Question about Home Security
Access master M200 garage door opener - Home Security
  • 3197 Answers
SOURCE: Garage door does not function makes couple of buzzing sounds only
Remove the cover and check out the drive gear. It is white nylon and is probably stripped.
Posted on Jun 01, 2009
  • 3197 Answers
SOURCE: Access Master Garage Door Opener opens by itself
The most common cause of this is a bad wall control or the wiring going to it. The wall control goes bad from use and the wiring sometimes has intermittent short caused by the staples the installer used.
Posted on Jul 31, 2009
  • 3197 Answers
SOURCE: trying to program garage door Access Master will
Try programming your remote this way. Press and hold the button on your remote while you press and immediately release the smart/learn button.
Posted on Sep 15, 2009
  • 3197 Answers
SOURCE: Where to buy remote control and reset My garage door opener also
To erase the memory of the opener so that your old remote will no longer work you need to locate the smart/learn button on the rear of the motor unit. Press and hold this button for 6 seconds. No remotes will now work.
To program the new remote when you get it, hold the button down on the remote and then press and immediately release the smart/learn button.
Call any local door opener repair company from the yellow pages and you should be able to buy a remote from them.
Posted on Feb 08, 2010
  • 3197 Answers
SOURCE: Access Master 1/3 HP garage door does not close, blinks
Most likely your door sensors are out of alignment. Make sure they are pointed directly at one another.
Posted on Apr 12, 2010
Lift master garage door opener won't open door motor runs no access to inside of garage. Suggestions?
manual release has been triggered
just lift up the garage door manually
will take effort
if motor drive engages as you lift and you cant get the door up any more
try the remote
Apr 30, 2017 | Building Materials
Reset garage opener
Look up the procedure to reset the remotes for your specific brand and model. Usually a pretty simple procedure, such as opening the garage with the hard wired unit while pressing a reset button on the remote.
Oct 26, 2014 | Building Materials
I have to "Access master" remote controls to open
Depends on the model. Some have a small screw on the back, some have a small 'door' that slides open and some have a small slot on the bottom that you use a screwdriver or the sun visor clip to insert and twist. Yes they do have a battery.
Nov 09, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have an Access Master garage door opener that will not allow door remotes to sucessfully close the door completely without holding the buttin down until door is completely closed and same with the wall...
Sounds like your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Mar 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
My access Master 350 will not open or close when using remotes
If the light in the wall control is flashing your opener is in the lock/vacation mode. Press and hold the button with the lock icon for 3 seconds. If this is not the case your logic board is bad.
Jul 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trying to program garage door Access Master will not program. Followed steps and now car remote will not work.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Jul 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
