Have a ws-42413 mitsubishi TV
When I push the power button or use the remote to turn the power on, the green light comes on and then goes off with the power after a second or two. The screen stays black and does not display anything.
Any ideas? When I push the power button or use the remote to turn the power on, the green light comes on and then goes off with the power after a second or two. The screen stays black and does not display anything. unplugging for two hours no help. does this model have a reset button and if so where would I find it? My problem is similar.  I turn the tv on and then it will go off on its own.  Sometimes in 1 to 2 seconds and sometimes within 4 to 5 seconds.  I took the back off and and started playing with the power supply.  When I moved it, you could hear it try to power up, but then it would shut off.  I did not see a reset button anywhere.  Any best guesses?  My tv shows the model number as ws-65807 not the one below.
    Top Expert:
  • Televison & ... Master
  • 74,844 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Mar 09, 2017
scottyfixit
  • 186 Answers
SOURCE: mitsubishi ws-65807 no sound or picture
Something related to the video boards. Check all inputs first, then check ribbon cables to the video board. Be careful of high voltage if you open the cover.
Posted on Apr 25, 2008
freetek
  • 5568 Answers
SOURCE: Have a ws-42413 mitsubishi TV
This behavior could be an indicator of power supply problems or abnormal current drain from elsewhere in the set.
Modern supplies are, by design, able to shut down if voltage or currents aren't within the design limits of the circuits they are servicing.
Without some hands-on it is not possible to isolate the problem unless one of the forums deals with a series fault.
If the set had a reset button, it would be located on the outside of it where the user could reset it.
The reset buttons one finds on some sets is nothing other than a very cheap kind of thermal circuit breaker that trips when current is above its limit.
These are kind of prone to failure themselves.
Posted on Jul 13, 2008
SOURCE: mitsubishi HD 1080 series model ws-65807 no volume.
You need a remote. There are places that sell them, but you can usually get by with your cable box remote or some other modestly programmable remote. It would help if you had an owner's manual. You can probably find one on line. It is a bit of a dance to make the menus work correctly.
My set is gone, but you have fairly ordinary on-screen menus. One of them is for sound on or sound off to the internals. That so that there isn't the conflict between speakers from a receiver based audio setup. You should have external speaker outlets on the set itself. If you do, plut in a speaker you're not worried about. you should get sound out from there.or use an audio out connection to a receiver, etc.
Posted on Jan 22, 2009
  • 3 Answers
SOURCE: Mitsubishi WS-65807 + PS3 1080i Screen goes blank when bright white displayed
Go to PS3 / Display settings. Set superbright OFF, even if you don't have HDMI. Set Cross Color Reduction to OFF. Set Display to only one resolution, not all of them as you probably have it now. Set it ot the highest possible resolution and uncheck all other boxes. The 480i is always on by default. The issue, which was very annoying, was fixed for me. I have a mitsubishi 65 inch RP that is pretty bright on daytime/sunlight scenes, so I never thought it was the PS3, but only whet the PS3 was used did this occur. I scanned this site via google to find that nobody else appeared to have resolved this. So after some changes and testing this solution worked for me. Enjoy! - Dave Walz
P.S. I think the only real fix was to set just one display resolution, but I am now watching a movie and am not going to stop it to find out. :) That's for whomever follows this posting to find out for themselves. Either way, this is working great.
Posted on Apr 26, 2009
SD Tech
  • 14553 Answers
SOURCE: cant find part #stk-392-570 for mitsubishi
SIMPLE---GO TO EBAY--
SELECT SEARCH THEN ADVANCED SEARCH AND THEN SEARCH BY SELLER---
sewsales55 is the one I buy mine from--company in Maryland---called SUBURBAN ELECTRONICS--
THEY HAVE THE CHIPS AND OTHER THINGS--also have a online catalog you can order from--usually their prices on Ebay are a bit lower than the catalog prices....
6 month warranty of the chips
IF this helps you, rate this solution as I do this here for free---they are the lowest price best source for these chips and other parts.
SD TECH
Posted on Nov 08, 2009
Tv wont power up?
could be buttons,unplug them and try remote, or the convergence ics are bad
http://www.shopjimmy.com/
Aug 25, 2012 | Mitsubishi WS-55807 TV
Mitsubishi VS-70707 rear projection TV
DOES THE LIGHT BLINK IN A PARTICULAR PATTERN?
Jan 31, 2008 | Mitsubishi WS-55807 TV
When we push the power button on the remote or on the tv the green light comes on for one second and then shuts off ... tv won't turn on
you have a short circuit in the power supply.
1) test the power cord very well
2) test the main swithc for short or open
3)test the power supply, look for a short in transformer+coil+filter+diode+rectifier. and replace
4)test the HVRECT+fLYBACK+ horizontal output for +125Vdc +vertical output for +80Vdc ALL this go to the CRT
color +12vdc+other circuit +12vdc. The first thing do you will have is RASTER, see the block. d
God bless you
Jul 31, 2012 | Mitsubishi WS-65819 TV
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Our WS-55313 Mitsubishi Projection screen tv was on then just died. When we push power button or remote on, the green power light comes on for a couple of seconds then the tv goes off .
do the self check this model has.
When green light goes off press and hold both the input and menu buttons for five seconds and release both buttons.
The power light will blink a two digit error code like, two blinks, two blinks, a pause and then repeat it several times.
let me know what the error code you find is and I will let you know what it means.
SD TECH
Dec 26, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi ws-55511 does not turn on
Listen: you need to wait for the set to first shut off! then push on the TV(not the remote) Input and Menu both at the same time for 5 seconds and then release---the power light will then blink---this model has this feature--
Sep 13, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green timer light turn on tv turns off
Read the info from this link to see if that applies to your TV.
Jul 23, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Jul 13, 2008 | Mitsubishi WS-65905 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
