Question about IBM ThinkPad R30 2656 Notebook
Ibm bios setup utility
What are the setting requirements that are applied in bios setup utility config date/time password startup restart bios date2001-10-19
  • 3 Answers
SOURCE: Startup Password IBM Thinkpad T40
How to Reset an IBM ThinkPad Power On Password Using Hardware If you cannot boot the ThinkPad, you will have to reset the IBM ThinkPad password via hardware. If only the power-on password is set, do the following to remove the power-on password. Power off the computer Remove the DIMM cover on the bottom side of the computer. Short-circuit the two password pads or put a jumper on the contacts to short the circuit. Under the short-circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed. Reinstall the DIMM cover. If both the power-on password and the supervisor password are set, do the following to remove the passwords: Power on the computer by pressing and holding F1. Enter the supervisor password. The Easy-Setup menu appears. Click on the Password icon. Click on the Power on icon. Enter the supervisor password and press the Space bar. Press Enter twice. Click on Exit; then click on Restart.
Posted on Aug 25, 2007
mrd00d
  • 36 Answers
SOURCE: my IBM t30 wont boot up
Use Knoppix to save your data if you need to, otherwise it sounds like you may need to reinstall the OS.
ftp://ftp.uni-kl.de/pub/linux/knoppix/KNOPPIX_V5.1.0CD-2006-12-30-DE.iso (to download Knoppix 5)
You could try using the recovery console, as previously mentioned as well. If you don't need to save data, just blow it all away and reinstall XP.
RESOLUTION loadTOCNode(1, 'resolution'); If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Posted on Dec 21, 2007
pbenke
  • 88 Answers
SOURCE: Removing CMOS battery on ibm r50e is not solving the pass problem
Removing battery or resetting BIOS with jumper will not help. You should call IBM for support on this issue. All thinkpads have a three year warranty, with either return to base or on-site service. Since the R50e is a recent model, you should have no problem getting it serviced directly by IBM. Toll Free: 1-800-IBM-SERV (1-800-426-7378)
Posted on Jun 25, 2009
kamal1984
  • 1383 Answers
SOURCE: BSOD when turning compuer on c0000021a
You need winxp bootable disk for format or repair your winxp.
Then boot your computer with that disk.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios .
Then set first boot device in bot option as your cd or dvd rom.Then save settings .
Then put your disk in rom then it boot with it.
Posted on Aug 01, 2009
sijudoniston
  • 134 Answers
SOURCE: IBM ThinkPad R50 restore factory settings
You might have deleted the Hidden partition within the drive .So you will not get the restore factory setting option
Posted on Aug 27, 2009
How to reset all settings to my lenovo a269i mobile thru pc
Is it a think pad ?
Power off your Thinkpad.
Press and hold the "F1" key and turn your Thinkpad on, still holding the "F1" key down.
Release the "F1" key when you hear repeating beeps. Wait for the "IBM BIOS Setup Utility" to load.
Select "Startup" using the arrow keys and press "Enter."
Select "Boot" or "Startup Sequence" and press "Enter."
Select "CD-ROM Drive."
Press the "F6" key repeatedly until "CD-ROM Drive" sits at the top of the list.
Insert your recovery CD into your Thinkpad's CD-ROM drive.
If you have multiple recovery CDs, insert the CD that has "Disc 1" on its label.
Press "F10" to save your changes and exit the BIOS Utility.
Select "Yes" and press "Enter" when the "Setup Confirmation" window appears.
Your laptop will restart. Wait for the Recovery Utility to load.
Select "Restore to Factory Specifications" to erase the contents of your hard drive and reinstall the Windows version and drivers that your Thinkpad originally came with.
Follow the Recovery Utility's onscreen instructions.
When prompted to insert another disc, do so according to the numerical labels on your recovery CDs (e.g., insert "Disc 2" after "Disc 1" and "Disc 3" after "Disc 2").
Your Thinkpad restarts when the restore process finishes. Power off your Thinkpad.
Hold down the "F1" key and power on your laptop to access the "IBM BIOS Setup Utility."
Press "F9."
Select "Setup Defaults" from the menu and press "Enter" so that your Thinkpad no longer boots from the CD-ROM drive.
Press "F10" and select "Yes" to confirm your changes.
Your Thinkpad will restart and load your newly installed operating system.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-61432
ThinkVantage Technologies downloads
Feb 20, 2014 | Computers & Internet
Doesn't enable virtualization
To determine whether your PC supports hardware virtualization:
Step 1. Does my PC have a CPU with support for hardware virtualization?
Download and run the Hardware-Assisted Virtualization Detection Tool
If you receive the message This computer does not have hardware-assisted virtualization, your computer does not meet the hardware requirement for Windows Virtual PC, but you can still use Windows 7 XP Mode by running this hotfix. Be aware that XP Mode will run much better if hardware-assisted virtualization can be enabled.
If you receive the message Hardware-assisted virtualization is not enabled on this computer, go on to Step 2 below.
If you receive the message This computer is configured with hardware-assisted virtualization, download and install Windows Virtual PC and Windows XP Mode.
Step 2. Does my PC BIOS support hardware virtualization, and is it turned on?
Instructions to turn on hardware virtualization in your PC BIOS are specific to OEM models. It is important that after changing your BIOS settings the PC is completely shut down at the power switch before restarting so that the new BIOS settings can take place.
Examples for some models of some computer manufacturer's BIOS settings are below:
Sample instructions for your PC
Expand all
Dell systems
Depress the F12 key when boot menu text appears at startup
Select BIOS setup and depress the Enter key
Using the mouse, expand the Virtualization Support menu item by clicking on the plus to the left of Virtualization Support and select Virtualization
Check the Enable Intel Virtualization Technology checkbox
Click Apply
Click Exit
Fully shut down (power off), wait a few seconds, and restart your computer
HP systems
Depress Esc key when prompted at startup
Depress the F10 key to Configure BIOS
Scroll to System Configuration using the arrow keys
Select Virtualization Technology and depress the Enter key
Select Enabled and depress the Enter key
Depress the F10 key to save and exit
Select Yes and depress the Enter key
Lenovo ThinkPad systems
Depress the blue ThinkVantage key when prompted at startup
Depress the F1 key to enter the BIOS setup utility
Using the arrow keys, scroll to Config and depress the Enter key
Scroll to CPU and depress the Enter key
Scroll to Intel Virtualization Technology and depress the Enter key
Depress Enter key to continue
Depress F10 key to save and exit
Acer
PCs capable of supporting Windows XP Mode have already been enabled and do not require additional configuration.
Asus
Samsung
Panasonic
Depress the F2 key when boot menu text appears at startup
Select Advanced menu in Setup Utility
Change "Intel Virtualization Technology" setting from Disable to Enable
Depress F10 to exit Setup Utility
Select Yes in confirmation menu
Depress Enter to exit confirmation menu.
Please note the instructions above may not work in all cases and consulting with your computer manufacturer may be necessary. Additionally, we expect hardware virtualization to become more available when Windows 7 is shipped, particularly in business-class PCs. For those PCs that come pre-installed with Windows XP Mode we recommend the computer manufacturer turn on hardware virtualization before shipping the PC.
Once you have confirmed your PC supports hardware virtualization
Download and install Windows Virtual PC and Windows XP Mode
hope this helps
Aug 08, 2012 | Computers & Internet
Lenovo T61 Power-on password. Hi, my Lap suddenly asks me a code that I unknow. It doesn't able access to any setup, even when I press F1 to open BIOS Setup Utility to remove. I removed Backup battery...
The BIOS password isconfigured from the BIOS setup and this password is stored on an 24RF08 EEPROM chip. There is no backdoor passwordavailable and IBM/Lenevo support says the motherboard needs to be replaced.Also removing the BIOS battery to discharge the BIOS and reset it to thedefault settings will not allow you to bypass this password. This also applies to thePower On Password and the Hard Disk Password.There is a way to crack thepassword but you need electronic skills, electronic components and severalprograms plus a working computer to carry out this task.For details on how to dothis check this WEB site.http://sodoityourself.com/hacking-ibm-thinkpad-bios-password/http://www.fixya.com/support/r4335050-remove_bios_power_password_thinkpad
Feb 07, 2012 | IBM Computers & Internet
I want to repeat my question again as follow: I turned on my Lenovo T60 it can not log in to Window because it show the check date and time message after that it show the Key's picture then I restart...
according to the levono support page at this link: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=YAST-3JWKJX
below is taken from the web site for a T60
Press the blue ThinkVantage button when the message "To interrupt normal startup, press the blue ThinkVantage button " is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
May 15, 2011 | IBM Computers & Internet
Forgot cmos password after cearing cmos not able to boot from harddisk. Pls assist me how to remove cmos password of ibm T60 laptop
I just helped a friend out with this exact issue on the same notebook. Here is the instructions (step by step...well 4 steps) that worked perfectly. What you are doing is using a backdoor password set up by IBM/Lenovo.
Turn on your Thinkpad T60 computer.
  • Watch for the status message "To interrupt normal startup, press the blue ThinkVantage button" to appear on the screen. The only time you have the ability to access your BIOS is while this message is on your monitor. If this message disappears, you will have to restart your T60 and try again.
  • Press the "ThinkVantage" button on your T60. From the list of options that appears, select "Start setup utility." You will be prompted to enter your BIOS password. Type "merlin" and hit "Enter" to bypass the password prompt using your backdoor password and enter your main BIOS utility.
  • Select "Security." In this window, select "Set Password." Type the new password you want to use for your BIOS. Press "Enter" to finish resetting your T60 BIOS password.
  • Hope this helps...
    Jan 03, 2011 | IBM ThinkPad T60 Notebook
    Startup password can't get into bois ibm t60 laptop tryed removing both battery and nothing i can't get it to do nothing
    From your hardware maintenance manual:
    Supervisor password: A supervisor password (SVP) protects the system information stored in the BIOS Setup Utility. The user must enter the SVP in order to get access to the BIOS Setup Utility and change the system configuration.
    Attention: If the SVP has been forgotten and cannot be made available to the servicer, there is no service procedure to reset the password. The system board must be replaced for a scheduled fee.
    Aug 03, 2010 | IBM ThinkPad T60 Notebook
    Lenovo thinkpad R51e , when i power on the laptop it show error code 271
    You need to set time and date in BIOS.
    Press the blue Access IBM button when the message "To interrupt normal startup, press the blue Access IBM button" is displayed to enter the ThinkVantage Productivity Center, then select Start setup utility to open the BIOS Setup Utility.
    Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
    Bios lock, ERROR CODE 0271
    Error code 0271 - Date and time error. Neither the date nor the time is set in the computer.
    Run BIOS Setup Utility to reset the time and date
    It sounds as though your computer has the wrong time in the CMOS. The CMOS (Complementary Metal-Oxide Semiconductors) is the chip that holds the basic startup information for the BIOS, system and its peripherals while the system is turned on and off.
    If you can get into the BIOS check the date and time settings and make sure they are correct.
    It may also be a case of the CMOS battery going out. When this happens your computer will tend to not keep the correct time. They are cheap and relatively easy to replace. Before buying a new batter your can try to take it out and let it sit for about 10 minutes or so to reset the CMOS and then go put the battery back in and go into the BIOS and reset the clock.
    Hopefully taking the batter out or replacing it will get past your lock icon asking for the password. Just search for CMOS or BIOS default password for your brand of laptop.
    Feb 03, 2009 | IBM ThinkPad R52 Notebook
    IBM Think pad T21 Notebook can not boot!! Help please
    Run IBM BIOS Setup
    Utility to reset the time and date.
    Jul 17, 2008 | IBM ThinkPad T21 Notebook
    IBM ThinkPad R30 2656 Notebook Logo
    190 people viewed this question
    Top IBM Computers & Internet Experts
    Computer Links
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
