Question about Acer Computers & Internet
My pc will not turn on properly it comes on but is as if the hard drive is asleep and the monitor says no input signal the dvd opens etc just cant figure it out please help
  • 149 Answers
Your video card is bad..if its attached to your motherboard im afraid you need a new one..depending on how old the computer is you either need to replace the motherboard or buy a new pc..sorry about that..good luck
Posted on Oct 27, 2008
2003 2.0 focus DOHC
What's this ? gaugesax out
P0123 - Throttle Position (TP) Circuit High Input The TP sensor circuit is monitored by the PCM for a high TP rotation angle (or voltage) input through the comprehensive component monitor (CCM). If during key ON engine OFF or key ON engine running the TP rotation angle (or voltage) changes above maximum calibrated limit, the test fails.
  • TP sensor not seated properly
  • TP circuit short to PWR
  • TP circuit short to ETCREF
  • SIG RTN circuit open to TP sensor
  • Damaged TP sensor
  • Damaged PCM
A TP PID (TP V PID) reading greater than 93% (4.65 volts) in key ON engine OFF, continuous memory or key ON engine running indicates a hard fault. P0123 - ETC Throttle Position (TP1) sensor Circuit High Input The ETC TP sensor 1 was flagged as fault status by the PCM indicating high voltage.
  • ETC TP1 sensor harness shorted to VREF
  • ETC TP1 sensor harness shorted to PWR
  • Damaged TP1 sensor
  • VREF circuit shorted to TP1 sensor
Drive vehicle, bring to a stop, turn key OFF. Start vehicle, run key ON engine running self-test at idle. Access KOER diagnostic trouble codes on scan tool.
P0193 - Fuel Rail Pressure Sensor Circuit High Input (FRP) The comprehensive component monitor (CCM) monitors the FRP sensor circuit to the PCM for high voltage. If voltage were to fall below a calibrated limit and a calibrated amount of time during testing, the test will fail.
  • FRP signal shorted to VREF or VPWR.
  • FRP signal open (gasoline only)
  • Low fuel pressure (NG only)
  • Damaged FRP sensor.
  • Damaged PCM.
  • High fuel pressure (caused by damaged fuel pressure regulator) NG.
A FRP PID value during KOER or KOEO less than 0.3 volts for gasoline or 0.5 volts for natural gas vehicles (NG) would indicate a hard fault. P0340 - Camshaft Position (CMP) Sensor Circuit Malfunction (Bank 1) The test fails when the PCM can no longer detect the signal from the CMP sensor on Bank 1.
  • CMP circuit open
  • CMP circuit short to GND
  • CMP circuit short to PWR
  • SIG RTN open (VR sensor)
  • CMP GND open (Hall effect sensor)
  • CMP misinstalled (Hall effect sensor)
  • Damaged CMP sensor shielding
  • Damaged PCM
Harness routing, harness alterations, improper shielding, or electrical interference from other improperly functioning systems may have intermittent impact on the CMP signal.
P0705 TR Sensor TR Circuit Failure TR circuits, indicating an invalid pattern in TR_D. Condition caused by a short to ground or an open in P/N, D, R, 2 or 1 circuits. Open in the taillamp ground circuit. This DTC can be set by an incorrectly adjusted TR sensor. Increase in control pressure (harsh shifts). Defaults to D for an invalid position. MIL on. Inspect the taillamp ground circuit. Go To Pinpoint Test C .
May 27, 2017 | 2003 Ford Focus
Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
May 08, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Whenever i turn on my pc it says no input signal.i dont know whats wrong with it.is it the motherboard or the hard drive?
When you power up the cpu check your smps is working?
Then check num lock key on key bord if it is on and off when you press numlock then your cpu gives dispaly to monitor ok.
but if it not constant on or off no change when you press num lock key then you have to open cpu cabinet.
Refix RAM memory .
Clean dust from motherbord chipset.
Pull out cmos cell for 15 minutes so bios settings are reset to defaults.
then check.
refix all connection to mothebord like ATX power supply from smps.
Jul 23, 2009 | HP Pavilion a1540n PC Desktop
Monitor going to sleep
turn off the hibernation mode if it is turned on.
Jun 15, 2009 | Dell Dimension 3000 PC Desktop
We cant get a signal on the tv and it wont work
If the tv powers on correctly, then recheck all wire connections (including ac cord) are in proper placement and fit. Make sure the DVD is working properly and is connected properly to the tv. Visit the tv menu and check all settings for input signal. Be sure to have the correct "input source" set on your tv.
Jun 13, 2009 | Hisense TL1700 17 in. LCD Television
Hp w1907 monitor not detecting vgi input from original HP x3122 computer
It sounds like your computer has been having some trouble for some time. My hunch is that there is nothing wrong with the monitor at all.
Usually, when you see this warning on the screen that there is no signal, the monitor is trying to tell you that it cannot talk to the computer. This means the computer either a.) will not boot or b.) your video card in the computer has stopped working.
Does your computer make all the usual noises when you start it up? Can you hear the hard drive clicking and the fans come on?
Have you reseated the video connection on the back of the tower?
My guess is that something was going out before and it is now gone. The first place I would look to diagnose this problem is the hard drive.
Hard drives fade to fail sometimes, and when they are fading, the entire computer becomes painfully slow.
Hope this helps
good luck
tony
May 19, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
Problem Using stand alone monitor with laptop computer
signal out of range suggests that your laptop is asleep..open the display settings, and disable those, until you get this resolved.
Oct 15, 2008 | Dell Inspiron 8600 Notebook
Computers & Internet Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
