Question about Kitchen Ranges
Magic Stove- GAS
My oven temp rises to 600 degrees with the stove just on warm. Any idea how where controls are to adjust that? No idea of year or model #
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
If your going above 600 setting only to warm there is no adjustment for that youll need to replace the thermostat/ temp sensor. depending on age. the model is usually located around the frame of unit when the door is opened, or perhaps on the side of the storage drawer when pullled out. you will need to find that to order any part for the machine
Posted on Oct 27, 2008
Replacing oven sensor on GE Range JGSP31GER1WG
You can try the new thermostat and if the temp is still off, then you you will need to replace the control.
Dec 29, 2011 | Whirlpool Stove Oven Sensor 8053344
Oven needs to be calibrated....it heats approximately 100 degrees below where it should
Not familiar with the brand of course but if your model has an Eaton oven control like this one for Viking Page 23 their is an adjustment screw for calibrating the oven temps. Other controls use an adjustment inside the shaft of the oven control itself.
Go to partstown.com and look up the service manual and calibration steps for your stove.
Apr 19, 2011 | DCS 36-6-1 Gas Kitchen Range
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
When I turn on the stove an F3 message comes on
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 26, 2009 | Magic Chef 31000 Gas Kitchen Range
Magic chef oven/stove top range not staying hot
Hi, It very well could be the ignitor. Sometimes they work at first and then will not open the gas valve later in cycle. You can set the oven to heat and watch the ignitor. If it glows and the gas will not ignite in 30 to 45 seconds, the igniter is getting weak. I jope this helps.
Please let me know if I can assit you further.
Vic
Jun 20, 2009 | GE JGRP17 Gas Single Oven
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Stove top gas burners are making my pots black with sut
the flames seem to be to high
try adjusting the air shutters underneath the cook top
May 27, 2009 | Magic Chef 9122 Gas Single Oven
Tappan Oven overheats!!
If you have electronic controls, you'll need either the temperature probe (about $60.00) or the clock (about $150.00). You can test the temperature probe from behind the machine. It should read about 1080 ohms at room temperature. if the probe is good, replace the clock.
If you have mechanical oven controls, you need a new thermostat. Is the too high temp consistent? (i.e. runs at 375F +/- 25F?) If so, you can usually adjust the thermostat **** to read closer to the actual temperature.
Feb 08, 2008 | Tappan TGF320 Gas Kitchen Range
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
