Question about ASUS Computers & Internet
An9 32x error code 9.9
Power went off during a power outage. turn computer back on and only booted up one time. after i put it to sleep for the night(win7), it would not boot up since.
dmathwizard
  • 113 Answers
SOURCE: an9 32x
I think you want the drivers to the ABIT Fatal1ty AN9 32x its
<A href="http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&pMAIN_TYPE=Motherboard&pTITLE_ON_SCREEN=AN9+32X&pSOCKET_TYPE=Socket%20AM2">here</A>
Posted on Mar 10, 2009
Kimi
  • 277 Answers
SOURCE: fan error during boot-up
Power supply, that can be the cause. Did you try disconnecting few devices to check if the CPU fan has enough power to turn itself on. Usually motherboard will have two connectors for the CPU fan, you may try connecting it directly to the power supply. Also Check through the BIOS and see if there is a setting to disable the CPU Fan monitor (Hardware Monitor??) It should be where the temps and voltages are. The BIOS in most computers has an option to monitor a CPU fan. If none exists, then the option needs to be disabled. I am assuming the error is occuring during the BIOS stage of bootup. If the error occurs in Windows, it may be that some software has been installed to monitor a fan that doesn't exist. Sometimes monitoring software comes on the motherboard CD and someone may install it, thinking it is a driver. It is not necessary. Good luck!
Posted on Jan 15, 2006
  • 452 Answers
SOURCE: computer powers off while booting, green light stays on!
1. check the cpu fan is properly working with normal speed..
2. go to bios setup and restore all settings to default.
3. if windows start and problem comes after some time , then it might be virus. so, go for a virus scan.
Posted on Oct 15, 2007
Drummernick
  • 440 Answers
SOURCE: dell dimesion 4600 won't boot up
u try to just hold in power button shut down all way for min then back on
Posted on Feb 09, 2008
map9966
  • 2351 Answers
SOURCE: MSI P6NGM won't BOOT
You should only hear 1 beep. That 1 beep is power on self test, known as P.O.S.T.
That loud flat line sound (And I'm pretty sure about this), was you're CPU. Just because you ran & passed the stressed test is nothing compared to running the system under load? That's why when you put in you other memory nothing changed. If you hadn’t mentioned you clocked up the FSB I would have come to the same conclusion hearing the loud flat line statement.
Can you test the CPU in another board? That is about the only way to be sure it's not the CPU. Memory does not make that kind of sound. Memory makes short & long beeps.
You can try clearing the cmos/bios by going to pg. 2-18 in you're user manual. This will reset the bios back to default settings & cross you're fingers!
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Posted on Apr 27, 2008
Hello, After putting my computer, hp pavilion m7690n, to sleep last night. I woke up to see it was turned off so I went to hit the power button to start it up but it didn't show any power because the...
It's possible that your computer froze during sleep. First, unplug the power cord, (with the cord removed) press the power button for 10-20 seconds. PS: You will lose any unsaved data prior to sleep mode. Let me know if this doesn't resolve your problem, might be something major.
Jul 01, 2013 | Computers & Internet
HP DC7800 doesn't wake up
Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity The computer will power-down and turn off unnecessary systems, including the monitor, while keeping the memory active so it can start back up quickly and still have all programs up that were being used prior to entering sleep mode. While this is a helpful feature that can extend the battery life of a laptop, it can result in errors where the computer won't power back up. You can usually solve the problem quickly.
Look for a sleep-specific key on the keyboard. It will usually be near the top row and have a symbol of a moon on it. Press this key as some laptops only respond to that command to come out of sleep mode. Press the "Enter" key to see if that will cause the computer to respond. Move the mouse back and forth several times and click the mouse button. Hold down the power button for 5 seconds if the previous methods have not worked. This is another common method for exiting sleep mode for many laptops. It may also trigger a full computer restart which would also solve the sleep mode problem. Unplug the laptop and remove its battery.
Reinsert the battery and then plug the laptop back in.
This should cause a full restart when the power button is pressed. Download the latest video drivers from the website for your video card manufacturer. Old drivers can sometimes cause problems with the laptop's power functions. See if your computer manufacturer has an updated BIOS on its website. The BIOS (basic input/output system) is the firmware that controls the initial boot processes for your laptop. Computer companies will release updated BIOS firmware if they get multiple complaints of boot or power problems. The BIOS interfering with Windows Power Manager is a frequent cause of sleep mode problems. Adjust your BIOS settings by rebooting the computer and pressing the appropriate function key when prompted on start up. It will normally be F1, F2 or F3, and you will often see a message during start up saying to press that key to enter the BIOS. Experiment with the BIOS settings by scrolling through the menu and locating Power Management. Increase the amount of time the BIOS allows before hibernating to make sure it is higher than the the Windows power setting. This can help eliminate conflicts between the BIOS and Windows concerning power shutdowns.
Jan 28, 2013 | Computers & Internet
Hello there, I have a problem I don't know how to resolve. My motherboard is M4A88T-M USB 2.0 with Phenom II X6 1090T Black Ed. Today, while my pc was in stand by mode there was a power outage but was it...
If your systemwill start in "safe mode" you can try a a'system retstore" back to when it was working.
Let me know if this helps through "add a comment" at end of soloution.
Dave
Mar 13, 2011 | ASUS M4A88TM Motherboard and AMD...
Computer won't start, solid amber light, no fans, no keyboard, nothing. There is power to monitor and modem. What's wrong and how can I fix it?
That my Friend is the Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, during a power outage with no surge protected, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Sep 21, 2010 | Dell Inspiron 530 Desktop Computer
My laptop battery/preparing to hibernate
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
if it boots up to your operating system
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Mar 07, 2010 | Samsung NC10-14ROBL Notebook
Computer will not boot up after power outage while running update
OK well if you can boot into Safe Mode, press F8 at bootup, then do so, and try a System Restore, back to a time before you had a problem Otherwise you will have to re-install your Operating System.
Feb 09, 2010 | Compaq Presario 2538CL Notebook
Monitor falls asleep during/after startup
control panel
click power settings
set the monitor to never sleep or dim
same on all windows.
the monitor is totally programmable
why not tell OS?
windows 10?
or google
why does my windows 10 monitor go to sleep
10,000,000 hits
endless.
the defaults under windows, are always wrong,
it's to keep the FEDs happy with there Energy Star bs.
im on laptop now far far from USA
set it all to not use sleep etccetra.
Feb 28, 2017 | HP Computers & Internet
Waco cintiq
We had the same peoblem with our tablet: no sync/ go to sleep. We tried re booting the computer-no luck. We tried turning on and off the tablet.-no luck. The solution for us was simple: unplug the power source, wait a minute, plug it back in. Voila! It worked. I know we had a power outage the night before, so perhaps the problem was associated with the outage.
Hope this solution helps someone!
Jul 19, 2008 | Wacom Cintiq 15X Graphic Tablet
Computers & Internet Logo
76 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
