Question about Samsung RS2534 Side by Side Refrigerator
LCD Screen won't reset after unplugging
I have a Samsung side by side and I unplugged it to clean behind it and now it won't reset the LCD screen. The manual says to unplug for 9 minutes but that doesn't work either
  • 700 Answers
Try holding the top two buttons in for @ 12 seconds or until the unit beeps then realease them.
Posted on Dec 21, 2008
My JVC flat screen won't turn on, tried unplugging and resetting. Stand-by light is still on. And it's attached to a surge protector than to the wall. I've only had this for 1 year.
More than likely its bad capacitors on the Power supply very common problem with most models. You can get repair kits or replacement power boards from www.tvrepairworld.com
Dec 09, 2012 | JVC LT-42X579 42 in. LCD TV
Tv wont go past the start screen
I have the exact same problem and am seeking a solution too ... it won't boot past the Vizio logo on the screen and the remote and side buttons won't work :(
Apr 18, 2012 | Vizio L32 32 in. LCD HDTV
I bought new screen of ebay but it flickers
Did you check both ends of the LCD Screen cable? The end that goes behind the lcd screen at the top and also the other end that attaches on the board. Also put a piece of tap over where the connections meet on the lcd screen to keep it in place.
Did you reseat (unplug then plug back in) the 2 cables that are in the LCD Inverter located at the bottom of the LCD Screen?
Apr 02, 2012 | Samsung R519-53S Notebook
My sanding 55 in rear projection tv has several hundred dots on the screen and getting worse each day. How can this be fixed?
u need to unplug tv, remove cover of upper back portion which is behind the screen. u will see a mirror fitted on inside of back cover clean both screen, mirror. u will also find on bottom side 3 picture tubes. clean them as well.
Aug 25, 2011 | Samsung Televison & Video
The touch screen is frozen and won't respond to anything. Is there a reset?
Try this, unplug it for about 10-15 second. All these modern appliances use microprocessors for control. Unplug is doing hard shut down on your computer. stewbison
Aug 20, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
The screen was unplugged and now when plugged in the blue light around the power buton just flashes
I tried the reset procedure, i've left it unplugged now for a week and upon ... Now the fifth died. This time, no illumination, just flashing blue light. ... The screen is completely black, the power button is dark blue and no amount of ... The monitor was gone for about 2 weeks (maybe 3) I left it plugged in and ...
deliverator.silverfir.net/?p=369
Dec 04, 2009 | Samsung SyncMaster 932B LCD Monitor
My samsung hdtv has horizontal lines running across the top third of the screen. What is this and how much will it cost to fix??
screen is going down need new one or give this ago it might work mark on side of tv were about lines are this will help locate witch strip wire that is faulty
WARNING HIGH VOLTAGE EVEN WHEN UNPLUGED !!
Unplug tv and take back off you will see on the sides of the screen inverter boards with firley wide ( Brown strip wire ) going into them and were your lines are on screen lift or flickup the locking clip on that strip clean strip and board conection
RECONECT IS REVRES make sure strip wire is located corect and locked if worked will save you money if not you will need screen
Nov 07, 2009 | Samsung TXT3093 30 in. Television
Samsung lcd LN32B360C5DXZA has green haze on screen
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 10, 2018 | Samsung LN32B360 32 in. LCD HDTV
The bottom of the screen has become darker!
Hi
The symptom you are telling is similar to FL inverter problem but with that case usually entire screen goes dim. You may try to reset the settings (Usually AUTO button). Unplug and plug in the electrical connection+Computer connection. Also make sure your Display setting in computer side has not been modified. If issue persist take to the qualified service center. FL inverter is the illuminator part of LCD works like fluorescent tube. FL inverter issue rather lower cost compare to other LCD issues.
Good Luck Happy New Year
Dec 28, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
NOT OPTIMUM MODE
SAME WITH ME GUYS, I THINK THE COMPONENT IN LCD ALREADY BROKEN. MY FRIEND TELL ME THAT PTC COMPONENT IS BROKEN. THE PROBLEM IS I DON'T HAVE THE SCHEMATIC DIAGRAM FOR SAMSUNG 510N. IF WE UNPLUG THE POWER CORD ABOUT 1 HOURS AND PLUG IT AGAIN IT'LL NORMAL AGAIN AND THE"PTC" COMPONENT IS RESPONSIBLE TO THAT JOB.
Nov 14, 2007 | Samsung 510N 15" Flat Panel LCD Monitor
Samsung RS2534 Side by Side Refrigerator Logo
207 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
