Question about Samsung Dryers
Dryer is blowing cold air - Samsung Model DV209AEW/XAA
Model Number DV209AEW/XAA Possible solutions
  • 112 Answers
SOURCE: the dryer only blow out cold air.
I would start by checking the continuity of your thermal fuses on the unit. You will have at least one and they will be located around the heater element or ducting near the heater element. If they check out good, check to see if you have an open element.
Posted on Oct 18, 2008
kachbibi1
  • 979 Answers
SOURCE: electric dryer blowing cold air
You either have a blown fuse, breaker, burned out element, wiring that has come loose. They all can be checked within 5 minutes. However, I believe it is in the thermal fuse which is located below the top of the dryer. You can access that pretty easy though. To check it, just bypass it and put the 2 wires together and see if it runs. The fuse is only 15 dollars or so. I am assuming you have an electric dryer.
Posted on Jan 26, 2009
SOURCE: Dryer blowing cold air only
older homes with fuses can have to fuses on the dryer circut-1 could blow and the dryer would run without heat
Posted on Jun 20, 2009
  • 3 Answers
SOURCE: I have a samsung dryer
This photo is from a Samsung DV409AEW, but I assume they are quite likely the same. I also turned the drum (clockwise, which is the wrong way) and the same thing happened. The thud in my case was the spring that holds the tension pulley arm in place falling to the bottom of the dryer. If your situation is the same, spinning the drum caused the belt to come off of the idler pulley and the tension spring fell off. It seems to happen frequently based on web searches.
Again, assuming the DV409Axx is the same, you can get at it from behind. There should be 3 screws (2 on the top and 1 on the bottom) of the plate that holds the vent pipe output assembly. That assembly can then be removed. There will be a vent pipe extension that comes out with the assembly.
Once inside, see if the spring is off, and if so re-attach it per the photo below. It is counter-intuitive that the spring pulls the arm down, rather than to the left. Hopefully this will be your issue.
Putting the pipe extension and outlet assembly back in can take a bit of fiddling... but if you lay on the floor, you can actually shine a flashlight in the crack to see what you're doing.
Hope this helps!
Posted on Dec 01, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
My samsung dryer dv330aew/xaa wont heat up is there a reset switch?
you can check the element with a multi meter for continuity. may also want to check the hi limit thermostat and the cycling thermostat, do u have full voltage at the terminal? sometimes a tripped breaker will give you half voltage say 110 instead of 220 and what u get is enough power to run the dryer motor but not the heat as it takes a full 220 to run heat
Sep 08, 2014 | Samsung DV330AEW Dryer
WHAT DOES ts error code on a samsung dryer
A ts error means that there is either a thermistor short or the vent is blocked. First check the entire dryer vent from the dryer to the outlet. Clean any lint build up and make sure that the vent isn't constricted around any objects if you have flexible ducting. Check that the flap hasn't shifted to block the vent outlet. (I've seen this a few times.)
If that doesn't solve the problem, replace the thermistor. It's part 7 on this diagram: http://www.searspartsdirect.com/partsdirect/part-model/Samsung-Parts/Dryer-Parts/Model-DV209AEWXAA0000/1482/0151200/50039356/00005?blt=06&prst=&shdMod= . If your dryer is still under warranty, contact Samsung for the repair.
I hope this helps.
Sep 05, 2014 | Samsung Dryers
Dv209aew/xaa therm
u may have a bad motor windings problem, usually will rund for about 25 minutes to an hour then shut off, wait an hour and can run again then shuts off ? also check ur venting inside machine and to the wall a build up can cause it to overheat and then shut down? u may have to remove cabinet to see inside condition? which thermostats did u change, u may have bad hi-lo limit and cycleling thermostat
Jul 28, 2014 | Samsung Dryers
Samsung dryer DV209AEW/XAA, How does the belt go on the pulley system in the back of the dryer? Can't seem to get it tight.
I never fixed a thing in my life and thanks to Macmarkus, who was right on the mark with what was wrong with my dryer, I was able to make the repair without uttering one cuss word. I didn't have to spend a dime either. Thanks so much. Rich
Aug 26, 2011 | Samsung 7.3 Cu. Ft. Electric Dryer
I need to replace the belt on my dv209aew dryer, I need to take my dryer apart and put it back together
Hi lisavawter...
Your best bet is to buy a service manual, so it will tell you everything you need to know about servicing your dryer...
You can get one at this webpage...
Please take time to rate me
http://www.samsungpart.com/Products/Parts_and_Accessories/DV209AEW/XAA/Default.aspx
Aug 12, 2011 | Dryers
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
Have a samsung dryer model DV209AEW/XAA. I "hand
Dec 03, 2010 | Samsung 7.3 Cu. Ft. Electric Dryer
Dryer works but is only blowing cold air. just bought the dryer last year and have already had it repaired once.
my Samsung was in a flood(so solution may only apply to floods), changed heater assembly, still blowing cold air, turned out to be the little black box on the generator, took box cover off,cleaned the connectors in box and voila...instant heat
Nov 28, 2009 | Samsung DV448AEE Electric Dryer
Dryers Logo
69 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
