Question about Dryers
Not drying I have a model MDG8600AWW the burner burns for a short time then shuts off but comes back on after a short time.But the clothes take forever to dry and all the vents are clean and the inside is clean.
    President:
  • Dryers Master
  • 2,651 Answers
Common cause for dryer taking to long to dry, (vent related issue) so long as thats be rectified, the next issue would be to look into replacing the coils atop the burner vale, part number 279834, retail for about $20, easy enough to change. although they appear to open the gas valve initially, after running for 30 min or so they overheat and no longer open the valve, extending dry time.
Posted on Oct 27, 2008
Clothes not dry when dryer shuts off
First turn off your breakers, then back on. Next check the wiring at the back of the dryer. You could have wires burned in two. You may next have an element that is burned out. Your relay switch underneath the top could be bad. To check it , bypass it by taping the two wires coming off it together. If it works, then you will know it is the relay .
Mar 01, 2013 | Fisher and Paykel DEGX2 Dryer
I was just cleaning my cooktop and now I'm getting a constant ticking noise. I turned all burners on, left them on a short time, turned them off and it's still making the fast ticking noise. Is...
what that clicking is , is the ignitor trying to light the burner, its electronic, and if it continues it will eventually burn out, more than likely what happened is that moisture from cleaning got into the knob and control for that specific burner, and needs to dry out before it burns out, , you can try turning that one burner on and off a few times o see if that shuts it down, if it doesn't,, unplug the unit, and wait until it dries out on its own
Sep 14, 2011 | Whirlpool Kitchen Ranges
Have a Kenmore 90 series gas dryer model 110. 72922188 that won't come up to heat and dry the clothes...Popped the front, cleaned all the lint areas, checked the cycle knobs for proper setting, tub/ motor...
aslong as the ignitor is glowing red then a click frome the flame switch and lights the burner tube and continues to repeat this over then dryer is ok ...... take venting off back of dryer and do a test load .... that will solve if it's a venting problem... if dryer dryes clothes with venting off back of dryer then it is a venting problem ..... from vent tube to out side exhaust... if dryer dosent dry clothes with vent off then u need to replace the gas coils black cylinders on top of gas valve... cost around $30.00 and very easy to installl 2 phillips screws in bracket cap on top of the coils slide off and replace one at a time there is a large coil and small coil and they both come in same kit and need to go back in the same spot they came off in ....part numbers..# 306106 306105 or recheck your model number off dryer data plate and order off sears.com
Jan 28, 2011 | Kenmore Dryers
Dryer burner burns for a short time and gose out then relites. cloths don't get dry
Might be a loose blower wheel or clogged filter housing causing an air restriction. Check you outside vent and pipe for restrictions.
Mar 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer burner does not kick on every time that I use the dryer. If I hear the heat kick on, the clothes will dry, but if the heat does not come on, the clothes will tumble on just a cold air dry and the...
Replace both coils on the burner valve . After heating up , they will not open to let gas thru again until cooled down for a short period of time . With no heat , timer will not cut off unless set for timed dry .
Aug 09, 2009 | Maytag Dryers
Ignites then burner shuts down then rignites over and over wont dry
Check your connecting exhaust vent for a blockage.
Remove the vent and run a 45 minute timed dry load and see if it works correctly.
Report back.
Apr 12, 2009 | Dryers
Whirlpool dryer model LER7646EQ1
Thats what it's supposed to do hopefully the clothes are coming out dry. The dryer has both thermal sesors and fuses that tell the dryer when to heat up and when to cool down. So yes the heating element will come on and go off multiple times in a cycle.
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Low dry temperature
check your air flow it could be a clogged or pinched vent pipe
Dec 20, 2008 | Maytag Neptune MDG9700A Gas Dryer
LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Dec 01, 2008 | LG DLG5932W Gas Dryer
Dryer is gas model dg212 flame come on but will not stay on long enough to dry clothes
if burner lights but fails to relight after several shut offs suspect burners solenoids change both they come in a kit ..once the solenoids get hot they will sometimes open electrically and fail to reenergize after cool down they will open gas valve and alow burner to reignite..also be sure vent to outside to clean and vent behind dryer is not flattened or kinked has know flame to not be properly burning due to exhaust problems and flame sensor would shut burner down
Sep 16, 2008 | Maytag Dryers
Dryers Logo
160 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
