Question about Car Audio & Video
Jvc kd-r620 car stereo wont play sound
Turns on..wont play sound
SOURCE: JVC KD-G720 car stereo - how to change the time?
disconnected the battery an lost all the stations got them back now i can't get the time right  HELP?
Posted on Sep 30, 2008
  • 4 Answers
SOURCE: setting clock on jvc radio
Hey here is an instruction page for your clock.
http://resources.jvc.com/Resources/00/01/13/LVT1775-001B.pdf
Posted on Mar 01, 2009
SOURCE: How do I change the time on my JVC KD-G230 stereo?
its simple. hold the "sel" button until the menu comes up and it will say hours use the volume button to change it. then use the next button to go to the minutes. then you can also change other settings under this menu. hit the "sel" button again to go back.
Posted on Apr 10, 2009
  • 13 Answers
SOURCE: i need to set the clock on my jvc kd-g340 car stereo
make sure radio is on and you press and hold sel (select) button
when you see demo release the select button(you might see other option if you have access the menu options). then press the forward button until you see clock h (hour). to adjust turn volume knob. then press the fast forward button again to get clock m (minute) and use volume knob again to adjust minutes. once you are done make sure to press select again to save the time.
Posted on Apr 22, 2009
josetejas
  • 300 Answers
SOURCE: how do you set the clock on a JVC KD-R200 car
Press and hold SEL button until the menu appears
Using the scan (FWD/REV) button, select Clock H
Using the volume knob, set the value
Using the scan (FWD/REV) button, select Clock M
Press SEL to save and return.
Posted on Jan 22, 2010
Hello, I have a JVC KD-S33, and I just hooked up the interface on the back of my stereo. I can't figure out how to set the stereo to play my ipod touch. The manual seems like chineese to me. The manual...
You can download the detailed user manual for your JVC KD-S33 in English from the following link.Please refer pages 18 and 19 of the pdf document for doubts regarding connecting the iPod touch with the stereo.( http://dl.owneriq.net/8/8abcc36e-cf2e-4b5a-a002-e343f1ffb6bc.pdf ).Please don't forget to rate me if you are satisfied with my solution.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 17, 2011 | JVC KD-G200 CD Player
I just installed a jvc kd g825 and i have a iphone 4 when i plug it in it says reading file and starts charging my iphone but wont play any thing any solutions?
I had a similar problem after I updated my iPhone 3g's software to 4.0.1. I read that if you turn off your iPhone, then with your car/stereo turned off, plug in your iPhone. Now turn on the car/stereo which will turn on your iPhone automatically and "re-initialize" the relationship with the iPhone. This worked for me. Hope this helps. If not, check the Apple forums.
Aug 11, 2010 | JVC KD-G820 CD Player
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
Car stereo JVC KD-PDR40 lost manual can't set clock?
hi my jvc kd-pdr40 cd player keeps resetting the sound to basic with no bass everytime i turn it off
Sep 26, 2009 | JVC KD-PDR30 CD Player
I have a jvc kd-g720 stereo in my car and when I plug my iPod into the usb port it says "do not disconnect" and even though i have about 2,000 songs on my iPod the stereo will only play the same 49 ones in...
if you are plugging your ipod into the usb port of the kd-g720 it won't play all your songs because this particular radio only plays mp3s through the usb port. ipods play both mp3s and mp4s. so those 49 songs you're hearing are the mp3s on your ipod. in order to play all the songs on your ipod you must buy the cord that plugs in the back of the radio that will connect to your ipod. sorry for the bad news man. i had the same thing happen to me.
Sep 01, 2009 | JVC KD-G720 CD Player
Jvc kd avx22 chamelion no subwoofer
THATS CAUSE DVD IS ,,HAS 5.1 AUDIO ,,THE OTHERS DO NOT ,,THERE IN STEREO 2,,CHANELS,,UNLESS YOU GET A PROGRAM TO CREATE THE 5.1
May 15, 2009 | JVC KD-AVX2 Car DVD Player
JVC KD-G351 question
It sounds like your stereo is working properly. I've never seen a car stereo that was wired properly that you could turn on and listen to while the car was off with the key removed from the ignition switch. You would have to move the ignition switch to the accessory position in order to get the stereo to work. Hope this helps. Good luck. Mike D.
Aug 21, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
