the serial # is ...
Model 1894 (Mod 94) - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1894.dat
  1. Cached
  2. Similar
Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
Jan 08, 2017 | Cell Phones
It has this number 22s10r1r on it can you tell me what my 22 pump winchester rifle model 61is worth i think it was made in 1945
Here you go Gayla. Remember though, condition is everything. If you want to check the date, google;
Winchester model 61 serials
winchester rifle model 61is Google Search
Dec 28, 2016 | Winchester Optics
Win 1894, s/n 857903, in 32-40. How common is this?
in 32-40 fairly unusual it would appear. Lots of information for you here.
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year ... totally accurate database of serial numbers from 1866 forward that we are aware of.
  1. Cached
totally accurate database of serial numbers from 1866 forward that we are aware of. ... 94 -. 95 -. 96 -. 97 -. 98 -. 99 -. MODEL 1866. 2. 12476 TO 14813. 15578 .... 32-. 1087836. 62-. 2551921. 03·. 291506. 33 -. 1089270. 63 -. 2586000. 04 - ... 40 -. 1142423. 70-. 3381299. 11-. 599263. 41 -. 1191307. 71-. 3557385. 12 -.
Winchester Model 94 - Gun Collections Online
  1. Cached
  2. Similar
Winchester Model 94, Winchester model 1894, 30-30 caliber, lever action ... The post-64 Winchester model 94 begin with serial number 2,700,000. ... .38-40 Winchester, and .44-40 Winchester, .410 shotgun, 30-30 caliber (30 WCF), ... began with Serial Number 1 and the Winchester Model 94 Serial Numbers run more or ...
  1. Cached
  2. Similar
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 30 30 ? ccookin is offline ... Winchester 94 32-40 21 posts 13 Mar 2013 Original winchester model 1892?? 10 posts 19 Jul 2010 Winchester 30-30-model 94 Pre or Post 1964? 25 posts 12 Nov 2004 More results from thefiringline.com
Winchester 1894 date of manufacture. - Shooters Forum
https://www.shootersforum.com/winchester-94.../66444-winchester-1894-date-manuf...
  1. Cached
  2. Similar
Jun 22, 2010 - 5 posts It seems that date of manufacture numbers are probably off as much as two years in this time frame. .... Winchester's production of the Model 94 averaged about 35,000 units per .... 32-40 Rifle - serial number 692, 12-14-1894
Blue Book of Gun Values - WINCHESTER RIFLES: LEVER ACTIONS ...
  1. Cached
  2. Similar
WINCHESTER RIFLES: LEVER ACTIONS - 1860-1964 gun model and pricing information. ... lever latch, adj. sporting type rear leaf sight, serial numbers are in three digits only. ... .32-20 WCF, .38-40 WCF, or .44-40 WCF cal., iron frame with sideplates, .... 1940-1964 mfg. without saddle ring, barrel is marked Model 94.
Model 1894 ' Winchester Collector
winchestercollector.org/models/model-1894/
  1. Cached
  2. Similar
.32-40 - introduced in 1894 ... As serial numbers approached the one-million mark, the official model ... The Winchester Model 1894 Saddle Ring Carbine
Win 1894 857903 in 32 40 Google Search
Nov 15, 2016 | Computers & Internet
Serial #3506979
any one of these sites will help you find the serial number and date of manufacturer. The forums will help with values, or the Blue Book of Gun Values.
  • Model 1894 (Mod 94 ) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Dates of Manufacture* for: Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, Vol. 3, The Models of 1894 and 1895 by Arthur Pirkle.
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm 41 rows · Gun Collections Online. Specialists in Marketing Your Gun Collections ...
  • Related searches for winchester model 94 serial numbers
  • Serial Number info for Winchester Model 94 - The Firing ... https://thefiringline.com/forums/showthread.php?t=322230
    • 109 POSTS
    • FIRST POST: 2008-11-27
    2012-08-04 · I have a Winchester model 94 serial # 2775xx3. The chart in this thread for serial # id show a lapse between 64 and 65 models. The 65 models all start with ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms What is the age and value of a Winchester Model 94 serial number 3910875? ... What is the age of a Winchester model 94 serial no 1929746?
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification PRE-64: The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • What Is The Year And Value Of My Winchester Model 94 ... www.gunvaluesboard.com/what-is-the-year-and-value-of-my-winchester... What is the year and value of my Winchester model 94 serial number 5271797?
  • Value Of A Model 94 Winchester Rifle 30-30 Serial Number ... www.gunvaluesboard.com/value-of-a-model-94-winchester-rifle-30-30... also have 3 winchester model 94 32 specials all are in fair condition stocks are worn and bluing has light scratches serial numbers are 3133157...2822367...2889678 ...
  • Model 1894 ' Winchester Collector winchestercollector.org/models/model-1894 ... the Model 1894 became the first Winchester ... The 1,000,000th Model 94 was presented ... from serial number 1 thru 353999. The Winchester Model ...
  • Jul 19, 2016 | Winchester Model 94 Short Rifle .30-30 20...
    I got a win model 70 308 serial number 862911
    You don't say, but I presume you want the date of manufacture?
    http://oldguns.net/sn_php/winmods.htm
    Other info for you.
    1. Date Your Model 70 and 94 - RifleShooter www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803 These tables indicate the years of production for the Winchester Model 70 and 94 rifles ... Date Your Model 70 and ... the tables below show serial number range by ...
    2. Winchester Rifles Modern Bolt/Auto/Single Model 70 For ... www.gunsamerica.com > ... > Login To Save This Search Winchester Rifles Modern Bolt/Auto/Single Model 70 for sale on GunsAmerica. Find guns for sale, gun auctions and more on GunsAmerica.
    3. Winchester Model 70 rifles (Win. Model 70) - Chuck Hawks chuckhawks.com/win_70.htm Chuck Hawks shares information about the Win. Model 70 ... .264 Winchester Magnum, .270 Winchester, 7x57 Mauser, .300 Savage, .308 ... the Winchester Model 70 has ...
    4. Related searches for win model 70 308 serials
    5. Winchester Rifles - Model 70 Pre-64 For Sale www.gunsinternational.com > Rifles Browse all new and used Winchester Rifles - Model 70 Pre-64 for sale and buy with ... Pre 64 Model 70 Alaskan in 338 Winchester Magnum Caliber. Serial ...
    6. Winchester Repeating Arms www.winchesterguns.com The Winchester Model 70 in Vietnam. ... "The Prize for Capturing Geronimo" about the famed serial number one, 1886. Read the article on the Rock Island Auction website.
    7. WINCHESTER DATES OF MANUFACTURE - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... Model 70 Model 72 Model ... Model 59 Shotgun ...
    8. Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 The Winchester Model 70 series rifles are marketed as sniper rifles for military forces and law enforcement agencies under the ... .308 Winchester.300 Winchester ...
    9. Winchester Model 70 Information - MGW www.midwestgunworks.com > ... > Winchester Model 70 Winchester Model 70 Information ... and there are many "legends" about why the historic serial number records for Winchester rifles and ... .308 Win: Long Action: 7 5 ...
    10. Blue Book of Gun Values - WINCHESTER RIFLES: BOLT ACTION ... bluebookofgunvalues.com/Gun_Values/Manufacturers/WINCHESTER/... (new 2006), .308 win., ... model 70 custom special "70 years of the model 70" get pricing.270 win., ... winchester rifles: bolt action - post 1964 model 70 custom grades
    11. Winchester Model 70 Featherweight ( Pre ' 64 ) .308 Win ... www.cabelas.com > Gun Library > Wheeling Gun Library ... Winchester Model 70 Featherweight (Pre '64) .308 Win ... Shown: null. More Views: Additional Media: Winchester Model 70 Featherweight (Pre '64) .308 Win. Caliber ...
    12. Pagination
    May 24, 2016 | Optics
    Can you tell me the model of my 270 winchester rifle serial number is G1871685
    This is more specific to decoding your serial number as the other information I gave was on your Model 70.
    [PDF]Winchester Firearms Manufacturing Dates By www.winchesterguns.com/.../winchester.../serial-number.../Winchester-M...
    1. Cached
    Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. The following pages were scanned from documents ...
    What year was my Winchester manufactured? (Serial ...
    1. Cached
    2. Similar
    1. Cached
    2. Similar
    Dates ' Winchester Collector
    winchestercollector.org/dates/
    1. Cached
    2. Similar
    When was Your Winchester Made? ... Serial Number ... the dates of manufacture shown were obtained from the original Winchester Factory Polishing Room ...
    Winchester Serial Numbers - ProofHouse.com
    www.proofhouse.com/win/index.html
    1. Cached
    2. Similar
    Main Page. Lever Action Rifles Slide Action Rifles Bolt Action Rifles Semi-Auto Rifles Shotguns Military Misc. Lever Action Rifles top. Walter Hunt's Repeater
    Winchester Dates - ProofHouse.com
    www.proofhouse.com/win/winchester.htm
    1. Cached
    Serial numbers of the Henry rifle overlap those of the model 1866 from 1865 to 1866. .... George Watrous, a Winchester employee, counted total production at ...
    1. Cached
    2. Similar
    1. Cached
    2. Similar
    Our database contains values of serial numbers through 5103248 which ended the year 1982. Our sources disagree a bit, but this seems to be the best set of ...
    1. Cached
    2. Similar
    Nov 3, 2010 - We bought a Winchester model 70 with serial number G1741812. ... Kurt. Where can I find manufacture dates for Winchester Model 1894 rifles?
    Winchester Model 1894/94 Factory Records - Shooters Forum
    https://www.shootersforum.com/winchester.../67350-winchester-model-1...
    1. Cached
    2. Similar
    Aug 12, 2010 - 7 posts It should now very clearly show the progression of verified dates of manufacture. I do not plan to add any additional new serial numbers to the ...
    1. Cached
    1. Cached
    2. Similar
    1. Cached
    2. Similar
    1. Cached
    2. Similar
    1. Cached
    2. Similar
    1. Cached
    1. Cached
    2. Similar
    1. Cached
    2. Similar
    1. Cached
    2. Similar
    1. Cached
    2. Similar
    May 01, 2016 | Optics
    I have a winchester ranger 270 cal. Rifle . Was wonde ring what model it is .... the serial number is G1871685
  • Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 ... 6.5×55mm, .264 Winchester Magnum, .270 Winchester, ... 70 Winchester rifles is the serial number ... the Winchester Model 70 rifle and Winchester Model ...
  • What is the value of Winchester ranger 270 caliber Serial? www.answers.com > ... > Firearms > Winchester Firearms Answer The Winchester 270 .22 was first introduced in 1963. It is not a collector item, or "rare". It is however a very good .22 rifle which should be enjoyed as ...
  • .270 Winchester - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/.270_Winchester Large rifle: Maximum pressure: 65,000 psi (450 MPa) Ballistic performance; Bullet weight/type Velocity Energy; ... The .270 Winchester (or 6.9x64mm) ...
  • winchester ranger .270 - Shooters Forum https://www.shootersforum.com/.../31131-winchester-ranger-270-a.html
    • 16 POSTS
    • FIRST POST: 2006-07-18
    2006-07-24 · Shooters Forum > Rifle and Rifle Cartridges > Rifles and Rifle Cartridges: winchester ranger .270 ... Winchester. Think push-feed M70 serial ... Ranger" mean? Caliber ...
  • What Is The Value Of A Winchester, Model 70, Cal. 270 ... www.gunvaluesboard.com/what-is-the-value-of-a-winchester-model-70... What is the value of a Winchester, Model 70, Cal. 270 ... of a Winchester, Model 70, Cal. 270 rifle. Serial number ... a Winchester model 70 270 cal the serial ...
  • 575 - Winchester Ranger .270 cal bolt-action rifle. Only ... www.proxibid.com > Firearms & Military Artifacts 575 - Winchester Ranger .270 cal bolt-action rifle. Only fired off one box of ammo.
  • Ranger T - Winchester LE winchesterle.com/Products/handgun-ammunition/ranger/t-series/Pages/... Ranger; T-Series; T-Series. When a ... Winchester T Series is ammunition that always performs at its best-even when things are at their worst. ... Rifle Ammunition ...
  • Winchester Ranger (M70?) .270 Win ' Gun Values Board www.gunvaluesboard.com/winchester-ranger-m70-.270-win-8295726.html I have a Winchester Ranger Serial # 5352836, 30-30 cal. Has a ... Tips for finding accurate ammunition for a .270 Win. chambered rifle. ... 1985 Winchester Ranger ...
  • Is a Winchester Ranger 270 cal a long action rifle? - Answers www.answers.com > Categories > Hobbies & Collectibles > Firearms Is a Winchester Ranger 270 cal a long ... What will excite ANSWERS.COM users for them to go ... The .270 Winchester is a great rifle for medium sized game such as ...
  • 270 Winchester Caliber Rifles for Sale - Online Gun Store ... www.ableammo.com > ... > Firearms > Rifles > Shop by Rifle Caliber We carry 270 WINCHESTER caliber rifles for sale in our online gun shop, including hunting rifles, tactical rifles, and more. We stock Browning BLR rifles, Remington ...
  • May 01, 2016 | Optics
    Sport & Outdoor - Others Logo
    79 people viewed this question
    Top Sport & Outdoor - Others Experts
    Bill Eager
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
