Question about Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum
Hoover windtunnel trys to start but then stops
Dirty light flashes but there are no obstructions.motor runs one half to one second then stops. after about three or four trys it will not try to start for a few minutes.
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
  • 97 Answers
SOURCE: Hoover Windtunnel shuts off
Sounds like you have a clog, which is a fairly common problem with these.
Check the air inlet immediately aft of the brushroll for clogs, then make sure the main wand and hose are also clear. If you have the machine on, check at the end of the hose for suction. This is a fairly common problem for all uprights with tools on board. Their airflow is very low, so they tend to clog up easily and then overheat the motor.
-R
Posted on Oct 01, 2008
  • 389 Answers
SOURCE: Hoover windtunnel..runs fine for 5 minutes then stops?
OK - sounds like your machine has a blockage somewhere. Follow manufacturer's instructions for clearing blockages and all should be well. If you no longer have the manual, you can download it from the Hoover website.
Posted on Mar 08, 2009
SOURCE: auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Posted on Jul 09, 2009
carlsbiz
  • 1124 Answers
SOURCE: Hoover Windtunnel shuts down after 15 minutes
Might be that its not exausting enough heat & stutting its self down..
Try cleaning all the filters & the hepa filter..
This will increase air flow & maybe fix the issue..
Hope this helps !!
rate me good ;o)
Posted on Jul 14, 2009
Vacuum stopped while sweeping the floor
it is either the switch or the motor buy a brand new switch to put on it and if that does not solve the problem then the motor is just trash but the switches go out on these kinds of vacuum cleaners all of the time so that is probably the problem but if not the vacuum is trash
Mar 23, 2014 | Hoover Vacuums
Hoover Windtunnel Bagged upright vacuum is smoking and belt is slitting and burning
you probably need to replace your brushroll seeing that your belt is burning means motor is turning. first check you brushroll and see if there is an obstruction keeping it from spinning if its not spinning freely replace
Jan 16, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover Windtunnel bagless self-propelled model #U6616-90. The vaccuum works fine, but the suction hose will hardly ****. There are no obstructions in the hose line. What could be wrong?
The only possible place where it could be clogged is where the hose goes into the motor if the hose is clear. Take the bottom off completely and use a flashlight and investigate. Hope this helped.
Jan 05, 2011 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
SWEEPER STOPPED, WITH A LOUD HUMMING SOUND. THE
Do not turn on again. You have an obstruction in the fan . You will need to remove the motor from the lower housing, dismantle the fan cover and remove the obstruction, possibly replace the fan as well.
The lower housing plate can be removed revealing a set of clamps around the motor hosusing which will in tun release the motor from the base of the vac.
Sep 09, 2009 | Hoover U6630-900 WindTunnel Bagless...
My Hoover Windtunnel, 12-amp, UGG16-900 (or U6616-900 - hard to make out the "G"s from the "6"s) suddenly lost suction this morning. The dirt collection thing is completely clean (I always clean it out...
usually on this machine the door/valve assembly is to blame. if something gets caught in the door/valve assembly it can break this part. you can take it in to see what the est. would be. hope this helps
Jul 27, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5468-900 WindTunnel Supreme suction is suddenly poor
The other possibility is there is a blockage in the foot. these models have dual channel air flow (windtunnel) and become blocked when not cleaned depending on use. under the roller there is a cavity that can be removed for cleaning. a hot motor can be caused by poor air flow.
Mar 15, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Mar 08, 2009 | Hoover U6630-900 WindTunnel Bagless...
Hoover windtunnel U5753-900 will not start
The most likely problem is the on off switch. but it could also be related to the motor or a connection.But definitely electrical in nature. suggest to take it in for service.
Feb 21, 2009 | Hoover U5753-900 WindTunnel Bagless...
Hoover Windtunnel spits dirt back out the back
Your problem sounds to be an obstruction in the foot (lower body) of the windrummel. Most all windtunnel's have a second cavity for suction to go over the top of the roller. When you remove the bottom plate, next remobe the belt and roller, under the roller will be a removable cavity, take it out. remove the dirt and clean out any debris. also check the suction path connecting hose. if your belt has not been changed in the last 12 months, I would recommend changing that as well.
Jan 17, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum Logo
42 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
